查看: 1131|回复: 1
Candle Terminology (HELP LEARN ENGLISH)
发表于 2009-6-2 18:27:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Candle TerminologyCandle: one or more combustible wicks supported by a material that constitutes a fuel which is solid, semi-solid, or quasi-rigid at room temperature, 68 Fahrenheit to 80 Fahrenheit (20 Celsius to 26 Celsius); it can also contain additives which are used for color, odor, stability, or to modify the burning characteristics; the combined function of which is to sustain a light-producing flame.
Filled Candle: A candle produced and used within the same vessel.
Freestanding Candle: A rigid candle (e.g., pillar-shaped, column-shaped, or figurine) recommended to be used on a heat-resistant, non-flammable surface or, on a candle accessory.
Taper Candle: A slender candle produced to be used with a candle accessory for support.
Tealight Candle: A cylindrical filled candle produced with a diameter and height of approximately 1.5" (38mm) and 0.75" (19 mm) respectively.
Votive Candle: A candle produced for use fully within a candle accessory, specifically, a votive holder.
Candle Accessory: An object designed for use with a candle.
Votive Holder: A small open vessel designed to hold a votive candle during use. The votive holder must be capable of containing the melted candle.
Gel Type Candle: A candle where the primary fuel is a liquid such as mineral oil, terpene type chemicals, or modified hydrocarbons that are not mineral oil based which may or may not contain organic functional groups; it also contains a chemical agent to increase the viscosity (thicken) to a point where the candle has a quasi-rigid property.
Wax: A solid or semi-solid material consisting of a mixture of hydrocarbons and/or hydrocarbon derivatives.
Wax Candle: A candle that contains petroleum wax, vegetable wax, animal wax, or insect wax as the primary fuel.
Wick: An object which delivers fuel to a flame through the process of capillary action.
Label: The term label is used to refer not only to stick-on-type labels , but to any other method of providing the warning message, for example , melt imprinting , embossing, direct printing , etc
Types of CandlesToday, there are candles for every occasion... and literally thousands of different candles from which to choose.
Listed below are non-technical descriptions of the most common types of candles used by consumers. See Candle Terminology for official ASTM definitions of candle types.
Taper: A slender candle, typically 6 - 18 inches in height, to be held securely upright by a candle holder. Sometimes referred to as a dinner candle.
Votive: A small cylindrical candle, usually about 1.5 inches in diameter and 2 or 2.5 inches high, which is placed in a "cup" (usually made of glass) to hold the liquefied wax that results from burning. Votives were originally produced as white unscented candles for religious ceremonies; they are now available in many colors and scents.
Pillar or Column: A rigid, self-standing candle that is thick in diameter, with one or more wicks. Despite the name, pillars or column candles can be round, square, hexagonal, etc., and are to be burned on a heat-resistant candle holder.
Luminaria: An outdoor candle created by planting a 15-hour votive in a container filled with sand.
Container or Filled: A candle that is poured into a special or decorative glass, tin or pottery container designed to withstand the heat.
Tealight: A small cylindrical candle, usually about 1 inch in diameter and 1.5 inches high, which is filled in its own holder, typically made of metal.
Specialty: An unusually shaped or sculpted free-standing candle, often painted to depict a three-dimensional object or designed to be viewed primarily as a decorative artwork.
Gel: A transparent-type candle typically having a rubbery-like consistency, made primarily from gelled mineral oils or gelled synthetic hydrocarbons, and poured into a container to maintain its shape. Decorative wax items are frequently suspended within the gel for special visual effect. "Hard" gel candles have a consistency suitable for free-standing candles.
Floating: A shallow candle with a smooth, slightly convex bottom designed specifically to float on water
 楼主| 发表于 2009-6-2 18:28:45 | 只看该作者
THIS IS VERY HARD TO OUR LEARN PLEASE WORK HARD
GMT+8, 2026-11-30 16:09 , Processed in 0.036952 second(s), 18 queries , Gzip On.
