查看: 610|回复: 1
power cord snatch test
发表于 2009-2-28 13:42:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
100g Snatch Test – this method details the procedure for carrying out the weighted snatch test.
1.
Clamp the unit under test so it is firmly held horizontally, at least 1 metre above floor level.
2.
Attach a 100g weight to the cable at 1 metre from the cable entry point.
3.
Allow the weight and cable to fall 1 metre.
4.
Repeat 5 times.
5.
Examine the item for any damage or loosening.
Repeat this test three further times to test all four 90 deg plains to the axis.
200g Snatch Test – this method details the procedure for carrying out the weighted snatch test.
1.
2.
Attach a 200g weight to the cable at 1 metre from the cable entry point.
3.
4.
Repeat 5 times.
5.
 楼主| 发表于 2009-3-1 13:14:07 | 只看该作者
请高手说是什么测试, 有做过吗?
请高手说是什么测试, 有做过吗?
GMT+8, 2026-10-17 09:47 , Processed in 0.071298 second(s), 18 queries , Gzip On.
