查看: 2575|回复: 13
SGS高档耳机验货知识
发表于 2009-3-18 23:01:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Product inspection contents:
Break down inspection contents for “Headsets”
A). Packaging check
Export carton / Gift box check
Accessory contents check
Literature check
B). Visual check
Product identification mark and labels
Visual appearance and workmanship
C). Safety test
General safety item
Electrical safety item (Not applicable)
D). Mechanical check
Mechanical check
E). Functional check
Audio sweep test (20Hz to 20KHz)
Acoustic output polarity
F). Special data measurement
DCR curve out of ACR.Specification 16
Ω±15%(not +/- 0.5 Ohm)
Critical size and dimensional check, 3 sets
4.0
Defect classification
4.1
Definition :
Defects detected during inspection are classified within 3 categories –
" Critical ", " Major ",
" Minor " , and the
normal definitions are :
Critical:
A defect that is likely to result in hazardous or unsafe conditions for individual using the product or that is contravening mandatory regulations.
Major:
A defect that is likely reducing the usability to result in failure of the product and obvious appearance defects affecting the salability of the product.
Minor:
A defects that does not reduce the usability of the product, but is nevertheless a workmanship defect beyond the defined quality standard.
Note:
For random inspection, the following rules should be applied:
If the same sample has several defects, all defective points should be reported, but the defective category just count for the most serious defective point only.
All defective samples should be replaced or repaired before repacking into the shipping cartons.
In the case of critical defects, the entire shipment must be rejected as a matter of principle and clients consulted for a decision.
4.2
Quality inspection contents and defect classifications
A). Product Packaging check
Export carton / Gift Box / Blister Pack
A01
Wrong export carton:
MAJOR
A02
Wrong shipping mark or incomplete marking:
MAJOR
A03
Smudge or fuzzy printing on export carton or printed matters found not readable:
MINOR
A04
Smudge or fuzzy printing on export carton or printed matters found still readable or sticker used to cover incorrect markings:
MINOR
A05
Wrong color of printing which beyond Client’s expect color:
MINOR
A06
Export carton marking off position / poor cutting / slant on Brand name:
MINOR
A07
Export carton marking off position / poor cutting / slant on Other printed marks:
MINOR
A08
UPC sticker or Serial number sticker on carton is missing, unreadable or does not match contents:
MINOR
A09
Security gummed tapes missing or not secured / fully sealed on opened end:
MINOR
A10
Length of center security gummed tape less than 2 cm but still secured:
MINOR
A11
Substandard materials reduce usability and salability problem:
MAJOR
A12
Export carton box found wet / damaged / torn / not same stock as reference sample/ incorrect color or gloss:
MAJOR
A13
Blister pack edges are cracked or bent:
MINOR
A14
Blister pack is not sealed or seal is partially broken:
MAJOR
A15
Poor printing / poor cutting / smudged letters / found not readable in blister pack insert:
MAJOR
A16
Poor printing / poor cutting / smudged letters found smudged but still readable in blister pack:
MINOR
A17
Color of blister pack insert is the wrong shade:
MINOR
A18
Printing fuzzy or slightly smudged but readable on gift box:
MINOR
A19
Printing fuzzy, smudged, damaged or missing on giftbox and not readable:
MAJOR
A20
Giftbox slightly scratched, dirty, or slightly damaged less than 1 inch:
MINOR
A21
Giftbox badly scratched, dirty, or slightly damaged greater than 1 inch:
MAJOR
A22
Export carton dirty or damaged:
MAJOR
A23
Inner carton dirty or damaged:
MAJOR
Accessory contents
A24
Missing or wrong accessories parts (included modawrap, ear pieces…etc.):
MAJOR
A25
Missing or torn, damaged on protective polyfoams, carton inserts and polybag causing usability problem:
MAJOR
A26
Torn, damaged on protective polyfoams, carton inserts and polybag
not causing usability problem:
MINOR
A27
Packaging materials wrong placement or not fit inside and may caused transportation damaged (include polyfoam, carton insert…etc.):
MAJOR
A28
Dirt stain on packaging material:
MINOR
A29
Foreign material inside the package:
MINOR
A30
ModaWrap is incorrect size by more then 1mm:
MAJOR
A31
ModaWrap holes are not correct size:
MAJOR
A32
ModaWrap lettering not readable:
MINOR
A33
ModaWrap not correct hardness:
MINOR
发表于 2009-3-19 07:14:10 | 只看该作者
好,太有用了。
发表于 2009-3-19 08:11:39 | 只看该作者
DING..............................
发表于 2009-3-19 10:06:09 | 只看该作者
thanks for your data
 楼主| 发表于 2009-3-19 18:56:17 | 只看该作者
如果各位要更全面的高档耳机标准 ,就在站内发消息给小弟,小弟的这个标准是针对人民币500元以上的耳机。
发表于 2009-3-19 19:23:48 | 只看该作者
非常实用!谢谢楼主!好资料!
发表于 2009-3-19 20:13:14 | 只看该作者
晕  把公司内部的WI都放上去了......太有才了
发表于 2009-3-26 16:59:48 | 只看该作者
Audio sweep test (20Hz to 20KHz)--声波
DCR curve out of ACR.Specification 16Ω±15%(not +/- 0.5 Ohm)--内阻抗
请专业人士分析一下
发表于 2009-3-26 21:31:05 | 只看该作者
楼主好人啊,不象有的人一心想要金币,文件要拆成几份.
发表于 2012-10-31 10:13:01 | 只看该作者
i need  function check point
GMT+8, 2026-10-17 11:42 , Processed in 0.043718 second(s), 18 queries , Gzip On.
