查看: 1165|回复: 4
缺陷描述
发表于 2007-7-29 16:22:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这批大货与样品不同,需经业务部确认
The goods is different from the sample, should be recomfirmed by sales department
这些铁架有凹痕,有铁锈,需要返工处理
There is dent and rust of the metal shelf(hob), which need to be re-produced.
经检测后,这批大货不符合我们客人的要求
After testing, these goods does not meet our customers requirements.
如果我们决得你们的意见合理,我们会同意出这批货
If your proposal is regarded reasonable, we will agree to ship
这批电风扇有问题,已经受到了客人的投诉,我们必须严格检查,所有返工好的大货要经过 QA/QC的检验确认
These fans have problem, the guests have been complaints, we must rigorously check after all goods will be redone large, well-recognized QA inspection.
发表于 2007-11-3 20:59:11 | 只看该作者
回复 #1 jackzhu20082008 的帖子
不错!可以参考下,还有没有多一点这样的英语描述啊?
发表于 2007-11-4 12:32:34 | 只看该作者
请发多点英语的描述啊!谢谢!
发表于 2007-11-19 10:07:35 | 只看该作者
    The certificate will be  issued by China Import and Export Commodity Inspection Bureau or by any of  its branches.
     检验证明书将由中国进出口商品检验局或其分支机构出具。
     As a rule, our certificate is made out in Chinese and English.
     通常证明书是用中文和英文开具的。
     Our Inspection Bureau will issue a Veterinary Inspection Certificate to show  that the shipment is in conformity with export standards.
     商检局将出具动物检疫证明书以证明货物符合出口标准。
     We have the best surveyor, China Import and Export Commodity Inspection  Bureau.
     我们有最好的公证行,即中国进出口商品检验局。
     Mr. Black is talking with the Chinese importer about inspecting the goods.
     布莱克先生与中方进口商就商品检验问题进行洽谈。
     How should we define the inspection rights?
     商检的权力怎样加以明确呢?
     We'll accept the goods only if the results from the two inspections are  identical with each other.
     如果双方的检测结果一致,我们就收货。
     Our certificates are made valid by means of the official seal and personal  chop of the commissioner.
     我们的证明书以盖公章和局长签字为有效。
     Our goods must be up to export standards before the Inspection Bureau  releases them.
     我们的货物只有在符合出口标准后,商检局才予以放行。
     What's the time limit for the reinspection?
     复验的时限是什么时候?
发表于 2007-11-21 16:06:41 | 只看该作者
有没有附件形式的啊  上传给兄弟门看看啊
GMT+8, 2026-10-26 12:28 , Processed in 0.027957 second(s), 18 queries , Gzip On.
