查看: 1913|回复: 13
高效自学外语的六招
发表于 2010-3-12 10:29:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. Get interested
第一步:对所学之物感兴趣
Make no mistake. Your interest in the subject is the essential driver of success. You can't learn what you do not want to learn. Emotion is an important part of the learning process. If you are even moderately interested in a subject, give yourself a chance. The key is to get started. If you can create some pleasurable routines, you may find that the subject grows on you. “L’appetit vient en mangeant” (the appetite comes with eating) as they say in French.
2. Expect problems and you won’t be disappointed.
第二步:降低期望值,这样就不会对自己失望
Don't expect to understand things, much less remember them, the first time you study them. Trust that things will get clearer as your brain comes to grips with new information. It is like a jig-saw puzzle or a cross-word puzzle. As you start to put the pieces together, or string the words together, the full picture becomes clearer. The brain learns all the time, but on its own schedule. Learning does not take place according to a schedule laid down by a curriculum or teacher. Some things are easier to learn than others. Some things just take longer to click in. Keep at it, and you will gradually find that things that seem difficult at first, will become second nature with time.
3. Cover the same ground from different angles.
第三步:从不同的角度学习同一个知识点。
Your brain is struggling to form patterns to cope with new input from your learning activities. Sometimes, no matter how long you focus on one subject, your brain is not going to pick it up. If you are stuck, move on. Then cover the same general information from a different source, a different book, or a podcast, or an online lecture or a video. Try to become a grazing learner, roaming the countryside, rather than a feedlot learner, just standing there in one spot, munching on the same bale of hay. The broader your base, the easier it is to learn. Just as the “rich get richer”, the more you know, the more you can learn.
4. Anytime is learning time.
第四步:随时都是学习时间!
Take full advantage of the Internet, iTunes, and various mobile devices, not to mention good old-fashioned books and magazines. Learn during “dead time”. Listen in your car, on the train, or while jogging. Have your learning with you while waiting in the doctor's office, or listen while checking out at the supermarket. Anytime is learning time. Remember, you are learning through exposure, not by nailing things down. It is more like moisture accumulation in a cloud, rather than building a brick wall.
5. Be a multimedia learner.
第五步:做一个多媒体学习者
The more varied your learning content, and the more varied the ways in which you learn, the clearer the puzzle will become. Different learning activities suit different people, at different times of the day. Vary your activities in order to keep your interest level up. Even if listening and reading work best for you, treat yourself to the odd video lecture, or get-together with other learners. This will renew your batteries.
6. Join learning communities.
第六步:加入学习社区
The “loneliness of the distance learner” is a thing of the past. Join a learning community on the web, where members share their knowledge and experience. Search for the communities that suit your interests and learning style. You will find encouragement, advice and stimulus from fellow learners, as well as from tutors, teachers and coaches. In these communities, you can measure your progress against your own goals, or compare your experience with that of other learners. You can even teach and help others, which is a great way to learn
参与人数 1威望 +3 收起 理由
sunwaydeng + 3 我很赞同
发表于 2010-3-12 10:48:25 | 只看该作者
good summerization,
发表于 2010-3-12 12:06:02 | 只看该作者
良好的建议啊
值得学习啊
 楼主| 发表于 2010-3-12 14:23:55 | 只看该作者
强烈要求斑竹加个精华贴
发表于 2010-3-12 14:51:36 | 只看该作者
good job ,boy!thank you for your sharing.
 楼主| 发表于 2010-3-14 13:53:48 | 只看该作者
Thank you, everybody.
发表于 2010-4-7 19:35:53 | 只看该作者
我顶,真是好帖,加为精华吧!
 楼主| 发表于 2010-4-15 22:00:17 | 只看该作者
给个精华吧,斑竹同志。
 楼主| 发表于 2010-4-17 19:31:49 | 只看该作者
给个精华吧,版主!!!!
发表于 2010-4-17 20:38:55 | 只看该作者
very good!!
GMT+8, 2026-11-30 14:44 , Processed in 0.048062 second(s), 19 queries , Gzip On.
