查看: 5172|回复: 16
What is critical defect, major defect and minor defect?
发表于 2007-4-27 18:52:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Defects found in inspection are classified into three categories: critical defects, major defects and minor defects:
1) Critical non-conformity (defect):
A non-conformity(defect) which experience and the judgment indicates is likely to result in a hazardous and injurious situation to the user, or makes the product subject to legal seizure, or not comply with any mandatory regulations(standards) or as per the customer's requirements
2) Major non-conformity (defect):
Non-conformity (defect) other than Critical is like to result in failure, or to reduce materially the usability of the unit for its intended purpose, or having an obvious aesthetic non-conformity (defect) which affect the salability of the products and lessens the value or as per the customer's requirements. A major problem will in all probability result in the customer returning the product for exchange or refund thus affecting the customer or product reputation.
3) Minor non-conformity (defect)
Non-conformity (defect) is that not likely to reduce the usability of the product for its intended purpose or is departure from established standards, having little bearing on the effective use of the products. or as per the customer's requirements. A minor problem may give a degree of consumer dissatisfaction. Several Minor problems together may lead to the customer returning the item.
发表于 2007-5-21 01:36:59 | 只看该作者
thank you for your pointing,would you give your email to me?
发表于 2007-6-9 09:52:47 | 只看该作者
这个问题很重要哦
发表于 2007-6-9 13:15:01 | 只看该作者
如童裝的安全疵點全都是 critical defect
发表于 2007-6-27 15:15:02 | 只看该作者
关于缺陷等级
同意楼上意见.但是需要留意的是有时客人对缺陷等级有不同的定义,有的国外的customer把没有功能也定义为critical.----不知大家有没有遇到类似的情况?
发表于 2007-11-24 23:10:29 | 只看该作者
TKS for good share!
发表于 2007-12-21 10:02:10 | 只看该作者
缺陷等级定义
我同意大家的看法,但据我的经验对缺陷等级我是这样定义的:但不同的客户对产品有不同的定义
CRITICAL DEFECT:对人的生命和财产成在潜在的危机.
MAJOR DEFECT:对产品的使用功能受到一定的影响的.
MINOR DEFECT:一般多指外观方面的不良.
发表于 2007-12-26 11:37:15 | 只看该作者
值得一学. 体会中....
发表于 2007-12-27 19:24:47 | 只看该作者
Learned a lot from above article
发表于 2008-1-3 00:05:38 | 只看该作者
不同客户有不同标准,按客户要求去判断就不会错
GMT+8, 2026-10-28 06:30 , Processed in 0.042729 second(s), 19 queries , Gzip On.
