查看: 3378|回复: 19
请帮忙提供日用玻璃器皿的检验标准
发表于 2007-8-19 11:39:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请知道的朋友帮忙提供,万分感谢!rufeng_sh@163.com
发表于 2007-8-19 12:10:23 | 只看该作者
1.
All products will be evenly finished, free from cracks, rough edges, chips or glaze runs. Painted items shall not flake. Flow marks in glassware must be kept to a minimum.所有的产品末道漆(磨光)均匀,没有裂缝,毛边,缺口或流釉现象.彩绘产品不可出现剥落现象.玻璃产品的流痕必须在最小值范围.
2.
All glazes and paints must be evenly applied and cover the product inside and out unless agreed with the Woolworths Technologist in writing.所有的上釉及油漆产品,其里外必须均匀的覆盖.除非Woolworths 有书面上的工艺认可.
3.
Products intended to stand should be stable when placed on a level surface.设计为站立的产品,将其放置在一个水平面上必须是稳定的.
4.
All lids, corks, or stoppers must fit securely.所有的盖子,软木塞,或塞子必须合适且安全.
5.
All painted products should be consistent in colour unless agreed with the Woolworths Technologist in writing. For hand painted and ethnic products, a tolerance must be agreed.所有彩绘产品其颜色必须一致,除非有Woolworths的工艺书面认可.对于手绘及手工产品,其差异范围必须得到Woolworths 确认.
6.
All vases or products intended to hold liquid shall not leak or deteriorate when exposed to the liquid for extended periods and must satisfy the requirements in Woolworths’ Test Method TM016, Seal Security and Resistance to Leakage.所有花瓶或产品是用来可以装盛液体的,将液体长期的暴露期间将不可出现渗漏或比渗漏更严重.按照Woolworths的测试方式TM016(密封安全和防渗漏)必须是合格的。
7.
Metallic vases must be corrosion resistant and comply with TM009, Rust and Corrosion Resistance.金属花瓶必须抗腐蚀,符合TM009(防锈及抗腐蚀)
8.
Air bubbles in glass products should be kept to a minimum.
Any bubbles present must be below the surface and not present the possibility of being crushed.
See appendix A for glass tolerance on weight, height (where applicable) and bubbles.
玻璃产品的汽泡必须在最小值。任何的汽泡必须是在产品表面里面(汽泡在产品表面不可以破)。
9.
Child appealing products must be tested against BS EN 71 Part 3. The packaging should state:对儿童有吸引力的产品必须按BS EN713部进行测试。包装需要声明:
“This is not a toy”.这不是一个玩具。
10.
Packaging shall be constructed from suitable robust materials and designed in such a way as to ensure the products arrive at store in a saleable condition.包装组件必须适当,坚固耐用,考虑到并保证产品在各种销售条件下可以到达零售店.
11.
Packaging to state:包装须声明:
“Avoid placing on painted / polished surfaces”.
"彩绘/磨光表面避免放置.
Woolworths装饰用玻璃,陶瓷,金属器皿一般要求(中英对照).doc
141 KB, 阅读权限: 20, 下载次数: 78, 下载积分: 金币 -1
参与人数 2金币 +5 威望 +8 收起 理由
wtoqc + 8 全球验货员感谢你
yyfbz + 5 你太有才了
发表于 2007-8-19 15:02:35 | 只看该作者
2楼是Woolworths公司的人吧,哈哈!谢谢了!
发表于 2007-8-21 20:03:35 | 只看该作者
兄弟,谢了!!!
二楼可以把TM016和TM009或TMxxx也发上来吗?
发表于 2007-8-21 20:53:00 | 只看该作者
二楼请多发些TMxxx上来吧.
大力支持二楼!
发表于 2007-8-26 14:11:03 | 只看该作者
谢谢了
发表于 2007-8-28 13:00:52 | 只看该作者
Thanks very much!
发表于 2008-3-24 20:14:07 | 只看该作者
thank you
谢谢你 我下载了
发表于 2008-3-25 09:30:04 | 只看该作者
谢谢啊,学到了很多,有没有更具体一点啊,我想下啊
发表于 2008-3-25 09:30:57 | 只看该作者
下载,,,,顶.......
GMT+8, 2026-7-31 20:46 , Processed in 0.069426 second(s), 21 queries , Gzip On.
