查看: 620|回复: 2
Spe&Note
发表于 2009-3-9 23:37:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Special attention and notes in report
No.        SA from reports        Improved        Grammar
1        3 out of 5 samples were found the paint peeled off from surface when tape test.        3 of the 5 samples had(=were found with)  the paint peeled off from surface in / during the tape test.         1./ the 5 samples. "the" 特指范围。2./ with/ have sth.done 表示 sth was done.主语不是done 的执行者。
2        According the information from calling Mr. Bryan, only two (2) pcs samples were conducted for the internal check, and power on check were conducted as follow way: thirty (30) minutes on and then five (5) minutes off as a cycle, then up to four hours on (total 8 cycles), and the result was satisfactory.         According to Mr. Bryan, only two (2) pcs of the samples needed the internal check. Power on check was conducted as follows: As a cycle, keep the unit on for thirty (30) minutes  and then off  for five (5) minutes. Totally 8 cycles were conducted.  The results were satisfactory.
 楼主| 发表于 2009-3-9 23:40:39 | 只看该作者
以下是一些外观常见的defects。
发表于 2009-3-10 12:13:43 | 只看该作者
非常好的学习资料,感谢楼主分享
GMT+8, 2026-10-18 05:32 , Processed in 0.027432 second(s), 18 queries , Gzip On.
