查看: 5557|回复: 52
About AQL & MIL STD 105E
发表于 2007-4-27 18:48:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
All inspectors use the MIL STD 105E tables, which are recognized standards by every industrial company.
This American standard now has equivalents in all national and international standardization organisations (ANSI/ASQC Z1.4, ISO 2859, NF06-022, BS 6001, DIN 40080).
This standard is a proven method to accept or reject a production lot by inspecting a randomly selected number of products.
This method is called ‘AQL’(acceptable quality level):
Uses the Acceptable Quality Level (AQL) to establish a maximum allowable error rate or variation from the standard. Acceptance testing will cease immediately if the failure rate of the product being tested exceeds the minimum Acceptable Quality Level.
NB: It is important to note that Acceptance Sampling cannot provide 100% perfect products. The only way of achieving this is to produce 100% perfect products.
MIL STD 105E table:
Practically, the MIL STD 105E tables are summarised below:
Table A :
Table B:
NB: What can I find out from the AQL tables?
Let's take a lot of 3,000 units to inspect, with an AQL of 2.5%.
According to Table B, the sample size is therefore 125 units, and the corresponding acceptance number is 7.
In other words:
     If the number of defective units is more than 7, the lot has to be rejected
     If the lot is accepted, it is commonly perceived that there is a maximum of 2.5% of defective units in the lot (with a failure risk percentage of less than 5%).
发表于 2007-5-28 21:10:23 | 只看该作者
楼主很热心.我们公司用的也是这个标准.
发表于 2007-6-5 09:25:05 | 只看该作者
基本上都是用的这个标准的吧?
发表于 2007-6-5 15:55:54 | 只看该作者
105E以经更新了。
发表于 2007-6-5 17:09:15 | 只看该作者
好東西...下了...
发表于 2007-6-14 18:39:39 | 只看该作者
踩踩~~~~~~~~~
发表于 2007-6-18 21:52:18 | 只看该作者
去那里可以下载到呢!!!!
发表于 2007-7-1 12:11:53 | 只看该作者
基本都是用这个标准。。呵呵
发表于 2007-7-1 14:29:18 | 只看该作者
感谢分享,我以前也是用这个的,不过现在不用了,现在全检
发表于 2007-7-2 13:57:20 | 只看该作者
好
谢谢楼主分享!收藏了
GMT+8, 2026-10-18 00:00 , Processed in 0.060677 second(s), 22 queries , Gzip On.
