查看: 852|回复: 0
ISO 8124-1:2009
发表于 2009-3-30 15:56:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract:
The requirements in ISO 8124-1:2009 apply to all toys, i.e. any product or material designed or clearly intended for use in play by children under 14 years of age. They are applicable to a toy as it is initially received by the consumer and, in addition, they apply after a toy is subjected to reasonably foreseeable conditions of normal use and abuse unless specifically noted otherwise.
The requirements of ISO 8124-1:2009 specify acceptable criteria for structural characteristics of toys, such as shape, size, contour, spacing, as well as acceptable criteria for properties peculiar to certain categories of toy.
ISO 8124-1:2009 specifies requirements and test methods for toys intended for use by children in various age groups from birth to 14 years. It also requires that appropriate warnings and/or instructions for use be given on certain toys or their packaging. Due to linguistic problems that may occur in different countries, the wording of these warnings and instructions is not specified but given as general information in Annex B. It should be noted that different legal requirements exist in many countries with regard to such marking.
ISO 8124-1:2009 does not purport to cover or include every conceivable potential hazard of a particular toy or toy category. Except for labelling requirements indicating the functional hazards and the age range for which the toy is intended, it has no requirements for those characteristics of toys that represent an inherent and recognized hazard that is integral to the function of the toy
http://www.iso.org/iso/iso_catalogue/catalogue_tc/catalogue_detail.htm?csnumber=51974
GMT+8, 2026-11-30 14:13 , Processed in 0.038647 second(s), 18 queries , Gzip On.
