查看: 1133|回复: 10
外贸产品主次判定标准
发表于 2009-8-12 16:18:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
外贸产品主次判定标准
Fault Classification Guidelines
CRITICAL
DEFECTS(重大缺失)
A product that presents a hazardous condition or carries a risk of
causing harm or injury to the Customer
产品存在造成客人受伤的问题或是
A product that is unfit for use
产品不宜使用
A defect that could result in a potential legal case or prosecution
会引起法律纠纷或起诉的缺陷。
No critical defects are permitted and observation of a critical
defect results in no further inspection until the Technical team has been
advised.不允许存在重大缺失。
MAJOR DEFECTS(主要缺失)
A product with a functional fault which would result in a product
return
产品存在功能性问题会引起退货。
A product with a cosmetic flaw that is likely to cause Customer
dissatisfaction and result in a return
产品出现的瑕疵可能会引起客诉或退货。
A product that deviates from specification in size/ weight/ colour
产品与规格书所要求的尺寸,重量及颜色不一致。
A product that has commercial faults which render it unsaleable
without rework
产品品质低劣,
不修补处理则严重影响销售。
Major defects may be reworked or rejected depending on the nature
of the problem as advised by the Technical
team主要缺失可以返工或是拒收(签于品质技术部门告知问题本质的基础上)
MINOR DEFECTS(次要缺失)
A product that has defects not rendering the product unusable or
will not cause Customer dissatisfaction
产品的问题不会引起客诉或销售。
A product that does not meet specification but is not serious
enough to be classed as a major fault
产品与规格书不符,
但此问题不能被归纳于主要缺失。
Minor defects may be passed on concession upon authorisation from
the Technical team次要缺失,
可以在品质技术部门授权许可的情况下接受。
MAJOR OR MINOR?
It can be quite hard to classify some faults into major or minor. A
good guide is to assess whether the end customer would find the fault offensive.
If yes – it should be classed as a major fault. Other factors to consider are:
主要缺失与次要缺失很难分类,
但可以依照客人是否会发现问题且投诉来定。如果会,则是重要缺失,
主要因素如下:
a)Location – flaws in high visibility areas are more
likely to be noticed by the customer.
位置:
瑕疵显而易见,很容易被客人注意到。
b)
Size – the larger the flaw the more likely it is to cause offence
to the customer.
尺寸:
瑕疵较大会使客人反感。
c)Colour – the more noticeable the colour of the flaw
颜色:
色差明显会引起客人反感。
d)
Number – the more flaws, the more offence they are likely to cause
to the customer
数量:
较多的瑕疵会使客人反感。
发表于 2009-8-12 21:53:22 | 只看该作者
楼主辛苦,来学习一下.
发表于 2009-8-12 23:58:40 | 只看该作者
楼主乐于分享的精神很好。
发表于 2009-8-13 14:17:09 | 只看该作者
Thank you for your sharing
发表于 2009-8-14 20:04:57 | 只看该作者
谢谢,学习了哦!
发表于 2009-8-16 19:56:30 | 只看该作者
楼主辛苦了,学习了
发表于 2009-8-21 11:36:27 | 只看该作者
赞!!!支持。
发表于 2009-9-12 11:49:59 | 只看该作者
回帖 :) :)
发表于 2009-9-12 13:05:16 | 只看该作者
楼主辛苦,来学习一下
发表于 2009-9-12 14:03:46 | 只看该作者
学习英文 :) :)
GMT+8, 2026-10-17 12:39 , Processed in 0.110710 second(s), 18 queries , Gzip On.
