查看: 1192|回复: 7
BATTERY STANDARD IEC 62133
发表于 2009-10-14 09:52:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Battery Standard IEC 62133 replaces the UL Standard within the IECEE CB Scheme. The status of battery safety standard IEC 62133, which is included in the scope of the IECEE CB Scheme, becomes stronger. After a specified transition period the standard will totally replace the UL 1642 standard used as component standard in equipment certification within the
IECEE CB Scheme.
Battery-Standard-62133.pdf
56.55 KB, 下载次数: 77, 下载积分: 金币 -1
发表于 2009-10-20 15:22:32 | 只看该作者
thanks for your sharing
发表于 2009-11-1 16:20:20 | 只看该作者
This is the newsletter from SGS ---- Safeguard not the stanard, LZ please state it clear to avoid confusing and save our coins!
发表于 2009-11-4 00:01:39 | 只看该作者
回复 1# haijohn 的帖子
thank you for sharing.
发表于 2010-3-25 18:51:52 | 只看该作者
Good, Thanks!
发表于 2010-3-25 19:38:35 | 只看该作者
Just a newsletter?
发表于 2010-4-15 23:41:17 | 只看该作者
这是什么的标准啊?
发表于 2010-10-3 17:08:28 | 只看该作者
Bad, bad man
GMT+8, 2026-11-30 16:25 , Processed in 0.029724 second(s), 21 queries , Gzip On.
