查看: 1281|回复: 0
环保标志
发表于 2007-8-11 23:28:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
環保標誌
Recycling marking
(Triangle recycling marking - same as Germany )
All packaging which are made from plastic, synthetic material (blister cards, clamp shell a.s.o)or metal must be marked with a recycling mark: In the marking should be the matching number which is linked to the used synthetic material.
For example: If you use PA/PE material the marking should look like this:
For synthetic material:
1
PET Polyethylentereflalat
2 ..... =
HDPE Linear Polyethylen
3 ..... =
PVC Polyvinylchlorid
4 ..... =
LDPE
5 ..... =
PP Polypropylen
6 ..... =
PS Polystyren
7 ..... =
PA/PE
For metal:
40 ....
FE steel
41 ..... =
ALU aluminium
(For Baumaxx only)
In addition we request on all cartons(export cartons, inner cartons, display cartons a.s.o) / paper packages ( card, label, color box, hang tag a.s.o)
a waste basket symbol
        ----WEEE SYMBOL
GMT+8, 2026-10-17 16:42 , Processed in 0.110918 second(s), 18 queries , Gzip On.
