查看: 74200|回复: 192
杂货 缺陷判定 及 中英对照
发表于 2009-2-18 16:10:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Defect Classification for Sundries
Defect description in Entlish         Defect description in Chinese        Defect Classification
A. MATERIAL
1.Wood part
splinter        木刺        Critical
broken        断开        Major
crack        破裂        Major
rough surface        粗造表面        Major or minor
worm hole        虫眼        Major
black/dead knot        死结        Major or minor
chip        崩掉        Major or minor
2.Plastic part
air bubble        气泡        Major or minor
burn mark         烧焦        Major or minor
flow mark        流水痕        Major or minor
flow line        流水纹        Major or minor
stress mark         顶白        Major or minor
silver mark        银丝纹        Major or minor
whire mark        发白        Major or minor
pits        凹坑        Major or minor
short shot         走料不足        Major or minor
shrinkage        缩水        Major or minor
gate remnant        水口未清        Minor
excessive flash        披锋        Minor
mold in dirt        胶件里脏        Major or minor
wavy surface        震纹        Major or minor
crack        破裂        Major
broken         断开        Major
clamp mark         钳痕        Major or minor
pear skin        沙梨皮(琅胶)        Major or minor
too soft        太软        Major or minor
too hard        太硬        Major or minor
uneven wall thickness        摇模胶件厚度不平均        Major or minor
eject mark        顶针痕        Minor
impure plastic        塑料不纯        Major or minor
plastic reminder        胶粪未清        Minor
plastic residue        胶丝胶        Minor
weld line        夹水纹        Minor
part line misalignment        夹模线移位        Major or minor
3.Metal part
rust        生锈        Major
oxidation        氧化        Major or minor
deformed        变形        Major
bend        弯        Major or minor
crack        破裂        Major
broken        断开        Major
burr        金属披锋        Critical
pin hole        毛孔        Minor
poor polishing        抛光不良        Major or minor
polishing compound        抛光余渣        Minor
void        穿孔        Major
4.Paper
printing out of register        印刷套位不正        Major or minor
whit dot        白点        Major or minor
colour shade        色暗        Major or minor
smeared printing        印刷油污        Major or minor
discoloration        裉色        Major
incorrect paper type        错纸张类型        Minor
creased        皱        Minor
torn        烂
5.Fabrics,Plush
incorrect pile depth        错毛料长度        Major
broken yarn        断纱        Major
coarse yarn of fabric         织物粗纱        Major
missed yarn        织物漏纱        Major
hole at fabric        织物洞眼        Major
fabric torn        织物料烂        Major
permanent fold lines in fabric        织物永久摺纹        Major
crease line in fabric        织物皱纹        Minor
untrimmed thread end        线头没剪        Minor
long loose thread        长线头        Minor
6.Ceramic
deform        变形        Major
a swelling         瘤状物        Major
blister on body         坯身空心泡        Major or minor
body refuse        泥渣/落渣        Major or minor
breaching of body         缺泥        Major
glaze bubble        釉泡        Major or minor
glaze craze        炸釉        Major
crack under the glaze        阴裂        Major
crack on body        坏裂        Major
fusion hole        熔洞        Major or minor
chip         崩        Major
iron spots        斑点        Major or minor
stuck scar        粘疤        Major or minor
flashing        火刺        Major
orange -peel glaze        桔釉        Major
thread -like surface flaws        泥釉缕        Major or minor
thin glaze        釉薄        Major
decoration defect        画面缺陷        Major or minor
smoked         烟熏        Major
yellowing of glaze        阴黄        Major
purple gold        蓝金        Major or minor
ripple glaze        波浪纹        Major or minor
7.Rattan/bamboo/willow
mould         发霉        Critical
worm hole        虫眼        Major
wet on material        材料湿        Major
coating wet        湿油        Major
broken        断裂        Major
low dense weaving        编织疏        Major or minor
willow/rattan/fern end exposed too long        藤条头暴露太长        Minor
insufficient lacquer        喷漆不足        Major or minor
lacquer dripping        聚油        Major or minor
8.Glass
air bubble inside glass        气泡在波璃内        Major or minor
rough and sharp edge of glass         玻璃粗造利边        Critical
chip at glass        玻璃崩口        Major
uneven thickness of glass        玻璃厚薄不均匀        Major
waviness of glass        玻璃波浪纹        Major
glass not very clear        玻璃不够透明        Major or minor
poor grinding around rim of glass        玻璃边研磨不良        Major or minor
glass fragemets attcvhed        粘附玻璃碎片        Critical
9.wax
air bubble in wax        汽泡在蜡内        Major or minor
broken on body         蜡烛中间有断层        Major
poor shape         形状不良        Major or minor
dirt in wax        蜡内污浊        Minor
B.ASSEMBLY WORKMANSHIP
1.Cleanliness
dirt stain         污渍        Minor
glue stain        胶水渍        Minor
colour stain        色渍        Minor
colour shade        色暗        Minor
wet         湿        Major
decay         腐烂        Minor
solvent mark        溶剂渍        Minor
oil stain        油渍        Minor
ball pen mark         圆珠笔渍        Minor
ink mark         墨水渍        Minor
dead insect         死昆虫        Critical
alive insect         活昆虫        Critical
finger print        手指模印        Minor
water stain        水痕        Minor
2.painting
over spraying        喷油过多        Major or minor
under spraying        喷油不足        Major or minor
paint scratch off        涂油刮花        Major or minor
paint peel off        涂油起皮        Major or minor
paint smear        油污        Major or minor
poor insufficient coverage        喷油盖底不足        Major or minor
uneven painting        涂油不均匀        Major or minor
paint accumulation        聚油        Major or minor
paint stain        涂油渍        Major or minor
poor touch up        手感不良        Major or minor
dull colour        色沉        Major or minor
painting off position         涂油移位        Major or minor
bubble paint        油漆起泡        Minor
orange peel        橙皮油        Major or minor
3.Lacquer coating
incomplete lacquer coverage        叻架盖底不足        Major or minor
lacquer accumulation        叻架聚        Major or minor
uneven lacquer coating        叻架涂不均匀        Major or minor
lacquer staing        叻架渍        Major or minor
bubbles in -lacquer        叻架起泡        Minor
lacquer coating too thin         叻架涂层太薄        Major or minor
lacquer coating too thick         叻架涂层太厚        Major or minor
lacquet cracked        叻架裂        Major or minor
参与人数 1金币 +3 威望 +3 收起 理由
fxy104 + 3 + 3 你太有才了
 楼主| 发表于 2009-2-18 16:11:49 | 只看该作者
4.Silk screen priting
incomplete silk screen printing        丝印盖底不足        Major or minor
silk screen printing off position        丝印移位        Major or minor
silk screen printing on wrong position        丝印位置错误        Major
smeared silk screen printing        丝印油污        Major or minor
5.Tempo printing
incomplete tempo printing        移印盖度不足        Major or minor
tempo printing off position        移印移位        Major or minor
smeared tempo printing        移印油污        Major or minor
tempo printing on wrong position        移印位置错误        Major
6.Decal
decal off position        贴花移位        Major or minor
incomplete decal        贴花不全        Major or minor
decal printing out of register        贴花套位不正        Major or minor
clour off tone        色不协调        Major or minor
torn decal         贴花烂        Major or minor
decal printing smeared        贴花油污        Major or minor
7.Sticker
sticker peel off        贴纸翘起        Major or minor
torn sticker        贴纸烂        Major or minor
printing out of register        贴纸套位不正        Major or minor
printing semeared        油污        Major or minor
8.Electro-plating
yellowish         电镀变黄        Major or minor
black mark         电镀发黑        Major or minor
abrasion         电镀擦花        Major or minor
peel off        电镀脱落        Major or minor
elector-plating shadow        电镀阴阳色        Major or minor
elector-plating rainbow        电镀成彩虹印        Major or minor
over plating        电镀过多        Major or minor
under plating        电镀不足        Major or minor
9.Hot stamping
incomplete hot stamping        热烫不全        Major or minor
hot stamping scratch off         热烫刮花        Major or minor
hot stamping off position        热烫移位        Major or minor
10.Others for coating surface
incorrect design        设计错误        Major
incorrect spelling         拼写错误        Major
wrong wording        词名错误        Major
cut mark        削痕        Major or minor
dent mark         凹痕        Major or minor
发表于 2009-2-18 16:38:48 | 只看该作者
谢谢!有一般用句吗?
 楼主| 发表于 2009-2-18 16:50:31 | 只看该作者
这个我到没有哦
发表于 2009-2-18 16:59:31 | 只看该作者
还是很有用
很实用啊,不错
发表于 2009-2-18 17:39:21 | 只看该作者
GOOD,thanks for sharing
发表于 2009-2-18 18:13:10 | 只看该作者
楼主不错,真是想群友之所想呀!!!
发表于 2009-2-19 18:23:35 | 只看该作者
楼主太有才了,CRITICAL,MAJOR,MINOR都判断好了。
 楼主| 发表于 2009-2-19 18:56:32 | 只看该作者
那也是.
发表于 2009-2-22 15:15:31 | 只看该作者
确实厉害,
呵呵,Major,Minor都判断好了,谢谢楼主
GMT+8, 2026-11-30 12:32 , Processed in 0.029749 second(s), 18 queries , Gzip On.
