查看: 1406|回复: 6
跌落测试
发表于 2007-5-28 13:01:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问有谁知道跌落测试标准
发表于 2007-5-28 14:11:53 | 只看该作者
Please go to my space and consult the "Packaged-Product Drop Test&Impact Velocity Standards".
参与人数 1金币 +3 收起 理由
yyfbz + 3 你很热情
发表于 2007-6-28 10:33:17 | 只看该作者
1,跌落方式:一角三边六面
2跌落高度与重量
重量                                                              高度
1-20.99磅(0.45-9.5KG)                          76.2CM
21-40.99磅(9.55-18.63KG)                        60.9CM
41-60.99磅(18.64-27.72KG)                      45.5CM
61-100磅  (27.73-45.45KG)                       30.5CM
参与人数 1金币 +3 收起 理由
yyfbz + 3 你很热情
发表于 2007-7-6 17:59:52 | 只看该作者
回复 #1 davidke 的帖子
請問你要的是玩具的跌落測試的標準? 如下:
EN:最嚴格的方向 850mm 跌落5次.
ASTM-F963: 0-18 Months  4.5ft, 10 drops
                 19-36months  3.0ft, 4 drops
                 37-96 months 3.0ft, 4 drops
发表于 2007-7-6 19:08:13 | 只看该作者
不知道你要什么的试摔标准,MTL,BV,JCP??
发表于 2007-7-20 21:07:39 | 只看该作者
Drop test instruction
Rules
1.        No refusal from vendor on the drop test is accepted.
2.        Supplier have to provide the appropriate cartoon in order to protect the goods
Objective
Check the reliability of packing and carton quality.
Ensure the safe transit of products.
Test condition
a) Carton quantity tested:
Sampling size: S-1
b) Test surface:
Flat rigid concrete floor
c) Drop Height for non fragile goods                                Drop test for fragile goods
        Toys, EM, Garden tools …                                                Glass or porcelain
Gross Weight        Drop height                Gross Weight        Drop height
0-10kg        80cm                0-10kg        25 cm
10-30kg        50cm                10-30kg        25 cm
Over 30kg        25cm                Over 30kg        25 cm
d) Drop sequence
1.        Test the most fragile corner, if not known, test the
bottom manufacturer’s joint corner
2.        Test the bottom face
e) Carton should withstand the maximum static pressure in shipping container
Product scope:
These drop test applies to the export carton of all products
Note: Not applicable to packed products on a skid or pallet secured together as a single load.
Inspection Points after Test as Usual Inspection:
1, Package of sales unit
2, Safety, function and appearance of the product
Criteria
No critical defect allowed. The master carton still affords reasonable protection to the sales unit.
Operation guideline
If critical defect emerge after test, the PSI report is failed. Major defect found after drop test should be marked as pending in the PSI report. Minor is acceptable. The defect quantity and ratio should be mentioned in the report.
发表于 2007-7-21 21:18:52 | 只看该作者
一般我们电器的是:ISO2448,不过没有现成的
GMT+8, 2026-9-14 19:42 , Processed in 0.044840 second(s), 19 queries , Gzip On.
