查看: 1188|回复: 14
印制电路词汇
发表于 2008-8-29 09:31:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一、 综合词汇  1、 印制电路:printed circuit
  2、 印制线路:printed wiring
  3、 印制板:printed board
  4、 印制板电路:printed circuit board (pcb)
  5、 印制线路板:printed wiring board(pwb)
  6、 印制元件:printed component
  7、 印制接点:printed contact
  8、 印制板装配:printed board assembly
  9、 板:board
  10、 单面印制板:single-sided printed board(ssb)
  11、 双面印制板:double-sided printed board(dsb)
  12、 多层印制板:mulitlayer printed board(mlb)
  13、 多层印制电路板:mulitlayer printed circuit board
  14、 多层印制线路板:mulitlayer prited wiring board
  15、 刚性印制板:rigid printed board
  16、 刚性单面印制板:rigid single-sided printed borad
  17、 刚性双面印制板:rigid double-sided printed borad
  18、 刚性多层印制板:rigid multilayer printed board
  19、 挠性多层印制板:flexible multilayer printed board
  20、 挠性印制板:flexible printed board
  21、 挠性单面印制板:flexible single-sided printed board
  22、 挠性双面印制板:flexible double-sided printed board
  23、 挠性印制电路:flexible printed circuit (fpc)
  24、 挠性印制线路:flexible printed wiring
  25、 刚性印制板:flex-rigid printed board, rigid-flex printed board
  26、 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
  27、 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
  28、 齐平印制板:flush printed board
  29、 金属芯印制板:metal core printed board
  30、 金属基印制板:metal base printed board
  31、 多重布线印制板:mulit-wiring printed board
  32、 陶瓷印制板:ceramic substrate printed board
  33、 导电胶印制板:electroconductive paste printed board
  34、 模塑电路板:molded circuit board
  35、 模压印制板:stamped printed wiring board
  36、 顺序层压多层印制板:sequentially-laminated mulitlayer
  37、 散线印制板:discrete wiring board
  38、 微线印制板:micro wire board
  39、 积层印制板:buile-up printed board
  40、 积层多层印制板:build-up mulitlayer printed board (bum)
  41、 积层挠印制板:build-up flexible printed board
  42、 表面层合电路板:surface laminar circuit (slc)
  43、 埋入凸块连印制板:b2it printed board
  44、 多层膜基板:multi-layered film substrate(mfs)
  45、 层间全内导通多层印制板:alivh multilayer printed board
  46、 载芯片板:chip on board (cob)
  47、 埋电阻板:buried resistance board
  48、 母板:mother board
  49、 子板:daughter board
  50、 背板:backplane
  51、 裸板:bare board
  52、 键盘板夹心板:copper-invar-copper board
  53、 动态挠性板:dynamic flex board
  54、 静态挠性板:static flex board
  55、 可断拼板:break-away planel
  56、 电缆:cable
  57、 挠性扁平电缆:flexible flat cable (ffc)
  58、 薄膜开关:membrane switch
  59、 混合电路:hybrid circuit
  60、 厚膜:thick film
  61、 厚膜电路:thick film circuit
  62、 薄膜:thin film
  63、 薄膜混合电路:thin film hybrid circuit
  64、 互连:interconnection
  65、 导线:conductor trace line
  66、 齐平导线:flush conductor
  67、 传输线:transmission line
  68、 跨交:crossover
  69、 板边插头:edge-board contact
  70、 增强板:stiffener
  71、 基底:substrate
  72、 基板面:real estate
  73、 导线面:conductor side
  74、 元件面:component side
  75、 焊接面:solder side
  76、 印制:printing
  77、 网格:grid
  78、 图形:pattern
  79、 导电图形:conductive pattern
  80、 非导电图形:non-conductive pattern
  81、 字符:legend
  82、 标志:mark
[/td][/tr][tr][td=2,1][/td][/tr][tr][td=2,1]
 楼主| 发表于 2008-8-29 09:32:12 | 只看该作者
印制电路词汇(2)
二、 基材:  1、 基材:base material
  2、 层压板:laminate
  3、 覆金属箔基材:metal-clad bade material
  4、 覆铜箔层压板:copper-clad laminate (ccl)
  5、 单面覆铜箔层压板:single-sided copper-clad laminate
  6、 双面覆铜箔层压板:double-sided copper-clad laminate
  7、 复合层压板:composite laminate
  8、 薄层压板:thin laminate
  9、 金属芯覆铜箔层压板:metal core copper-clad laminate
  10、 金属基覆铜层压板:metal base copper-clad laminate
  11、 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film
  12、 基体材料:basis material
  13、 预浸材料:prepreg
  14、 粘结片:bonding sheet
  15、 预浸粘结片:preimpregnated bonding sheer
  16、 环氧玻璃基板:epoxy glass substrate
  17、 加成法用层压板:laminate for additive process
  18、 预制内层覆箔板:mass lamination panel
  19、 内层芯板:core material
  20、 催化板材:catalyzed board ,coated catalyzed laminate
  21、 涂胶催化层压板:adhesive-coated catalyzed laminate
  22、 涂胶无催层压板:adhesive-coated uncatalyzed laminate
  23、 粘结层:bonding layer
  24、 粘结膜:film adhesive
  25、 涂胶粘剂绝缘薄膜:adhesive coated dielectric film
  26、 无支撑胶粘剂膜:unsupported adhesive film
  27、 覆盖层:cover layer (cover lay)
  28、 增强板材:stiffener material
  29、 铜箔面:copper-clad surface
  30、 去铜箔面:foil removal surface
  31、 层压板面:unclad laminate surface
  32、 基膜面:base film surface
  33、 胶粘剂面:adhesive faec
  34、 原始光洁面:plate finish
  35、 粗面:matt finish
  36、 纵向:length wise direction
  37、 模向:cross wise direction
  38、 剪切板:cut to size panel
  39、 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper ccl)
  40、 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper ccl)
  41、 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates
  42、 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates
  43、 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates
  44、 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates
  45、 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates
  46、 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates
  47、 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates
  48、 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates
  49、 超薄型层压板:ultra thin laminate
  50、 陶瓷基覆铜箔板:ceramics base copper-clad laminates
  51、 紫外线阻挡型覆铜箔板:uv blocking copper-clad laminates
 楼主| 发表于 2008-8-29 09:34:00 | 只看该作者
印制电路词汇(3)
三、 基材的材料  1、 a阶树脂:a-stage resin
  2、 b阶树脂:b-stage resin
  3、 c阶树脂:c-stage resin
  4、 环氧树脂:epoxy resin
  5、 酚醛树脂:phenolic resin
  6、 聚酯树脂:polyester resin
  7、 聚酰亚胺树脂:polyimide resin
  8、 双马来酰亚胺三嗪树脂:bismaleimide-triazine resin
  9、 丙烯酸树脂:acrylic resin
  10、 三聚氰胺甲醛树脂:melamine formaldehyde resin
  11、 多官能环氧树脂:polyfunctional epoxy resin
  12、 溴化环氧树脂:brominated epoxy resin
  13、 环氧酚醛:epoxy novolac
  14、 氟树脂:fluroresin
  15、 硅树脂:silicone resin
  16、 硅烷:silane
  17、 聚合物:polymer
  18、 无定形聚合物:amorphous polymer
  19、 结晶现象:crystalline polamer
  20、 双晶现象:dimorphism
  21、 共聚物:copolymer
  22、 合成树脂:synthetic
  23、 热固性树脂:thermosetting resin
  24、 热塑性树脂:thermoplastic resin
  25、 感光性树脂:photosensitive resin
  26、 环氧当量:weight per epoxy equivalent (wpe)
  27、 环氧值:epoxy value
  28、 双氰胺:dicyandiamide
  29、 粘结剂:binder
  30、 胶粘剂:adesive
  31、 固化剂:curing agent
  32、 阻燃剂:flame retardant
  33、 遮光剂:opaquer
  34、 增塑剂:plasticizers
  35、 不饱和聚酯:unsatuiated polyester
  36、 聚酯薄膜:polyester
  37、 聚酰亚胺薄膜:polyimide film (pi)
  38、 聚四氟乙烯:polytetrafluoetylene (ptfe)
  39、 聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene copolymer film (fep)
  40、 增强材料:reinforcing material
  41、 玻璃纤维:glass fiber
  42、 e玻璃纤维:e-glass fibre
  43、 d玻璃纤维:d-glass fibre
  44、 s玻璃纤维:s-glass fibre
  45、 玻璃布:glass fabric
  46、 非织布:non-woven fabric
  47、 玻璃纤维垫:glass mats
  48、 纱线:yarn
  49、 单丝:filament
  50、 绞股:strand
  51、 纬纱:weft yarn
  52、 经纱:warp yarn
  53、 但尼尔:denier
  54、 经向:warp-wise
  55、 纬向:weft-wise, filling-wise
  56、 织物经纬密度:thread count
  57、 织物组织:weave structure
  58、 平纹组织:plain structure
  59、 坏布:grey fabric
  60、 稀松织物:woven scrim
  61、 弓纬:bow of weave
  62、 断经:end missing
  63、 缺纬:mis-picks
  64、 纬斜:bias
  65、 折痕:crease
  66、 云织:waviness
  67、 鱼眼:fish eye
  68、 毛圈长:feather length
  69、 厚薄段:mark
  70、 裂缝:split
  71、 捻度:twist of yarn
  72、 浸润剂含量:size content
  73、 浸润剂残留量:size residue
  74、 处理剂含量:finish level
  75、 浸润剂:size
  76、 偶联剂:couplint agent
  77、 处理织物:finished fabric
  78、 聚酰胺纤维:polyarmide fiber
  79、 聚酯纤维非织布:non-woven polyester fabric
  80、 浸渍绝缘纵纸:impregnating insulation paper
  81、 聚芳酰胺纤维纸:aromatic polyamide paper
  82、 断裂长:breaking length
  83、 吸水高度:height of capillary rise
  84、 湿强度保留率:wet strength retention
  85、 白度:whitenness
  86、 陶瓷:ceramics
  87、 导电箔:conductive foil
  88、 铜箔:copper foil
  89、 电解铜箔:electrodeposited copper foil (ed copper foil)
  90、 压延铜箔:rolled copper foil
  91、 退火铜箔:annealed copper foil
  92、 压延退火铜箔:rolled annealed copper foil (ra copper foil)
  93、 薄铜箔:thin copper foil
  94、 涂胶铜箔:adhesive coated foil
  95、 涂胶脂铜箔:resin coated copper foil (rcc)
  96、 复合金属箔:composite metallic material
  97、 载体箔:carrier foil
  98、 殷瓦:invar
  99、 箔(剖面)轮廓:foil profile
  100、 光面:shiny side
  101、 粗糙面:matte side
  102、 处理面:treated side
  103、 防锈处理:stain proofing
  104、 双面处理铜箔:double treated foil
参与人数 1金币 +3 威望 +3 收起 理由
阿正 + 3 + 3 你太有才了
 楼主| 发表于 2008-8-29 09:34:50 | 只看该作者
印制电路词汇(4)
四、 设计  1、 原理图:shematic diagram
  2、 逻辑图:logic diagram
  3、 印制线路布设:printed wire layout
  4、 布设总图:master drawing
  5、 可制造性设计:design-for-manufacturability
  6、 计算机辅助设计:computer-aided design.(cad)
  7、 计算机辅助制造:computer-aided manufacturing.(cam)
  8、 计算机集成制造:computer integrat manufacturing.(cim)
  9、 计算机辅助工程:computer-aided engineering.(cae)
  10、 计算机辅助测试:computer-aided test.(cat)
  11、 电子设计自动化:electric design automation .(eda)
  12、 工程设计自动化:engineering design automaton .(eda2)
  13、 组装设计自动化:assembly aided architectural design. (aaad)
  14、 计算机辅助制图:computer aided drawing
  15、 计算机控制显示:computer controlled display .(ccd)
  16、 布局:placement
  17、 布线:routing
  18、 布图设计:layout
  19、 重布:rerouting
  20、 模拟:simulation
  21、 逻辑模拟:logic simulation
  22、 电路模拟:circit simulation
  23、 时序模拟:timing simulation
  24、 模块化:modularization
  25、 布线完成率:layout effeciency
  26、 机器描述格式:machine descriptionm format .(mdf)
  27、 机器描述格式数据库:mdf databse
  28、 设计数据库:design database
  29、 设计原点:design origin
  30、 优化(设计):optimization (design)
  31、 供设计优化坐标轴:predominant axis
  32、 表格原点:table origin
  33、 镜像:mirroring
  34、 驱动文件:drive file
  35、 中间文件:intermediate file
  36、 制造文件:manufacturing documentation
  37、 队列支撑数据库:queue support database
  38、 元件安置:component positioning
  39、 图形显示:graphics dispaly
  40、 比例因子:scaling factor
  41、 扫描填充:scan filling
  42、 矩形填充:rectangle filling
  43、 填充域:region filling
  44、 实体设计:physical design
  45、 逻辑设计:logic design
  46、 逻辑电路:logic circuit
  47、 层次设计:hierarchical design
  48、 自顶向下设计:top-down design
  49、 自底向上设计:bottom-up design
  50、 线网:net
  51、 数字化:digitzing
  52、 设计规则检查:design rule checking
  53、 走(布)线器:router (cad)
  54、 网络表:net list
  55、 计算机辅助电路分析:computer-aided circuit analysis
  56、 子线网:subnet
  57、 目标函数:objective function
  58、 设计后处理:post design processing (pdp)
  59、 交互式制图设计:interactive drawing design
  60、 费用矩阵:cost metrix
  61、 工程图:engineering drawing
  62、 方块框图:block diagram
  63、 迷宫:moze
  64、 元件密度:component density
  65、 巡回售货员问题:traveling salesman problem
  66、 自由度:degrees freedom
  67、 入度:out going degree
  68、 出度:incoming degree
  69、 曼哈顿距离:manhatton distance
  70、 欧几里德距离:euclidean distance
  71、 网络:network
  72、 阵列:array
  73、 段:segment
  74、 逻辑:logic
  75、 逻辑设计自动化:logic design automation
  76、 分线:separated time
  77、 分层:separated layer
  78、 定顺序:definite sequence
 楼主| 发表于 2008-8-29 09:35:54 | 只看该作者
印制电路词汇(5)
五、 形状与尺寸:  1、 导线(通道):conduction (track)
  2、 导线(体)宽度:conductor width
  3、 导线距离:conductor spacing
  4、 导线层:conductor layer
  5、 导线宽度/间距:conductor line/space
  6、 第一导线层:conductor layer no.1
  7、 圆形盘:round pad
  8、 方形盘:square pad
  9、 菱形盘:diamond pad
  10、 长方形焊盘:oblong pad
  11、 子弹形盘:bullet pad
  12、 泪滴盘:teardrop pad
  13、 雪人盘:snowman pad
  14、 v形盘:v-shaped pad
  15、 环形盘:annular pad
  16、 非圆形盘:non-circular pad
  17、 隔离盘:isolation pad
  18、 非功能连接盘:monfunctional pad
  19、 偏置连接盘:offset land
  20、 腹(背)裸盘:back-bard land
  21、 盘址:anchoring spaur
  22、 连接盘图形:land pattern
  23、 连接盘网格阵列:land grid array
  24、 孔环:annular ring
  25、 元件孔:component hole
  26、 安装孔:mounting hole
  27、 支撑孔:supported hole
  28、 非支撑孔:unsupported hole
  29、 导通孔:via
  30、 镀通孔:plated through hole (pth)
  31、 余隙孔:access hole
  32、 盲孔:blind via (hole)
  33、 埋孔:buried via hole
  34、 埋/盲孔:buried /blind via
  35、 任意层内部导通孔:any layer inner via hole (alivh)
  36、 全部钻孔:all drilled hole
  37、 定位孔:toaling hole
  38、 无连接盘孔:landless hole
  39、 中间孔:interstitial hole
  40、 无连接盘导通孔:landless via hole
  41、 引导孔:pilot hole
  42、 端接全隙孔:terminal clearomee hole
  43、 准表面间镀覆孔:quasi-interfacing plated-through hole
  44、 准尺寸孔:dimensioned hole
  45、 在连接盘中导通孔:via-in-pad
  46、 孔位:hole location
  47、 孔密度:hole density
  48、 孔图:hole pattern
  49、 钻孔图:drill drawing
  50、 装配图:assembly drawing
  51、 印制板组装图:printed board assembly drawing
  52、 参考基准:datum referance
发表于 2008-8-29 09:46:52 | 只看该作者
thank you very much !
发表于 2008-8-29 09:48:55 | 只看该作者
发表于 2008-8-29 10:24:50 | 只看该作者
发表于 2008-8-29 10:25:56 | 只看该作者
发表于 2008-8-29 10:27:17 | 只看该作者
GMT+8, 2026-11-30 16:44 , Processed in 0.030132 second(s), 19 queries , Gzip On.
