查看: 2424|回复: 11
package-drop test
发表于 2008-8-26 10:22:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Package Drop Test
• Number of samples required: One sample is required for the tests in this procedure.
The test drop height varies with the weight of the packaged-product. Find the weight of the packaged-product in the following chart to determine a drop height:
Packaged-Product Weight
Drop Height
Equal to or greater than
But Less than
Free Fall
lb
kg
lb
kg
In.
cm
0
0
21
10
30
76
21
10
41
19
24
61
41
19
61
28
18
46
61
28
100
45
12
31
100
45
150
68
8
20
The test method requires the packaged-product to be dropped in several different package orientations.
Sequence #
Orientation
Specific face, edge or corner
1
Corner
Any one of the eight corners
2
Edge
shortest edge radiating from the corner tested
3
Edge
next longest edge radiating from the corner tested
4
Edge
5
Face
one of the smallest faces
6
Face
opposite small face
7
Face
one of the medium faces
8
Face
opposite medium face
9
Face
one of the largest faces
10
Face
opposite large face
The packaged-product has satisfactorily passed the test if, upon examination, no more than 2% of the product is damaged.
发表于 2008-8-26 10:49:39 | 只看该作者
谢谢共享,不过每个公司或客人的要求都不太一样,我们公司的要求是25KG以下60CM一角六面,25KG以上45CM一角六面
发表于 2008-8-26 12:27:07 | 只看该作者
我们要求是六面三边一角的。
发表于 2008-8-26 13:51:04 | 只看该作者
但通常都不会从角开始的,因为伤害太大。
发表于 2008-8-26 14:57:23 | 只看该作者
不过建议还是从角开始.要知道,很多装卸工人到最后没体力了,摔箱起来厉害哦.呵呵
发表于 2008-8-26 21:48:35 | 只看该作者
i like english version of information,as i can learn a lot from it
发表于 2008-8-27 23:48:11 | 只看该作者
跌落根据不同的产品有不同的方式
发表于 2008-9-12 09:02:57 | 只看该作者
也是target的最新标准哦!厉害
发表于 2008-12-5 15:41:40 | 只看该作者
纸箱跌落测试
我公司跌落测试是连纸箱(卡通箱)跌1角3边6面,一般的玩具公司都是执行此标准.
发表于 2008-12-6 09:13:36 | 只看该作者
摔箱我们公司从来没做过,只做过空箱子的抗压
GMT+8, 2026-11-30 14:13 , Processed in 0.034464 second(s), 18 queries , Gzip On.
