查看: 6973|回复: 28
洗涤标准和图标,水洗标识
发表于 2007-4-14 14:12:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
<TABLE width="70%">
<TBODY>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dryclean.gif"></TD>
<TD class=engText>dryclean</TD>
<TD class=chiText>干洗</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/donotclean.gif"></TD>
<TD class=engText>do not dryclean</TD>
<TD class=chiText>不可干洗</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry-any.gif"></TD>
<TD class=engText>compatible with any drycleaning methods</TD>
<TD class=chiText>可用各种干洗剂干洗</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/iron.gif"></TD>
<TD class=engText>iron</TD>
<TD class=chiText>熨烫</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/iron-low.gif"></TD>
<TD class=engText>iron on low heat</TD>
<TD class=chiText>低温熨烫 (100<SUP>o</SUP>C)</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/iron-medium.gif"></TD>
<TD class=engText>iron on medium heat</TD>
<TD class=chiText>中温熨烫 (150<SUP>o</SUP>C)</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/iron-high.gif"></TD>
<TD class=engText>iron on high heat</TD>
<TD class=chiText>高温熨烫 (200<SUP>o</SUP>C)</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/iron-no.gif"></TD>
<TD class=engText>do not iron</TD>
<TD class=chiText>不可熨烫</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/bleach.gif"></TD>
<TD class=engText>bleach</TD>
<TD class=chiText>可漂白</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/bleach-no.gif"></TD>
<TD class=engText>do not bleach</TD>
<TD class=chiText>不可漂白</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry.gif"></TD>
<TD class=engText>dry</TD>
<TD class=chiText>干衣</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry-noheat.gif"></TD>
<TD class=engText>tumble dry with no heat</TD>
<TD class=chiText>无温转笼干燥</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry-lowheat.gif"></TD>
<TD class=engText>tumble dry with low heat</TD>
<TD class=chiText>低温转笼干燥</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry-medheat.gif"></TD>
<TD class=engText>tumble dry with medium heat</TD>
<TD class=chiText>中温转笼干燥</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry-hiheat.gif"></TD>
<TD class=engText>tumble dry with high heat</TD>
<TD class=chiText>高温转笼干燥</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/heat-no.gif"></TD>
<TD class=engText>do not tumble dry</TD>
<TD class=chiText>不可转笼干燥</TD></TR>
<TR>
<TD class=chiText>悬挂晾干</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry-drip.gif"></TD>
<TD class=engText>hang dry</TD>
<TD class=chiText>随洗随干</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/dry-flat.gif"></TD>
<TD class=engText>dry flat</TD>
<TD class=chiText>平放晾干</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/wash.gif"></TD>
<TD class=engText>line dry</TD>
<TD class=chiText>洗涤</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/wash-cold.gif"></TD>
<TD class=engText>wash with cold water</TD>
<TD class=chiText>冷水机洗</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/wash-warm.gif"></TD>
<TD class=engText>wash with warm water</TD>
<TD class=chiText>温水机洗</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/wash-hot.gif"></TD>
<TD class=engText>wash with hot water</TD>
<TD class=chiText>热水机洗</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/wash-hand.gif"></TD>
<TD class=engText>handwash only</TD>
<TD class=chiText>只能手洗</TD></TR>
<TR>
<TD><IMG alt="" src="http://www.e-giordano.com/materiel/GIO/CN/CS_washinstructions/wash-no.gif"></TD>
<TD class=engText>do not wash</TD>
<TD class=chiText>不可洗</TD></TR></TBODY></TABLE>
参与人数 3金币 +15 威望 +25 收起 理由
yyfbz + 10 + 10 精品文章
Aaron + 10
broodtrue + 5 + 5 全球验货员感谢你
发表于 2007-5-24 11:23:29 | 只看该作者
经典,可学之处,但我不是从事这行,以后还请多多指教
发表于 2007-5-24 23:42:15 | 只看该作者
回复 #2 qiumin80 的帖子
感謝樓主,學到不少!
发表于 2007-6-17 22:29:19 | 只看该作者
很好
谢谢啦。但图片复制不了,能否改成附件下载的,那就更好啦
发表于 2007-6-18 03:36:29 | 只看该作者
辛苦了,学到很多,感谢!
发表于 2007-6-19 18:04:37 | 只看该作者
呵呵
长了见识了e
发表于 2007-6-19 20:03:06 | 只看该作者
哇噻,我刚入这行,真是学到不少!谢谢
发表于 2007-6-20 16:28:08 | 只看该作者
  3 k you!!!
发表于 2007-7-9 23:19:05 | 只看该作者
我刚入这行,还请多指教。
发表于 2007-7-12 14:04:35 | 只看该作者
好的资料我一定要顶!
GMT+8, 2026-11-5 14:46 , Processed in 0.162722 second(s), 24 queries , Gzip On.
