查看: 687|回复: 1
ROHS(欧盟)豁免条款—第39项豁免
发表于 2009-9-29 08:39:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2009年8月14日,欧盟委员会发布G/TBT/N/EEC/292号通报,为了适应技术进步,欧盟拟修订欧洲议会和理事会关于豁免镉的某种应用的指令2002/95/EC(RoHS指令)的附件。这是由委员会提议的在RoHS指令的附件中再增加的一项豁免,如下:
    39、用于固态照明或显示使用系统中的彩色转换II - VI族发光二极管(小于10微克每平方毫米的发光区域)内所含的镉,此项豁免于2014年7月1日截止。
"    39. Cadmium in colour converting II-VI LEDs (< 10 μg Cd per mm2 of light-emitting area) for use in solid state illumination or display systems until 1 July 2014"
      该通报拟于2009年11月末批准并生效,通报评议截止日期自通报日期起60天。
发表于 2009-9-29 14:07:23 | 只看该作者
要求
Exemptions Expiring 31 July 2014
5. Lead in glass
5a. Lead in glass of cathode ray tubes.
5b. Lead in the glass of fluorescent tubes not exceeding 0.2% by weight
5c. Electrical and electronic components which contain lead in a glass or ceramic other than a dielectric ceramic, or in a glass or ceramic matrix compound (e.g. piezoelectronic devices)
7c.1,2: Electronic components with lead in a glass or ceramic matrix compound
7c.1 Electrical and electronic components which contain lead in a glass or ceramic other than a dielectric ceramic or in a glass or ceramic matrix com-pound, (e.g. piezoelectronic devices)
7c.2 Electrical and electronic components for a voltage of 125 V AC or 250 V DC or higher which contain lead in a dielectric ceramic
8b. Cadmium and its compounds in electrical contacts.
9b. Lead in bearing shells and bushes for refrigerant-containing compressors for HVACR applications.
13a. Lead in white glasses used for optical applications.
13b. Cadmium and lead in filter glasses.
15. Lead in solders to complete a viable electrical connection between semiconductor die and carrier within integrated circuit Flip Chip packages.
GMT+8, 2026-10-17 11:48 , Processed in 0.034175 second(s), 18 queries , Gzip On.
