查看: 1140|回复: 2
中英文
发表于 2008-11-13 14:22:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
QC验货基本准则(中英版本)
2.不符合指定的要求:
2. Not As Specified
a.任何不符合要求的尺寸或超出可接受的范围;
a. Any measurement not as specified or outside the tolerance.
b.主料、颜色、配件、及附件等与与确认的样板有差异的;
b. Fabric, color, hardware, or accessories different from sign-off sample.
c.替代品或漏装的部件;
c. Substituted or missing parts.
d.如要求与主料配色时,所有与原面料标准不配衬的配件或配饰。
d. Poor match of fabric to an established standard or a poor match of accessories to the fabric if a match is intended.
3.面料瑕疵:
3.Fabric Defects
a.破孔
a. Holes
b.
有可能导致布料穿孔的潜伏瑕疵;
b. Any surface blemish or weakness that could become a hole.
c.布料起皱或有抽线、抽纱现象;
c. Snagged or pulled thread or yarn.
d.面料编织瑕疵(如粗糙纱粒及抽纱等);
d. Fabric weaving defects ( Slubs, loose threads, etc.).
e.不均匀的染色、喷胶、托底或其它整理;
e. Uneven application of dye, coating, backing, or other finish.
f.面料结构、“手感”或外观不符合已批核的样板。
f. Fabric construction, “hand feel”, or appearance different from sign off sample.
4.开料方向:
4. Cutting direction
a.
所有绒毛皮料必须依照我们的方向指示开料;
a. All napped leather have to follow our instruction of direction when cutting.
b.任何涉及到开裁方向的面料,如灯芯绒料、针织料、印有或织有图案等布料,都必须依照GEMLINE的指示开裁。
b. Any fabric concerning cutting direction like corduroy/rib-knitted/printed or woven with pattern etc had to follow GEMLINE’s instruction.
(B)结构性错误:
(B) CONSTRUCTION DEFECTS
1.车线:
1. Stitching
a.缝线与大身料颜色不配衬(若货品要求与大身料颜色须相配衬时);
a. Sewing thread different color from main fabric (if a match is intended).
b.车线不直或车线移位,缝入邻近的部分;
b. Stitching not straight or running into adjoining panels.
c.断线;
c. Broken stitches.
d.针数不少于规定的每英寸车线针数;
d. Fewer than specified stitches per inch.
Nylon(尼龙)、Polyester(化纤Poly)及Cotton(棉布),每英寸至少有7针Rayon(人造棉)、PVC、Polyurethane(PU),每一个英寸至少6针。
发表于 2008-11-13 15:08:17 | 只看该作者
学习中,谢谢!
发表于 2017-3-16 23:05:10 | 只看该作者
good file, thanks!
GMT+8, 2026-11-4 05:33 , Processed in 0.035012 second(s), 18 queries , Gzip On.
