查看: 2272|回复: 9
qc inspection tone
发表于 2008-8-20 16:15:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
collar 領
Unbalance collar 領不平衡
Asymmetric collar 領位不對稱
Uneven collar width 左右領闊不一致
Uneven neckline 左右領圈不一致
Uneven collar point 領尖不對稱
Uneven lapel shapes 左右前領咀形狀不一樣
Too much easing at C.F. neckline 前領口溶位太多(有太多溶位於前中領窩)
Collar too tight at CB 後領中太緊
Collar band is twisting 領座扭曲不平順
Fullness at front collar and lapel 領及前領咀不平順
Neckline is not smooth 領圈不圓順
Neck setting not smooth 領子裝得不平順
High & low back neck 後領圈有高低
Edge of front opening is crooked 前門領邊不直
Front opening not straight 前門領邊不直
Front facing is exposed at bottom hem 前門領貼在下擺處外露
Front opening facing is shorter than body 前門領貼短於大身
Neck was stretched 領圈拉松Too much tie on front collar 前領處有豁口
Sleeve & Armhole 袖&夾
Puckering at left/right armhole 左右夾圈有溶位不平伏.
Too loose at right armhole, uneven for left/right armhole 右夾圈有拉松, 左右夾圈不相稱.
Sleeve running to back(衣袖走後) / Sleeve running to front(衣袖走前) 操兵袖
Too loose at front sleeve seam 前袖骨拉松
Too tight at back sleeve seam 後袖骨過緊.
Poor cuff setting 卡夫裝得不好
Sleeve placket is not set well 袖叉裝得不好
Underarm seam was stretched 袖底縫被拉松
Armhole setting not smooth 袖孔不圓順
Ease on sleeve cap is uneven 袖頂縮拱不均勻
Front/back 前後幅
Hiking at front, CF facing too short 吊襟
Hiking at back, lining too short 吊裡
Curve at CF zip(too much fullness at CF zip) 前中拉鏈溶位太多
Curve at CF zipper because of no easing of zipper. 前中拉鏈無溶位(引致紐曲)
Hiking at back / Hiking at front 後幅吊起 / 前幅吊起
Front panel is bigger than under panel(lining) 前幅底幅細面幅松
Lining too big, too short, too small, too long 裡布太大, 太短, 太小, 太長
Grain lines are not match at front & back panel 前後幅布紋不相稱
Front length uneven 左右前長不一致
Too loose at shell, Too loose at back/lining, turn insider out 底松, 面鬆, 向外反
Hem 衫腳
Seam binding stitch tension is too tight, causing bottom not smooth. 下擺絲帶過緊, 使下擺不平順
Bottom hem is not in line / not straight. 下腳不夠不平(直)
Twisting hem, puckering at hem 下腳紐紋起豆角.
Uneven hem 左右下擺高低不一
Vent length uneven 左右開叉長短不一
Uneven leg length 長短腳
Uneven hem line 衫腳不平均 / 不對稱
Uneven hem 左右下擺高低不一
 楼主| 发表于 2008-8-20 16:16:56 | 只看该作者
Pocket 袋
High-low pocket 高低袋
Both pocket set uneven 左右口袋裝得高低不一
Pocket not smooth / squared 袋不平服/不夠正方
Pocket flap not centered over pocket 袋蓋不正中
Both pocket shapes are uneven 左右口袋形狀不一致
Bottom part of pocket is sagging 口袋下部下垂
Pocket flap is misplaced 袋邊位置不對
Pocket is misplaced 口袋位置不對
Pocket is smiling 袋口開得不吻合
Pocket opening is fray 袋口有毛口
Pocket shape distorted 口袋變形
Pocket size and shape is not follow sample exactly 口袋的尺寸及形狀未按照實樣做
Pocket welt is uneven 上下袋唇不均勻
Poor pocket setting 口袋裝得不好
Binding 拉捆
Piping is uneven 捆邊不均勻
Piping is twisting and not smooth 捆邊扭曲不平順
Pleats 縮褶
Uneven shirring at back waist seam後腰縮碎褶不均勻
Shirring 碎褶
Elastic shirring is uneven 橡筋縮拱不均勻
Both side pleats not balance 左右褶位不一致
Darts placement is not follow sample exactly 褶位未按照實樣做
Pleats is misplaced 褶位不對
Shirring / Gathering 縮褶
Pleated 生褶
Darts 死褶
Beading & embroidery 釘珠&繡花
Beads stitching are not secure 珠子未釘牢
Embroidery stitching is too tight 繡花線太緊
Embroidery stitching too loose 繡花線太松
SHADING DEFECTS 色差問題
1) Color shading 色差   2) Color shading within one garment. 同一件衣服內有色差。
3) Color shading between trims and body. 配件與衫身之間有色差。
4) Shade differs from approved standard. 顏色與批核色版不同。
5) Shading caused by poor color interlining matching. 紙朴顏色不配合, 引致色差。
ACCESSORIES 輔料問題
1) Missing button / label / badge 漏鈕 / 漏嘜頭 / 漏章
2) Button position not well match buttonhole. 鈕與鈕門位置欠配合
3) Button inside out 鈕的底面倒置
4) Button marking not removed. 點鈕筆痕沒有清除
5) Damaged button/buttonhole 鈕爛/爛鈕門
6) Rusted stud 工字鈕生銹
7) Paint peel off on stud 工字鈕顏色脫落
8) Button and buttonhole not aligned cause bulge. 鈕及鈕門位置不配合, 引致谷起
9) Buttonhole too small to allow button to pass through. 鈕門太細, 鈕不能順利通過
10) Uncut buttonhole / partially cut buttonhole 鈕門未幵 / 鈕門未開盡
11) Ragged edges at buttonhole 鈕門紗線不清
12) Broken buttonhole stitches 鈕門斷線
13) Button thread easily pulled out. 釘鈕線容易拉脫
14) Snap / rivet easily pulled off.吸鈕、撞鈕容易拉脫
15) Buttonhole is not match button size 鈕洞尺寸與鈕扣大小不相配
16) Button misplaced 鈕扣位置不對
17) Buttonhole misplaced 鈕洞位置不對
18) Button is not sewing security 鈕扣未釘牢
19) Button is sewn too tight 鈕扣釘得太緊
20) Buttonhole is fray 鈕洞有毛口
21) Key buttonhole density is too loose 鳳眼鈕洞的車縫線步太疏
22) Key buttonhole is misplaced 鳳眼鈕洞位置不對
23) Snap misplaced 揿鈕位置不對 24) Snap tape is misplaced 撳鈕扁帶位置不對
25) Snap tape setting not well 撳鈕扁帶裝得不好
26) There is bubble on buttonhole area 鈕洞周圍有氣泡
27) Hood and bar is misplaced 裙扣位置不對
28) Hole at zip top / end 拉鏈頂 / 尾有洞
29) Zipper setting is twisting 拉鏈裝得扭曲
30) Shoulder pad not attach to garment security 肩棉未釘牢
31) Shoulder pad not cover well 肩棉未包好
32) Velcro is misplaced 么朮貼位置不對
33) Waistband belt is not set straight 腰耳裝得不直
34) Waistband belt length and width are uneven 腰耳的長、寬不一致
35) Incomplete adhesive on interlining. 黏朴未完全黏好
36) Strike through of adhesive on interlining. 黏朴膠露面
37) Strike back of adhesive on interlining. 黏朴脫落
38) Blistering occurred on interlining. 黏朴起泡
39) Insecure shoulder pad attached. 肩棉釘縫不穩
40) Label placement incorrect. 嘜頭位置不正確
41) Care label content not as specified. 成份嘜內容不符合要求
42) Main label and size/content label are set too closed 主嘜與尺碼成份嘜裝得太靠近
43) Main label setting is misplace 釘主嘜不井齊
44) Wrong care label sewn on garment. 成份嘜車錯位置
45) Label not properly secured. 嘜頭車縫不穩
46) Label sewn beyond label edge. 嘜頭車縫太入
47) Label sewing seam uneven / puckered. 嘜頭車縫不平均或起皺
48) Wrong accessories used. 用錯輔料
Button out of line. 鈕位不成直線
STITCHING AND SEAMS 線步和骨位
1) Raw edge 散口
2) Raw edges 爆口
3) Untrimmed thread ends 線頭未剪
4) Skipped stitches 跳線
5) Exposed stitching 露線
6) Broken stitches 斷線
7) Run-off stitches 間線落坑
8) Crooked stitches 線步彎曲
9) Poor join stitching 駁線欠佳
10) Unsightly over-lapping stitches 駁線不良
11) Stitches too loose 線步太松
12) Stitches too tight 線步太緊
13) Distorted stitches 車線不直
14) Broken seams 縫線爆幵
15) Expose stitch 落坑線外露
16) Inconsistent stitching 線步不一致
17) Uneven width on double stitching 雙線闊窄不均
18) Uneven stitching density / tension 線步密度 / 鬆緊度不平均
19) 1/4 top stitch not even 1/4面線有寬窄
20) Expose safety stitch 保險線外露
21) Inseam is uneven 內縫線不井齊
22) Merrow stitch density is too big 撥邊線步太疏
23) Overlap stitch is not well 反縫的接線不好
24) Top & under stitch tension not match 底面線力不相符
25) Uneven merrow seam 內撥邊線彎曲不直
26) Missing reinforcement stitches 漏車加固線步
27) Row of stitching missing – top stitch 漏車一行線——平車線
28) Stitch count less than standard 線步較標準少
29) All top stitch is uneven 所有的面線都不均勻
30) Blind stitch is broken 筒針有斷線現象
31) Blind stitch is wavy 筒線彎曲不直
32) Shoulder seam not smooth 小肩縫彎曲不直
33) Uneven folded width at bottom sweep 1/2〞hemming. 折車1/2〞腳圍闊窄
34) Blind stitching visible 挑腳線露面
35) Incomplete seam stitching 線步不到尾
36) Uneven for hem closure stitching, uneven stitch at hem 下腳車線不直
37) Exposed waistband running stitches 裙頭/褲頭見坑線
38) Not straight at front fly 褲鈕牌車線不順直
39) Not straight at back yoke 後擔干車線不直, 紐曲
40) Skipping stitches, looping stitches 跳線, 車線太鬆起耳仔
41) Seam allowance, sewing thread too tight 子口補間線, 線太緊起豆角
42) Pleated seam 骨位打褶
43) Puckered seam 骨位起皺
44) Open seam 爆骨
45) Burst seam 爆骨
46) Under seam visible 底骨露面
47) Waviness on seams 骨位起波浪
48) Twisted seams / Seam rolling 扭骨
49) Twisting at side seam, Wavy at side seam 側骨紐, 不順直.
50) Seam closures uneven 骨位結尾不平均
51) Missing bar-tack 漏打棗
52) Seam not properly secured 骨位不牢固
53) Fullness on seams 骨位太谷, 不平伏
54) Seam not fully opened before stitching. 骨位未完全撥開間線
55) Cracked seam 骨位拉時有響聲(引致斷線)
56) Too loose at princess seam 前公主骨拉松起泡
57) Puckering at back princess seam 後公主骨溶位太多, 起皺/起豆角
58) Too tight or too loose at side seam. 側骨車線太緊或太鬆
59) Too loose at CF / CB seam 前中/後中骨太松
60) Too loose at shoulder seam, unbalance of front & back panel at shoulder seam 肩骨拉松(要落定位)
61) Too flat at shoulder seam, too slant of shoulder seam 肩骨太平/太斜
发表于 2008-8-20 19:54:04 | 只看该作者
thank you !
发表于 2008-8-21 22:32:36 | 只看该作者
资料不错,错在我不在服装这行业!!!!
发表于 2009-10-18 22:30:57 | 只看该作者
THANK U VERY MUCH
发表于 2009-11-15 17:45:33 | 只看该作者
Thank you for sharing.
发表于 2011-4-5 23:33:58 | 只看该作者
3Q~~~~~~~~~~~~~~~
发表于 2011-5-4 10:51:57 | 只看该作者
谢谢楼主分享
发表于 2011-5-4 11:48:22 | 只看该作者
很好很不错的东西,可惜我不懂服装
发表于 2011-5-6 18:48:07 | 只看该作者
Thanks for you sharing!
GMT+8, 2026-10-28 15:38 , Processed in 0.172666 second(s), 18 queries , Gzip On.
