查看: 914|回复: 3
哪位同行有汽油发电机的标准啊?
发表于 2009-6-22 14:40:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位同行有汽油发电机的标准啊?拿出来分享一下啊 。或者是具体的验货标准   谢谢了!
发表于 2009-6-22 16:06:38 | 只看该作者
leave my feet.
 楼主| 发表于 2009-6-22 17:36:14 | 只看该作者
回复 2# jack.hq 的帖子
说话注意点
发表于 2009-6-22 17:48:24 | 只看该作者
是汽油发电吗?以前验过2单,基本的程序如下(供参考):
1.Checking the quantity of the goods and sampling
2.Checking of the packaging and marking
3.Visual appearance checking
• Check that no scratch, no bump is on the visible surface of unit.
• Check that there is no rust on metal part.
• Check that all the button, knobs, and movable parts operate smoothly.
• Check oil leakage stain(check oil tank bur elimination)
4.Hi-voltage test
5.Continuity of protective bonding circuit
6.Basic function check
7.Endurance test
8.Gasoline consumption check
9.Tilt platform test
10.Regular voltage output with different loading
11.Noise check (if suitable equipment is provided by manufacturer)
12.Barcode check
13.Size and weight measurement
14.Overload protection
欢迎补充~~~
GMT+8, 2026-10-24 05:59 , Processed in 0.130477 second(s), 18 queries , Gzip On.
