查看: 682|回复: 1
求助-警告语字母的大小
发表于 2008-12-18 09:37:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
)"CAUTION",WARNING","DANGER" the high degree  of letters no less than 1/8"(3.2mm),others letters should not less than 1/16"(1.6mm).2)"Warning may be provided at a fixed mark in the import or export of equipment with soft lines permanently label" the high degree of letters should not less than 3/32"(2.4mm)
请教:多大的尺寸(面积)时,警告语字母大小是如何要求的?
发表于 2008-12-21 23:29:31 | 只看该作者
没有强制要求说面积大于多少平方就需要印刷多大字母的警告语,上面的要求是最小要求,只要印刷的警告语不小于这个标准就行
GMT+8, 2026-10-23 04:22 , Processed in 0.116472 second(s), 18 queries , Gzip On.
