查看: 3672|回复: 16
关于美国DOLLAR GENERAL的验厂资料
发表于 2010-3-9 19:33:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求美国DOLLAR GENERAL的验厂资料?谢谢提供
发表于 2010-3-9 22:28:26 | 只看该作者
dollar general是公司名字还是产品名呢?
 楼主| 发表于 2010-3-10 09:03:27 | 只看该作者
公司简介
Dollar General Corporation是一家以客户需求为导方的日用消费品分销商,在美国的29个州拥有6,700多家商店。这些商店的货物由7个分销中心供给:佛罗里达州的Alachua,肯塔基州的Scottsville,密西西比州的Indianola,密苏里州的Fulton,俄亥俄州的Zanesville,俄克拉荷马州的Ardmore以及弗吉尼亚州的South Boston。
发表于 2010-3-10 09:34:39 | 只看该作者
O      All items (except porcelain doll) require Lab Testing at vendor
> expense and must obtain favorable testing results before shipment can occur.
> When required, the lab test is done once per season for each item.           所有由供應商付費要求進行實驗室測試的items(陶瓷娃娃除外),
  一定要在出貨前拿到測試結果. 若要求測試, 每個item每季做一次測試.
> O      Factories used in the manufacturing of the Dollar General product
> will be evaluated at the expense of Dollar General. There are nine critical
> points, which will result in immediate audit failure. Select a factory
> that can meet the following: 針對DG大貨產生工廠, 由DG付費進行評估.
   有9點很重要, 會直接影響驗廠失敗. 要選擇符合以下條件的工廠:
>   1.. Factory is compliant with Dollar General’s Child Labor Policy.
> (The minimum age for employment is 16 years of age.)
      工廠需要遵守Dollar General的童工政策.(雇員最小年齡是16歲)
>   2.. A review of factory documentation confirms there is no evidence of
> forced or involuntary labor, whether in the form of prison, bonded,
> indentured or otherwise. 審看工廠資料, 確認沒有強迫或非自愿的勞工
    的証據, 不論是否以監禁, 擔保, 合同或其他形式.
>   3.. Factory is compliant as required by the applicable country laws
> concerning regular and overtime pay rates.
     工廠要遵守有關普通和加班付薪的相關的國家法律規定.
>   4.. Factory workers are given at least one-day rest per 7-day period.
       工廠工人每7天到少要有一天的休息時間.
>   5.. Factory follows the legal limit on number of annual overtime hours worked.
      工廠要遵守法定的全年加班時間限定.
>   6.. There are sufficient exits for an emergency and doors are opened
> and/or unlocked during working hours. - At least two exits on each floor
>    工作時間, 要有足夠的出口, 門要打開或者不要鎖住, 防止突發事件,
>     每層樓至少要有2個出口.
>   7.. Factory has adequate fire extinguishers on site.
      工廠要有足夠的滅火器.
>   8.. Factory does not engage in trans-shipping activities.
      工廠不要參與中轉活動.
>   9.. If applicable, the factory has a needle replacement policy in effect.
      若可以, 工廠需要實行換針規定.
> O      Two types of Inspections are required for each Purchase Order at the
> expense of Dollar General. 每次下的訂單由DG付費進行兩次檢貨.
> o       During Production Inspection – requires 10% packed products
> (applies to lab test required order only).
      產品檢貨期間, 要求10%的產品完成包裝(只針對實驗室要求的訂單)
> o       Final Random Inspection – requires 80% packed products.
        最終的隨機檢貨--要求80%的產品完成包裝.
Dollar General.rar
1.67 MB, 阅读权限: 1, 下载次数: 203, 下载积分: 金币 -1
参与人数 1金币 +10 威望 +10 收起 理由
yyfbz + 10 + 10 你太有才了
发表于 2010-3-10 14:20:57 | 只看该作者
谢谢分享,我们在努力拿订单呢,先知道知道。
发表于 2010-3-10 20:53:15 | 只看该作者
谢谢分享 4个pdf
发表于 2010-3-18 12:10:24 | 只看该作者
Thanks Very Much
发表于 2010-3-19 00:23:53 | 只看该作者
三个体系一起审核的  重点在人权和质量
发表于 2010-4-23 10:13:16 | 只看该作者
good material
发表于 2010-5-19 13:42:03 | 只看该作者
DING,DING,谢谢分享
GMT+8, 2026-11-17 17:42 , Processed in 0.061822 second(s), 21 queries , Gzip On.
