查看: 803|回复: 2
厂房标识的中英对照
发表于 2008-11-26 10:04:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
冲压课  Stamping Section
冲压区 Stamping Area
冲压现场办公区 Stamping Section Office
点焊区 Welding Area
拉钉区 Riveting Area
打磨区 Sanding Area
拉钉现场办公区 Riveting Section Office
废弃物存放区 Scrap Area
烤漆课 Coating Section
烤漆区 Coating Area
液体/粉体 Liquid/Powder
烤漆清洗线 Degreasing Process
烤漆前处理区 Coating Prep Area
超音波清洗区 Ultrasonic Cleaning Process
粉体烤漆线 Powder Coating Line
液体烤漆线 Liquid Painting Line
粉体涂装室 Powder Coating Spraying Room
液体涂装室 Liquid Painting Spraying Room
烤漆课现场办公区 Coating Section Office
集尘室 Dust Collector Room
吹尘室 Dust Blow Off Room
调漆室 Paint Mixing Room
打磨房 Sanding Room
煤气房 Natural Gas Control Room
预脱脂槽 Degreasing Area Stage 1
主脱脂槽 Degreasing Area Stage 2
皮膜槽 Metal Surface Phosphate Treating Area
清水槽 Rinsing Area
沉淀储水池 Waste Deposit
小心吊物 Warning: Hooks in Operation
小心碰头  Warning: Head Injury, Low Shelves
更衣间 Dressing Room
闲人免进Warning: Only Authorized Personnel
警告: 须着防静电衣后才可入内. Warning: Antistatic Clothing is Required
贵宾衣柜/鞋柜 For Visitors Use Only
员工鞋柜  Employee Shoes Lockers
杂项物料区 Miscellaneous Items Storage
不合格品区 Non-Conforming Parts Area
废弃物存放区 Scrap Area
烤漆制具保养室 Masking Maintenance
烤漆卸制具制程 De-Masking Process
治具保养室 Fixture/Jig/Gauge Maintenance
组配课 Assembly Section
组配区 Assembly Area
上班入口 Entrance
下班出口 Exit
 楼主| 发表于 2008-11-26 10:04:45 | 只看该作者
组配现场办公区 Assembly Section Office
包材作业区 Packaging Area
备料区 Material Staging Area
不合格品区 Non-conforming Parts Area
换鞋间Changing Room
为保持清洁,请您换鞋. For cleanliness, please change your shoes.
组装线Assembly Line
负责人 Line Leader
前置加工线 Prep Line
散件大宗线 Accessory Part Assembly Line
会议室 Conference Room
洗手间 Rest Room
茶水间 Tea Room
电脑机房 MIS Server Room
复印室  Copy Room
教育训练室 Training Room
仓管课 Warehouse Management Section
品管部 QC Dept.
品管部资料室 document Control, QC Dept.
品管部样品室 QC Sample Room
塑料厂 Plastic Plant
塑料厂厂长室 Plastic Plant Manager
塑料厂经理室 Manager
塑料成型课 Molding Section
物料室 Raw Material Warehouse/Storage
碎料室 Crusher Room
模具存放区 Tooling Warehouse
成型课现场办公区 Molding Section Office
工具区 Accessorial Tools Storage
治具柜放置区 Fixture/Jig/Gauge Racks
设备维修区 Tooling Maintenance Area
柜式烤炉 Oven
不良品放置区 Non-Conforming Product Area
重工区 Rework Area
包材存放区 Packing Material Area
塑料喷漆印刷课 Plastic Decoration Section
周转包材放置区 Recycled Packaging Materials Rack
大宗包材放置区 Packaging Material Rack
待印刷产品放置区 Silkscreen/Pad Printing WIP Material
待喷漆产品放置区 WIP Material
"调漆房&治具房Paint Mixing Room & Fixture Shop
 楼主| 发表于 2008-11-26 10:04:51 | 只看该作者
重点防火区 No Fire Area
喷漆房Painting Room
谢绝参观Authorized Personnel Only
浴尘室除尘 Dust Vacuum Room
1.进门灯显示绿灯时开门进入浴尘室
1. Enter the room when light turns green.
2.将进门关上后自动除尘
2.Close door to start vacuum
3.除尘时间约为8秒,听到" 啪 "一声后开门走出
3.Vacuum time 8 seconds. Exit room at the sound of the "pop".
塑料厂设计课 Plastic Molding Design Section
塑料制模课 Tooling Fabrication Section
修模区 Tooling Repair Area
省模区 Polishing Area
制模区 Tooling Fabrication Area
EDM加工区 EDM Area
CNC加工区 CNC Area
检验区 Inspection Area
外发区 Shipping Area
模具厂/中心 Tooling Plant/Center
模具厂办公室 Tooling Center Office
五金模具厂 Sheet Metal Tooling Shop
五金加工设计课 Sheet Metal Tooling Design Section
五金模具维修区Sheet Metal Tooling Maintenance Area
五金模具制模区Sheet Metal Tooling Fabrication Area
线割房 Wire Cutting Shop
五金工具室 Tooling Parts Storage
CNC加工区 CNC Area
样品室 Sample Room
试模区 Stamping Try-Out Area
会议室 Conference Room
厂长室 Plant Manager
铁材仓 Sheet Metal Warehouse ----Raw Materials
冲件仓 Stamping Warehouse ---- WIP
包材仓 Packaging Material Warehouse
塑料仓 Injection Molding Warehouse ---- WIP
待验区 Holding Area
贵重物品仓 High value Materials Warehouse
特殊物料仓 Special Item Storage
塑料原料区 Plastic Warehouse - Raw Materials
不合格仓 Non-conforming Parts Area
烤漆件仓 Coating Parts Warehouse
成品仓 Finished Product Warehouse
小件仓 Small Parts Warehouse
收料窗口 Receiving Window
IQC 检验台 IQC Inspection Station
QA实验室 "Quality Assurance
QA量测室 QA Measurement Office
模具仓 "Tooling Warehouse
GMT+8, 2026-11-30 16:59 , Processed in 0.026464 second(s), 18 queries , Gzip On.
