查看: 3627|回复: 14
请问“ ASTM 胶袋的平均厚度不能少于?”
发表于 2009-3-11 15:34:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有哪位前辈能告诉我下面几个问题的答案吗?小第感激不尽~~~
1.ASTM 胶袋的平均厚度不能少于?”
2.EN71针对的年龄组是?
3.安全警告“WARNING”字样的字体高度不少于?
 楼主| 发表于 2009-3-11 15:35:43 | 只看该作者
还有一个要请教:几岁以上儿童允许有功能性利边利角?
发表于 2009-3-11 17:19:25 | 只看该作者
那位大哥說一下,小弟我也想知道
发表于 2009-3-11 17:19:37 | 只看该作者
Please be advised of the following requirements for all poly bags/films used and TAPE
in packaging for
all customers.
POLY BAGS/FILMS REQUIREMENT
Toys
For toys, ASTM F963 standard will apply. Any flexible plastic film bags and flexible plastic sheets used as packaging materials with minor dimensions of greater than 3.94 in. and that will not be destroyed when opening the package (i.e. shrink wrap) shall be at least 1.5 mils (0.03810 mm) in nominal thickness, but the actual thickness shall never be less than 1.25 mils (0.03175 mm).
General Merchandise
For all other general merchandise with an opening of greater than 5 in must include the following warning statement or its equivalent on the bag:
Both requirement of
Toys and General Merchandise should be met
English version:
WARNING: To avoid danger of suffocation, keep this bag away from babies and children. Do not use in cribs, beds, carriages or playpens.
The thin film may cling to nose and mouth and prevent breathing. This bag is not a toy. Discard bag and any other packing materials immediately after removing product. Knot up bag before throwing away. Do not re-use this bag.
French version:
MISE EN GARDE: Pour éviter tout risque de suffocation, tenir ce sac hors de la portée des bébés et des enfants. Ne pas utiliser dans les berceaux, les lits, les carrosses ou les parcs. Este filme plástico podría engancharse cerca de la nariz y boca evitando así la respiración. Ce sac ńest pas un jouet. Jeter ce sac ou tout autre matériau d’emballage immédiatement après avoir enlevé les produits. Knot valise avant de jeter. Ne pas ré-utiliser ce sac.
Spanish version:
ADVERTENCIA: Para evitar riesgo de sofocación, mantenga esta bolsa alejada de bebes y niños. No use en cunas, camas, carriolas o corralitos. La delgada película puede aferrarse a la nariz y la boca e impedir la respiración.
Esta bolsa no es un juguete.Tire la bolsa y los otros materiales de empaque immediatamente. Nudo de la bolsa antes de tirar. No re-use ésta bolsa.
Remark:
@The size of the print of the warning on the plastic bag must adhere to the following and must be printed on at least one side of each bag. Languages must be
in the same font size, with equal presentation.
Total Length & Width of the bag – Font Size/ RED Font
60” or more at least 24 point
40” – 59” at least 18 point
30” – 39” at least 14 point
25” – 29” at least 10 point
< 25” at least 10 point
@ The Hole on bag must have diameter more than 1 cm and 8 holes on each bag
TAPE REQUIREMENT
The minimum tape width must be equal to or greater than 2.25 in.
Tape must be applied in a smooth wrinkle-free method. The tape length from each adjacent side and or extending past the corner of the top, bottom or side edge of the carton shall be a minimum of 3.0 in.
参与人数 2金币 +8 威望 +9 收起 理由
jknew + 3 + 3 你太有才了
he_aqi + 5 + 6 你很热情
发表于 2009-3-11 17:20:54 | 只看该作者
揚州商檢局: 包裝薄膜的測試
技術人員會先有個小測試,看看塑膠袋的均勻性.然後在把袋子剪開成為一張塑膠紙.
盡量在不起皺的地方(中間位置),在剪下100mmX100mm(如圖二)
塑膠紙100mmX100mm以筆劃上對角線並取10個點位測量
測量值有兩種
1.平均值------須要達到標準0.00150in(0.03810mm)   附件報告Fail的原因
值0.0037084mm
2.最小值  (10個點上最小的值)------須要達到標準 0.00125in(0.03175mm)
技術人員說每家測試行的誤差值(+/-)會有不同,因為這個測試精準度需要達到1微米= 0.001mm
建議我司的塑膠袋都能達到 最小值 0.039mm or 0.04mm
注意
本要求不適用於以下情況:
  1.12.1 周邊完全拉伸後,袋口周長小于14in(360mm)的袋子。
  1.12.2 周邊完全拉伸後,袋口周長為14in(360mm)或以上,袋長度和完全拉伸後的袋口周長總和小于23in(584mm)。
  1.12.3 額定厚度小于0.00150in (0.0381mm)包裹玩具的收縮薄膜
,一般當顧客打開包裝時薄膜就被破壞。
ps.儀器精準度 1微米=0.001mm
参与人数 1威望 +3 收起 理由
angel520 + 3 你太有才了
发表于 2009-3-11 17:23:16 | 只看该作者
功能性尖點 :
ASTM F963
- 48個月以下兒童玩具不能有功能性尖點
- 48 ~96個月的玩具 , 應在
包裝上加以說明
Warning! Not suitable for children under 4 years. This toy contains a functional sharp point / edge* which may cause injury if mis-used. (* Delete as appropriate )
EN71
- 36個月以下兒童玩具不能有功能性尖點
- 36個月以上的玩具 , 應提醒使用者
注意銳利尖點的潛在危險
Warning! Not suitable for children under 3 years. This toy contains a functional sharp point / edge* which may cause injury if mis-used. (* Delete as appropriate )
参与人数 1金币 +2 收起 理由
angel520 + 2 全球验货员感谢你
发表于 2009-3-11 17:25:24 | 只看该作者
楼上的回答很仔细!
支持你! forever.......
 楼主| 发表于 2009-3-11 17:51:49 | 只看该作者
  谢谢您。
发表于 2009-3-11 18:08:54 | 只看该作者
小弟有2个问题
=>Q1.请问以上这2点是从哪来的??我以前好象有看到过...
=>Q2. ASTM F963-03: Bags or plastic film with a minor dimension of 3.94
in. (100 mm) or less. 是指长/宽≤100mm, 就豁免?????
谢谢回答^^
发表于 2009-3-11 19:15:56 | 只看该作者
Q1. you may check ASTM F963 Package Film section
Q2  100 x 100 mm
参与人数 1金币 +2 威望 +2 收起 理由
he_aqi + 2 + 2 你很热情
GMT+8, 2026-11-30 14:14 , Processed in 0.040306 second(s), 19 queries , Gzip On.
