查看: 787|回复: 1
篮球词汇(七)
发表于 2008-11-26 09:46:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
进攻259.组织进攻:set up
260.进攻组织者:playmaker
261.助攻:assist
262.快攻:(fast)break
263.机动灵活的快攻:racehorse; run and gun
264.高速度进攻:running[up-tempo]game
265.快攻路线(靠边线):lane
266.机动进攻:freelance
267.突破:drive;break
268.强行通过:power drive
269.通过罚球区冲向篮下:drive the lane
270.阵地进攻:position play; set offense
271.交叉进攻:alternating attack
272.中间进攻:center pivot play
273.单中锋进攻:single-post attack
274.换位进攻:shuffle offense
275.侧面进攻:flank offense
276.马蹄形进攻:horseshoe offense
277.磨时间的进攻:stall offense
278.有控制的进攻:controlled offense
279.破人盯人防守的进攻:man-for-man offense
280.拉开对方防守面的进攻:spread offense
281.跟进:trail; follow up
282.前进阻力大:heavy traffic
283.迂回:bypass; circle-back; detour
284.摆脱对方防守:break away [free; loose];shake
285.利用掩护摆脱对手:rub off the screen
286.阻隔对方防守队员:set a pick
287.压缩对方防守:pack the defense
288.冲过人群防守:charge through
289.掩护:screen; pick
290.掩护队员:screener
291.假掩护:dummy screen
292.反掩护:rescreen; screen away
293.侧掩护:side screen
294.内侧掩护(靠3秒区一侧):inside screen
295.外侧掩护:outside screen
296.交叉掩护:crisscross screen
297.定位掩护:stationary screen
298.转身掩护;turnaround block
299.双掩护:double screen
300.行进间掩护:moving [running]screen
 楼主| 发表于 2008-11-26 09:46:14 | 只看该作者
301.切入:cut (in;through);pierce; penetrate; split; knife through
302.切入者:cutter
303.双切:double-cut
304.绕切:cut around
305.背后切入:backdoor cut
306.篮下外切:under and out
307.前场沉底:play deep
308.溜底线;反切打法;后门进攻战术:backdoor play
309.传切配合:pass-[give-]and-go play
310.传切8字进攻:give-and-go weave
311.环形切入(切向边线和篮下):loop cut
312.场角环形切入(从端线到场角再切向篮下):corner loop cut
313.沿边线切入篮下:sweep
314.交叉切入:scissors cut
315.中间切入:inside drive
316.解围的切入:decoy cut
317.V形切入:V cut
318.向里切入(利用策应队员掩护):slice cut
319.向外切入:break-out
320.变向切入:angle cut
321.突然后转:fish hook
322.掩护转身切入:pick and roll
323.突然转身奔至篮下:roll
324.策应:pivot; post up
325.策应队员:counter
326.策应区:post(area)
327.内策应low post
328.外策应:high post
329.迁回策应(从篮下切回3秒区):reverse post
330.中锋策应:bucket[center-pivot;pivot-post] play
331.中锋篮下策应:post play
332.三前锋策应阵式:stack
333.1-3-1进攻阵形:1-3-1 offensive formation
334.马蹄形进攻阵形:2-3 offensive formation
335.1-4进攻(前场四角各一人,另一人在中圈附近):four-corner offense
336.四人8字配合:four-man roll[weave; figure 8]
GMT+8, 2026-11-30 16:56 , Processed in 0.041866 second(s), 18 queries , Gzip On.
