查看: 730|回复: 0
进出口外贸业务包装专用短语、词组(二)
发表于 2008-11-26 09:25:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  长圆形 Long Circle 椭圆形 Oval  双缺圆形 Double Indented Circle 圆内三角形 Triangle in Circle
  三角形 Triangle 六角星形 Hexangular Star
  二重三角形 Double Triangle 对顶三角形 Hourgrass Touching Triangle
  内外三角形 Three Triangle 十字形 Cross
  圆内十字形 Cross in Circle 山角形 Angle
  义架形 Crotch 直线 Line
  月牙形 Crescent 心形 Heart
  星形 Star 包装情况 Packing Condition
  散装 In Bulk 块装 In Block
  条装 In Spear 片装 In Slice
  捆(扎)装 In Bundle 裸装 In Nude
  裸散装 Bare in Loose 木托架立装 Straightly Stand on Wooden Shelf
  传统包装 Traditional Packing 中性包装 Neutral Packing
  水密Water Tight 气密 Air Tight
  不透水包 Water Proof Packing 不透气包 Air Proof Packing
  薄膜 Film Membrane 透明纸 Transparent Paper
  牛皮纸 Kraft Paper 地沥青牛皮纸Bituminous Kraft Paper
  腊纸 Waxpaper 厚板纸 Cardboard Paper
  蒲、苇 Bulrush mat 防水纸 Water Proof Paper
  保丽龙(泡沫塑料)Poly Foam(SnowBox) 竹条Bamboo Batten
  竹篾 Bamboo Skin 狭木条Batten
  铜丝 Brass Wire 铁丝 Iron Wire
  铁条 Iron Rod 扣箍 Buckle
  外捆麻绳Bound with Rope Externally
  外裹蒲包,加捆铁皮Bale?Matted Iron-band-strapped Outside
  块装外加塑料袋Block Covered with Poly Bag
  每件外套一塑料袋 Each Piece Wrapped in a Poly Bag
  机器榨包不带包皮Press Packed Bale without Wrapper
  机器榨包以铁皮捆扎 Press Packed in Iron Hooped Bale
  用牢固的纸箱装运 Packed in Strong Carton
  适合于长途海洋运输 Suitable for Long Distance Ocean Transportation
  适合出口海运包装 Packed in Seaworthy Carton for Export
  全幅卷筒 Full with Rolled on Tube
  每卷用素包聚乙烯袋装 Each Roll in Plain Poly Bag
  混色混码 With Assorted Colours Sizes
  每隔——码烫有边印With Selvedge Stamped Internally at Every——Yards
  用…隔开 Portioned with
  纸屑 Paper Scrap
  纸条 Paper Slip
  纸带 Paper Tape
  纸层 Paper Wool
  泡沫塑料 Foamed Plastics
  泡沫橡胶Foamed Rubber
  帆布袋内充水 Canvas Bag Filled with Water
  包内衬薄纸 Lined with Thin Paper
  内衬锡箔袋 Lined with Frescobag
  内置充气氧塑料袋 Inner Poly Bag Filled with Oxygen
  内衬牛皮纸 Lined with Kraft Paper
  内衬防潮纸、牛皮纸 Lined with Moist Proof Paper &Kraft Paper
  铝箔包装 In Aluminium Foil Packing
  木箱内衬铝箔纸Lined with Aluminium Foil in the Wooden Case
  双层布袋外层上浆 Double Cloth Bag with Outer Bag Starched
  外置木箱 Covered with Wooded Case
GMT+8, 2026-11-30 16:55 , Processed in 0.025383 second(s), 18 queries , Gzip On.
