查看: 1374|回复: 15
照明灯饰灯具分类英语词汇
发表于 2008-12-3 09:44:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
室内灯 residential lamp / light
枝状大吊灯 chandeliers
吊灯 pendant lamp / light
半吊灯 half pendant lamp / light
台灯 table lamp / light
壁灯 wall lamp / light
孙光辉 Jacky Sun
落地灯 floor lamp / light
吸顶灯 ceiling lamp / light
水晶灯 crystal lamp / light
木灯 wooden lamp / light
宫灯 palace lamp / light
仿水晶灯 imitated crystal lamp / light
低压灯 low voltage lamp / light
工艺灯 artificial lamp / light
石艺灯 marble lamp / light
羊皮灯 parchment lamp / light
镜前灯 mirror front lamp / light
镜画灯 picture lamp / light
吊线灯 track / line lamp / light
格栅灯 grille lamp / light
水珠灯 water pearl lamp / light
导轨灯 track lamp / light
柱灯 pillar lamp / light
蒂凡尼灯 tiffany lamp / light
风水灯 water fountain lamp / light
户外灯 outdoor lamp / light
路灯 street lamp / light
筒灯 down lamp / light
投光射灯 spot lamp / light
翻译整理 Translated by
孙光辉 Jacky Sun
庭院灯 garden lamp / light
草坪灯 lawn lamp / light
草地灯 lawn lamp / light
防水灯 water proof lamp / Under water lamp
柱头灯 water jet lamp / light
水底灯 underwater lamp / light
户外壁灯 outdoor wall lamp / light
组合灯 assembled lamp / light
太阳能灯 solar lamp / light
彩灯 holiday lamp / light
彩虹灯 rainbow lamp / light
烟花灯 firework lamp / light
 楼主| 发表于 2008-12-3 09:45:03 | 只看该作者
ambipolar diffusion [物]双极扩散
arc discharge 电弧放电, 弧光放电
avalanche n.雪崩 v.雪崩
buffer gas 缓冲气体
candle n.蜡烛vt.对着光检查
cap 灯座
charge neutrality 电中性区
chromaticity diagram色度图
coiled coil 卷曲螺旋
colorimetry 色度学
Columnar cell 柱状细胞
compact fluorescent lamp 紧凑型荧光灯
cone cell 视锥细胞, 圆锥细胞
critical angle n.[物][空]临界角
carbon arc lamp 炭弧灯
diffuse v.散播, 传播, 漫射, 扩散, (使)慢慢混合 adj.散开的, 弥漫的
diffuse reflection 漫反射
diffuse transmission 扩散透射 漫透射 扩散传输
diffusion n.扩散, 传播, 漫射
double helix 二重螺旋线, 双螺旋线
electroluminescent lamp 场致发光灯
electrode n.电极
electroluminescence n. [物]场致发光, 电致发光
electromagnetic radiation 电磁辐射
electromagnetic wave n.[电磁]电磁波
envelope 玻壳
filament n.细丝, 灯丝
filter n.滤波器, 过滤器, 滤光器, 筛选
fluorescent lamp n.荧光灯(管),日光灯(管)
full radiator 完全辐射体
fuse n.保险丝, 熔丝 v.熔合
gas incandescent lamp 充气白炽灯
gas-filled lamp 充气灯
getter 消气剂
glass pinch 玻璃封接
glow discharge 辉光放电
high pressure mercury lamp 高压汞灯
high pressure xenon lamp 高压氙灯
homogeneous light 单色光
illuminance n.(=illumination)照明[度], 启发
Incandescent lamp 白炽灯, 白热灯
incidence n.]入射
incident angle 入射角
inert gas 惰性气体
infrared ray adj.红外线的 n.红外线
intensity 光强
irradiation 辐照度
lamp cap 灯(泡)头 管帽
lead wire 导线
light intensity 光强度
low pressure discharge 低气压放电
low pressure sodium vapour lamp 低气压钠灯
luminance [计] 亮度
luminous flux n.[物]光通量(其单位为流明lumen)
luminous intensity 发光强度, 照度
medium n.媒体, 方法, 媒介 adj.中间的, 中等的, 半生熟的
mesopic vision 过渡视觉 黄昏黎明视觉
metal halide lamp 金属卤化物灯
metastable states 亚稳态
monochromitry/monochromatic 单色
neon arc lamp 氖(弧)灯, 氖光灯, 霓虹灯
neon lamp n.霓虹灯
phosphor 荧光粉
photogenerator 半导体发光器
photometers n.光度计, 曝光计
photometry n.光度测定, 测光法
photopic vision 亮视觉, 白昼视觉
photosynthesis n.光合作用
positive column 正柱区
primary color 原色
prismatic adj.棱镜的
propagation n.动植物, 繁殖, (声波, 电磁辐射等)传播
radial 射线
 楼主| 发表于 2008-12-3 09:45:19 | 只看该作者
radiance 辐亮度
radiation flux 辐射通量
radiation power 辐射功率
radio wave n.无线电波
radiometry n.辐射线测定
reflect v.反射,
reflection angle n.反射角
refraction 折射
retina n. [解]视网膜
saturated color 饱和色
scattering n.散射
scotopic vision 暗[夜, 微光]视觉
solid angle n.[几]立体角, 多面角
spectral luminous efficiency 光谱效率曲线
spectrum 波谱
spirality n.螺旋形
sputtering 溅射 阴极真空喷镀, 阴极溅镀
thermal radiation 热辐射
total internal reflection [光]全内反射
total reflection 全反射
transmission n.播送, 发射, 传动, 传送, 传输, 转播
trichromatic adj.三色的, 三色版的, 三原色的
tungsten halogen lamp 卤钨灯
ultraviolet radiation n.紫外线
vacuum lamp 真空灯
visible light 可见光
wavelength n.[物][无]波长
 楼主| 发表于 2008-12-3 09:45:34 | 只看该作者
照明术语
1˙重点照明(accent lighting)
指用以强调某一特别目标物,或是引人注意视野中某一部分之一种方向性照明
2˙调适(accommodation)
指人的眼睛焦点自某一点移动至另一点之改变过程
3˙顺应(adaptation)
指人眼视觉系统调适较多或较少、或不同色光之过程,其会影响视觉灵敏度
4˙周围照明(ambient lighting)
指可以产生全般照明之全地区性照明
5˙表面平均亮度(average luminance, of a surface)
指实际离开光照面上单位面积之总流明光通量
6˙灯具平均亮度(average luminance, of a luminaire )
指于某一已知角度之光度除以灯具在该方向之投影面积
7˙遮蔽体(baffle)
指于某一特定角度遮蔽光线直接照射、或吸收不需要光线之不透明或半透明对象
8˙安定器(ballast)
指与放电灯一起使用之一种装置藉以获得起动及运转时所需电路之电流、电压及波形等条件
9˙光束角(beam angle)
指于垂直光束中心线之一平面上,光度等于50%最大光度之二方向的夹角
10˙亮度(brightness)
参照subjective brightness, luminance, veiling luminance
11˙新烛光(candela, cd)
光度单位,参考图F1;以点光源为中心,半径为一公尺作球,如贯通此球面一平方公尺面积上的光束为一流明时,则此方向之光度称为一新烛光
12˙烛光功率(candle power)
I=dX/dS,以新烛光表示
13˙光度配光曲线(candle power distribution curve)
指在一平面上以一电灯或灯具之光源中心利用极坐标方式绘出光度变化情形之曲线
14˙屋顶高窗采光(clere story)
指建筑物具有透明屋顶、或是墙壁具有采光玻璃窗之照明设计
15˙照明率(coefficient of utilization)
指于工作面上接收算得之流明光通量对于估计的电灯放射光通量之比值(等于室利用率×灯具效率)
16˙演色性(color rendering)
指于一光源下某目标物外观呈现之色彩与其在参考光源(如日光)下原有色彩相比其演出之真实感如何是否与原有色彩一样
 楼主| 发表于 2008-12-3 09:45:56 | 只看该作者
17˙对比(contrast)
参照luminance
18˙对比灵敏度(contrast sensitivity)
检测出辉度差异之能力,如以定性方式说明则其等于对比定限之倒数
19˙灯具遮光角(cutoff angle of a luminaire)
自最低点量测,人眼所无法看见裸光之第一条光线与垂直线二者之间的夹角
20˙漫射反射(diffuse reflection)
指入射光束于某一角度范围内反射回去之过程
21˙漫射照明(diffused lighting)
指入射光线并非主要来自单一特别方向之照明方式
22˙漫射器(diffuser)
指某种装置可用以反射、或散射光源所发出之光线,通常主要可藉由漫射完成
23˙直接眩光(direct glare)
视野内由于极高亮度或因光源遮蔽不足、或因高亮度反射所引起之眩光
24˙方向性照明(directional lighting)
指于工作面或目标物上主要来自单一方向之照明
25˙减能眩光(disability glare)
指减低视功能及明视度之眩光
26˙不舒服眩光(discomfort glare)
指令人感觉不舒服之眩光
27˙效力(efficacy)
参照luminous efficacy of a source of light
28˙效率(efficiency)
参照luminaire efficiency, luminous efficacy of a source of light
29˙放电灯(electric-discharge lamp)
指电流经由特殊蒸汽或气体流通因而产生光线或是接近可见光之辐射能的一种电灯
30˙开窗式(fenestration)
指利用开窗、或开窗安排(通常利用光介质控制)俾引入昼光之任何采光方式
31˙张角或光束角(field angle)
于垂直光束中心线之一平面上,光度等于10%最大光度之二方向间的夹角
32˙灯具(fixture)
参照 luminaire
33˙泛光灯(floodlight)
指当参考之景或物之照明需求比其背景强出许多时,被设计用来照明某一景或物之光投射器
34˙日光灯(fluorescent lamp)
属于一种低压水银放电灯
35˙平壁式或隐藏式灯具(flush mounted or recessed luminaire)
指安装于天花板内(或安置于墙壁或其它隔间之中)的一种灯具,灯具之开口通常与其所在平面切齐
36˙光通量(flux)
参照luminous flux
37˙呎烛光(foot candle, fc)
当长度以呎为单位时之照度单位;一流明之光束照射于一平方呎面积上可获得一呎烛光之照度
38˙全般照明(general lighting)
提供全部地区照度大体上呈现均匀分布之一种照明设计
39˙眩光(glare)
视野内产生人眼无法适应之光亮感觉,可能引起厌恶、不舒服甚或丧失明视度
40˙高光度放电管灯(high intensity dischare lamp)
包括水银灯、复金属灯及高压钠气灯
41˙高压钠气灯(high pressure sodium(HPS)lamp)
一种高光度放电灯,可藉施压1.33x104Pa(100Torr)于含钠气灯管使之放射发光
42˙照度(illuminance)
E=dX/dA,指于工作面上接受之入射光通量密度;单位为勒克司(Lux),英美为呎烛光(foot-candle),1fc=10.76lux
43˙照度计(illuminance (lux or foot candle)meter)
于一平面上测量照度之一种仪器
 楼主| 发表于 2008-12-3 09:46:14 | 只看该作者
44˙照明(illumination)
指以灯光照亮之动作或被灯照亮之状态
45˙白炽灯(incandescent filament lamp)
藉将灯丝通以电流使之白炽化发光之电灯
46˙光强度(intensity)
luminous intensity及radiant intensity之简写
47˙反平方定律(inverse-square law)
E=I/d2;照度与距离平方成反比而与光度成正比
48˙等照度线(isolux(isofoo**ndle)line)
指被照面上将相同照度之所有点利用适当坐标绘成的曲线;不同之等照度线构成等照度图
49˙电灯(lamp)
人工光源之一般通称
50˙灯管流明降落系数(lamp lumen depreciation factor,LLD)
用于照明计算之一项乘数,说明灯管之最初照度与使用末期灯管预期之最低照度的关系
51˙电灯遮光角(lamp shielding angle)
指介于电灯遮蔽体或铠板平面,与最接近电灯及铠板片切线方向之水平面二者间之夹角。通常电灯遮光角大于(绝不小于)铠板遮光角
52˙透镜(lens)
用于灯具上之一种玻璃或塑料性组件可以变化光线之方向或是控制配光分布情形
53˙光(light)
可以激发视网膜产生视觉能力之辐射能;电磁波之可见光谱范围为380~770nm(10-9m)
54˙光损失系数(light loss factor, LLF)
在已知情况及于一段时间内用以计算照度大小之一项系数,其将温度、电压变动、灯具及房间外表尘埃堆积量、电灯折旧情形及大气状况等因素均纳入考虑。以前亦称作maintenance factor。
55˙局部照明(local lighting)
提供照度予较小地区或是局部范围之照明设计,其并未能提供任何比较显着之全般周围照明
56˙局部全般照明(localized general lighting)
指利用工作岗位上之灯具提供照明,通常亦包括该工作岗位之周围照明
57˙遮板(louver)
于某特定角度用以遮蔽或是吸收不需要之灯光之成串状的反射物谓之,通常多以几何形状排列
58˙遮板遮光角(louver shielding angle)
指介于电灯遮蔽体或遮板水平面,及将灯具内全部器材隐藏的平面二者间之夹角
59˙方格天花板(louvered ceiling)
属于一种天花板式地区照明系统,藉多重格子状遮板将安装其上之光源予以遮蔽
60˙流明(lumen)
光通量之单位,参考图F1;一新烛光之光源于单位立体角内所发生之光束等于一流明
61˙流明计算法(lumen(or flux)method)
一种照明设计程序,用以决定电灯或灯具数量、型式,房间特性及工作面之平均照度等级之关系。其同时考虑直接光通量及反射光通量之情形。
62˙灯具(luminaire)
指完整之照明配备,包括一或多个电灯、及其附属器材
63˙灯具尘埃减能系数(luminaire dirt depreciation factor, LDD)
用于照度计算之一项乘数,说明灯具于干净、崭新时之照度与灯具在堆积尘埃后之照度的关系
64˙灯具效率(luminaire efficiency)
指灯具发出之光通量对于灯具电灯发出之光通量的比
65˙辉亮度(luminance(photometric brightness))
指于一已知方向的任一光照面上,自该方向观看该面之单位面积光度的大小,所有可见物体均具有一些辉亮度
66˙辉度对比(luminance contrast)
指视目标物辉度与其直接背景辉度二者间之关系
67˙辉度差(luminance difference)
指二地区辉度大小之差异
68˙辉度比(luminance ratio)
视野内二地区辉度大小之比
69˙流明天花板(luminous ceiling)
属于一种天花板式地区照明系统,利用连续式可被光线穿透之平面构成,光源长系安装于其上方可藉漫射或控制变化发光方式
70˙光源辉度效力(luminance efficacy of a source of light)
等于电灯放射出之总光通量除以输入之总电功率,单位为流明/瓦特
 楼主| 发表于 2008-12-3 09:46:32 | 只看该作者
71˙光通量(光束)(luminous flux)
指一光源于某一单位时间内所发出之光线总数量,一般通称为光束,单位为流明
72˙光度(luminous intensity)
点光源于一已知方向放射,于单位立体角内所发出之光通量谓之,单位为烛光或流明/立体角
73˙勒克司(lux)
SI制照度单位,一流明之光束照射在一平方公尺之工作面上可得一勒克司之照度
74˙维护系数(maintenance factor, MF)
指某一地区于一段时间过后之照度与最初照度相较二者之比
75˙无泽面(matte surface)
指反射主要为可予忽略之漫射成分,参见diffuse reflection
76˙卤化金属灯,复金属灯(metal halide lamp)
指一于高强度放电灯(HID),其发光主要藉由卤化金属及其解离原子(结合例如水银金属蒸汽)放射而成。
77˙水银灯(mercury lamp)
指一于高强度放电灯(HID),其主要藉由将水银施压105Pa(约一大气压力)以上使之放射发光而成。
78˙工作面上安装高度(mounting height above the work-plane)
指自工作面至灯具光源中心间之距离,或是至天花板间之距离(指隐藏式灯具而言)
79˙逐点计算法(point method)
亦称作point-by-point method;系一种照明设计程序,其利用灯具之照明亮度数据决定照明系统于不同位置安装之照度。于某点之总照度等于灯具之直接照度及房间表面之间接照度二者之和
80˙主要竞赛区(primary playing area)
指照度水平必须维持之整个竞赛区域
81˙照明之质量(quality of lighting)
于一视觉环境中有关照明分布之衡量。此术语常用以正面评估,用以指出所有照明是否符合视功能、视觉舒服度、容易看、安全度及富美感等的要求条件。
82˙反射率(reflectance of a surface or medium)
即DXr/Di,表示反射之光通量对入射之光通量的比值
83˙反射眩光(reflected glare)
指视野里因擦光体或平滑物产生之高反射亮光所引起之眩光
84˙反射(reflection)
指描述自被照面或介质之入射面离开之入射光通量过程之一般术语
85˙反射器(reflector)
指以反射方式再生光通量之一种装置
86˙室利用系数(room utilization factor (utilance))
指工作面接收之流明光通量对于灯具发射之光通量的比值
87˙次要竞赛区(secondary playing area)
指介于主要竞赛区及实际障碍物(如栅栏)间之地区
88˙灯具遮蔽角(shielding angle (of a luminaire))
指介于通过光源中心水平线及可被人眼看见之第一线裸光二者间之夹角
89˙聚光灯(spotlight)
指具有极窄光束角用以照明某特定地区之灯具
90˙杂散光(stray light)
一般指超出眼睛网膜视线之光线
 楼主| 发表于 2008-12-3 09:46:50 | 只看该作者
91˙主亮度(subjective brightness)
指由于光知觉所产生之任何有关光感觉之主要属性,包括对于所有之明亮度、光照度、辉度、暗淡度或黑暗度之视觉属性
92˙补助照明(supplementary lighting)
指提供额外质与量照度之照明,其无法藉由全般照明系统获得,通常系应特殊工作需要加以安装
93˙平面安装灯具(surface mounted luminaire)
指直接安装在天花板上之灯具而言
94˙工作岗位照明(task lighting)
指一特别被照面或地区之直接照明,提供视工作岗位足够照度
95˙传播(transmission)
P=Xt/Xi;指传送之光通量对入射光通量二者之比值
96˙透过率(transmittance )
指入设光通量自被照面或介质入射面之另外一面离开的过程
97˙钨-卤素电灯(tungsten-halogen lamp)
指一种充气式钨丝白炽灯
98˙光幕照明(veiling luminance)
指降低视网膜影像对比性之一种照明方式。于视野内可藉此法将强光地区改变其视功能及明视度
99˙光幕反射(veiling reflection)
利用光幕漫射反射,将可降低亮度之对比使得目标物较为不清楚
100˙明视度(visibility)
指人眼视觉之质量及状态。于户外,其指目标物可被人眼察觉之距离;于室内,其指可在标准视觉环境观看实际物清楚对比之能力
101˙视觉锐度或视力(visual acuity)
指可辨识目标物清晰度之一种测量视觉能力
102˙视角(visual angle)
指自观察点对向目标物或特定物之弧角,通常以圆弧度测量之
103˙视野或视界(visual field)
头与眼睛如保持固定,则人眼所能看见在空间中之目标物或点的轨迹范围
104˙视觉(visual perception)
指人眼观看真实外界印象自视网膜传送至大脑之一种解说
105˙视功能(visual performance)
将速度及正确性纳入考虑计算视工作岗位照度之一种定量评估
106˙视周围(visual surround)
除了视工作岗位以外之视野部份
107˙视工作岗位(visual task)
传统上指完成一项给予任务所必需之视觉条件,于此条件下所有相关之目标物及工作细节均可看见
108˙工作面(被照面)(work-plane)
通常指完成工作之处,于该处照度定有标准并予量测。除非特别声明,一般假设其位于地板上方0.76米(30吋)之水平面上。
发表于 2008-12-3 19:50:45 | 只看该作者
这个对于检验灯具的朋友来说是个好资料,谢了收藏!
发表于 2008-12-3 23:29:43 | 只看该作者
哦,够全面的,学习学习
GMT+8, 2026-10-16 21:20 , Processed in 0.034485 second(s), 18 queries , Gzip On.
