查看: 830|回复: 1
紧固件相关英语1
发表于 2009-9-27 14:21:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
T型槽用螺栓和螺钉
??Bolts and screws for T-slots
??粗牙螺纹螺钉和垫圈组件.第5部分:带锥形弹簧垫圈
??Screw and washer assemblies with coarse thread - Part 5: With captive conical spring washer
??传动元件.用两个螺钉紧固的带盖轴承和无盖轴承
??Driving components - Cap bearings, half bearings - Fastening with two screws
??传动元件.用两个螺钉紧固的法兰轴承
??Driving Components - Flange bearings - Fastened with two screws
??传动元件.用四个螺钉紧固的带盖轴承和无盖轴承
??Driving components - Cap-bearings, half bearings - Fastening with four screws
??传动元件.用四个螺钉紧固的法兰轴承
??Driving components - Flange bearings - Fastened with four screws
??六角内孔平头攻丝螺钉;
??Hexalobular socket pan head tapping screws
??有柄开槽无头螺钉
??Slotted headless screws with shank
??带米制精细齿距螺纹的六角凹头螺钉
??Hexagon socket head cap screws with metric fine pitch thread
??十字槽凹穴六角头自攻螺钉和平垫圈组合件
??Cross recessed hexagon head tapping screw with identation and washer assemblies with plain washers
??带米制细牙螺纹的内六角凹头螺钉
??六角内孔沉头螺钉
??Hexagon socket countersunk head screws
??海关编码
??73181100 方头螺钉
??73182300 铆钉
??73181400 自攻螺钉
??7318.2400 销及开尾销
??白鐵蓋螺絲 A2(18-8)CAP SCREWS
??水平調整螺絲 ADJUSTED LEVELING SCREWS
??航太扣件 AEROSPACE FASTENERS
??合金鋼螺絲(栓) ALLOY STEEL SCREWS (BOLTS)
??鋁螺絲 ALUMINUM SCREWS
??車輛(汽車)螺絲、螺帽 AUTOMOTIVE FASTENERS
??複含材料鉆尾螺絲 BI-METAL SELF DRILLING SCREWS
??大尺寸螺絲 BIG SIZE BOLTS
??公母螺絲組 BINDER POST & SCREW SET
??拉栓 BLIND BOLTS
??銅螺絲(栓) BRASS SCREWS (BOLTS)
??建築螺絲 BUILDING FASTENERS
??建築膨漲螺絲 BUILDING WALL ANCHOR
??半圓頭六角孔螺絲 BUTTON HEAD SOCKET CAP SCREWS
??馬車螺絲 CARRIAGE BOLTS
??活動輪螺絲附件 CASTORS FITTINGS
??塑板螺絲 CHIPBOARD SCREWS
??快速釘緊螺絲及螺帽 CLINCH STUDS & NUTS
??擠壓扣件 CLINCHING FASTENERS
??齒花扣件 CLINCHING PARTS
??寬牙螺絲 COARSE THREAD SCREWS
??鏈帶螺絲 COLLATED SCREWS
??水泥螺絲 CONCRETE SCREWS
??板模扣件 CONSTRUCTION FASTENERS
??貨櫃螺絲 CONTAINER SCREWS
??耐候鋼螺絲 CONTEN STEEL HEAVY HEX BOLTS
??魚尾螺絲 CONTEN STEEL OVAL NECK TRACK BOLTS
??雙刀螺絲 CUTTER SCREWS
??匣板螺絲 DECK SCREWS
??鋅蝶螺絲 DIE CAST WING SCREWS;ZINC ALLOY
??雙頭牙螺絲 DOUBLE END SCREWS, HANGER BOLT
??旋鎖螺絲 DRIVE LOCK SCREWS
??旋入螺絲 DRIVE SCREWS
??牆用螺絲 DRYWALL SCREWS
??EJOT DELTA PT SCREWS
??EJOT PT SCREWS
??電子螺絲 ELECTRONIC SCREWS
??電梯螺絲 ELEVATOR BOLTS
??歐洲螺絲 EURO SCREWS
??環首螺絲 EYE BOLTS
??岡山頭螺絲 FILLISTER SCREWS
??鰭頭螺絲 FIN NECK ROUND HEAD BOLTS
??管配件接頭 FITTING FASTENERS (CONNECTORS)
??突緣螺絲 FLANGE BOLTS (SCREWS)
??平頭六角孔螺絲 FLAT HEAD SOCKET CAP SCREWS
??平紡螺絲 FLAT PAN HEAD SCREWS
??地板螺絲 FLOORING PANEL SCREWS
??基礎螺絲 FOUNDATION BOLTS
??框架支撐螺絲 FRAME ANCHOR-LAG ROUND SCREWS
??傢俱螺絲 FURNITURE SCREWS (CONNECTING BOLTS)
??重型車螺絲、螺帽 HEAVY DUTY WHEEL HUB BOLTS & NUTS
??六角螺絲(栓) HEX HEAD CAP SCREWS (HEX BOLTS)
??六角機械螺絲 HEX HEAD MACHINE BOLTS
??六角木牙螺絲 HEX LAG BOLTS
??內六角孔螺絲 HEX SOCKET CAP SCREWS
??等高螺絲 HEX SOCKET HEAD SHOULDER SCREW
??薄頭強力螺絲 HEX SOCKET LOW HEAD CAP SCREW
??內六角固定螺絲 HEX SOCKET SET SCREWS
??華司頭機械螺絲 HEX WASHER HEAD MACHINE SCREWS
??高低牙螺絲 HIGH LOW THREAD SCREWS
??高張力螺絲 HEX SOCKET HEAD SHOULDER SCREW
??鉸鏈螺絲 HINGE SCREWS
??勾頭螺栓 HOOK BOLTS
??管夾螺絲 HOSE CLAMP SCREWS
??哈克釘 HUCK BOLTS
??旋鎖螺絲 KTX LOCKING RECESS SCREWS
??機械螺絲 MACHINE SCREWS
??MDF螺絲 MDF SCREWS
??微小精密螺絲 MICRO SCREWS
??鉬六角螺絲 MO HEX HEAD CAP SCREWS
??鉬NC螺絲 MO NC FASTENERS
??鉬螺帽 MO NUTS
??鎳合金螺絲 MONEL FASTENERS
??多衝程螺絲 MULTI-STAGE SCREW & PARTS
??利革釘 NYLON PLUG & SCREWS
??單向螺絲 ONE WAY LAG SCREWS
??枋頭中心螺絲 PAN HEAD CENTER BOLTS
??面板螺絲 PANEL FASTENERS
??複合材料用螺絲(夾板用) PARTICLE BOARD SCREWS
??貫穿螺絲 PENETRATE SCREWS
??十字四角複合螺絲 PH+SQ COMBINATION SCREWS
??塑膠螺絲 PLASTIC SCREWS
??犁壁螺絲 PLOW BOLTS
??特殊精密螺絲 PRECISION AXIS AND SPECIAL FASTENERS
??卷帶螺絲 ROLL COLLATED SCREWS
??屋頂螺絲 ROOFING SCREWS
??螺旋椿 SCREW STUDS
??機(踏)車用螺絲.軸心 SCREWS & SHAFTS FOR MOTORCYCLE OR BICYCLE
??針車用螺絲.軸心 SCREWS & SHAFTS FOR SEWING MACHINE
??螺絲附華司組合 SCREWS & WASHERS ASSEMBLED (SEMS)
??安全螺絲 SECURITY SCREWS
??鑽尾螺絲 SELF DRILLING SCREWS
??自攻螺絲 SELF TAPPING SCREWS
??固定螺絲 SCREWS & SHAFTS FOR SEWING MACHINE
??剪力釘 SHEAR CONCRETE STUD
??束肩螺絲(栓) SHOULDER SCREWS (BOLTS)
??一字溝槽固定螺絲 SLOTTED SET SCREWS
??止付螺絲 SOCKET SET SCREWS
??飛機特殊扣件 SOURCE CONTROL BOLTS
??特殊塗裝螺絲 SPECIAL COATING SCREWS
??特長螺絲 SPECIAL LONGER SCREWS
??特殊材質螺絲 SPECIAL MATERIAL SCREWS
??特殊螺絲 SPECIAL SCREWS OR BOLTS
??特殊防鬆螺絲 SPECIAL SELF-LOCKING SCREWS
??不鏽鋼特殊螺絲 SPECIAL STAINLESS STEEL SCREWS
??特殊割尾螺絲 SPECIAL THREAD CUTTING SCREWS
??四角螺絲 SQUARE HEAD BOLTS
??四角頭固定螺絲 SQUARE HEAD SET SCREWS
??不鏽鋼大螺絲 STAINLESS STEEL BOLTS
??不鏽鋼塑板螺絲 STAINLESS STEEL CHIPBOARD SCREWS
??不鏽鋼粗牙螺絲 STAINLESS STEEL COARSE THREAD SCREWS
??不鏽鋼旋入螺絲 STAINLESS STEEL DRIVE SCREWS
??不鏽鋼平頭內六角孔螺絲 STAINLESS STEEL FLAT HEAD SOCKET CAP SCREWS
??不鏽鋼六角螺絲 STAINLESS STEEL HEX HEAD CAP SCREWS
??不鏽鋼內六角螺絲 STAINLESS STEEL HEX SOCKET CAP SCREWS
??不鏽鋼固定螺絲 STAINLESS STEEL HEX SOCKET SET SCREWS
??不鏽鋼高低牙螺絲 STAINLESS STEEL HIGH-LOW THREAD SCREWS
??不鏽鋼機械螺絲 STAINLESS STEEL MACHINE SCREWS
??不鏽鋼小螺絲 STAINLESS STEEL SCREWS
??不鏽鋼鑽尾螺絲 STAINLESS STEEL SELF DRILLING SCREWS
??不鏽鋼自攻螺絲 STAINLESS STEEL SELF TAPPING SCREWS
??不鏽鋼SEMS 螺絲 STAINLESS STEEL SEMS SCREWS
??不鏽鋼自削螺絲 STAINLESS STEEL THREAD CUTTING SCREWS
??不鏽鋼牙條棒 STAINLESS STEEL THREAD ROD
??不鏽鋼三角牙螺絲 STAINLESS STEEL TRIANGULAR SCREW THREAD
??不鏽鋼木螺絲 STAINLESS STEEL WOOD SCREWS
??卡鎖壁虎 STEEL LOCKING ANCHOR
??大頭馬車螺絲 STEP BOLTS
??螺樁栓 STUD BOLTS
??T頭螺絲 T HEAD BOLTS
??扭矩控制螺栓 T.C. BOLTS (TENSION CONTROL BOLTS)
??自削螺絲 THREAD CUTTING SCREWS
??牙條棒 THREAD ROD
??姆指螺絲 THUMB SCREWS
??鈦合金自行車螺絲 TITANIUM -6AL –4R ALLOY FASTENERS
??鈦合金螺絲 TITANIUM ALLOY BOLTS
??鈦六角螺絲 TITANIUM HEX HEAD CAP SCREWS (HEX BOLTS)
??鈦NC螺絲 TITANIUM NC FASTENERS
??鈦止付螺絲 TITANIUM SET SCREWS
??鈦內六角孔螺絲 TITANIUM SOCKET CAP SCREWS
??鈦牙條 TITANIUM THREAD ROD
??套掛螺絲 TOGGLE BOLTS
??套掛螺栓及螺絲 TOGGLE BOLTS & ACOUSTICAL LAG (SCREWEYE)
??馬桶螺絲 TOILET CLOSET BOLTS
??TORX SCREWS TORX SCREWS
??軌道螺栓(魚尾螺絲) TRACK BOLTS
??三角牙螺絲 TRIANGULAR SCREWS THREAD
??U型螺栓 U BOLTS
??直立軸螺絲 VERTICAL SHAFT SCREWS
??焊接螺絲 WELD STUDS,SCREWS,BOLTS
??焊點螺絲 WELD STUDS SCREWS
??輪轂螺栓 WHEEL BOLTS
发表于 2009-9-27 23:54:35 | 只看该作者
回复 1# shenhb001 的帖子
thank you for sharing.
GMT+8, 2026-10-18 09:44 , Processed in 0.046224 second(s), 18 queries , Gzip On.
