查看: 1035|回复: 2
机电行业——水泵相关词汇
发表于 2008-8-20 11:08:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
obleque plate pump 斜板泵;
oil burner pump 燃油喷射泵;
oil cooler pump 油冷却泵;
oil diffusion pump 油扩散泵;
oil ejector booster pump 油喷射增压泵;
oil ejector pump 油喷射泵;
oil field pump 油田泵;
oil line pump 输油管线泵;管线泵;
oil pump 油泵;
oil refinery pump 炼油厂泵;
oil tanker‘s pump 油轮用泵;
oil vapour jet pump 油蒸汽喷射泵;
oppesed piston pump 对置活塞泵;
ordinary pump 通用泵;
ore washing pump 洗矿用泵;
oscillating displacement pump 往复泵;
paper stock pump 纸浆泵;
paramagnetic oxygen pump 顺磁性氧气泵;
partial emission pump 切线增压泵;部分流泵;
partial load pump (主机)部分负荷泵;
peak load pump 高峰负荷泵;
pedestal mounted pump 托架固定泵;
peripheral pump 旋涡泵;
peripherally ported radial piston pump 外配流径向活塞泵;
peristaltic pump 软管泵;蠕动泵;
petrol station pump 加油站泵;
petroleum pump 石油泵;
piezoelectric pump 压电泵;
pintle valve radial piston pump 轴配流径向活塞泵;
pipeline canned motor pump 管道屏蔽泵;
pipeline mounted pump 管道泵;
pipeline mounted pump with screwed connections 螺纹连接管道泵;
pipeline mounted pump with welded connections 焊接管道泵;
pipline pump 输油管线泵;管线泵;
pisitive displacement pump 容积泵;
piston diaphragm pump 活塞隔膜泵;
piston metering pump 活塞计量泵;
piston pump 活塞泵;
piston pump with rotary gate 回转滑阀活塞泵;
piston with shakeable cylinder 摆动缸活塞泵;
pit barrel pump 矿井筒袋泵;
pit pump 矿井泵;
pitot pump 斗式泵;皮托泵;
pivotal vane centrifugal pump 可调叶片离心泵;
planet rotor pelstaltic pump 行星转子型蠕动泵;
plastic lined pump 衬塑料泵;
plastic pump 塑料泵;
plunger metering pump 柱塞计量泵;
plunger pump 柱塞泵;
pneumatic pump 风动泵;
port plate axial piston pump 配流盘式轴向活塞泵;
portable canned motor pump 可携式屏蔽电泵;
portable fire (fighting)pump 可移式消防用泵;
portable pump 可移式泵;
positive rotary pump 回转容积泵;
power pump 动力往复泵;曲柄泵;
power station pump 电厂泵;
pressure oil pump 压力油泵;
pressure-balanced gear pump 压力补偿齿轮泵;
primary coolant booster pump 主冷却剂增压泵;
priming pump 起动用罐水泵;
process pump 流程泵;
product pump 产品泵;物料泵;
propeller pump 旋浆泵;
propeller pump with adjustable or variable pitch blades 可调式轴流泵;
propeller pump with reversible blades , 可逆叶片轴流泵;
proportioning pump 比例泵;
pull-out type pump 转子可抽出式泵;
pulp water pump 纸浆水泵;浆水泵;
pulsating (chamber) pump 脉冲容积泵;
pump for acid washing of boiler 锅炉酸洗泵;
pump for edible fluids 食品泵;
pump for liquid ls 液态金属泵;
pump for liquid salts 熔盐泵;
pump for pipe system 管网泵;
pump for water -borne solids 固体输送泵;
pump for with bearing bracket 轴承架固定式泵;
pump with bowl-type vaned casing 导流壳式多级泵;
pump with cyclic electromagnetic drive 电磁驱动泵;
pump with enclosed impellers 闭式叶轮泵;
pump with external bearing(s) 外轴承泵;
pump with internal bearing(s) 内轴承泵
pump with mechanical seal 机械密封泵;
pump with nonrotating cylinder 固定刚体泵;
pump with opposed impellers 相对叶轮泵;背靠背叶轮泵;
pump with overhung impeller 悬臂叶轮泵;
pump with series or parallel connection impellers 叶轮串并联泵;
pump with withdrawable rotor assembly 转子可抽出式泵
radial flow (centrifugal)pump 径流泵;
radial piston eccentric pump 偏心径向活塞泵;
radial piston pump 径向活塞泵;
radial piston pump with exterior admission 外配流径向活塞泵;
radial piston pump with interior admission 内配流径向活塞泵;
radial plunger pump 径向活塞泵;
radially split pump 分段泵;径向剖分泵;
ram pump 柱塞泵;
raw juice circulating pump 原汁循环泵;
raw juice pump 原汁泵;
raw liquor pump 粗糖泵;原液泵;
raw sewage pump 原生污水泵;
raw sludge pump 原生污泥泵;
raw water service pump 清水泵;供水泵;
reactor pump 反应堆泵;
reciprocating pump 往复泵;
reciprocating pump with counterrunning piston 对向活塞泵;
reciprocating pump with pistons in V-type arrangement V型活塞泵;
reciprocating pump with unidirectional piston 单向活塞泵;
recycle pump 再循环泵;
reflux pump 回流泵;
refrigerating medium pump 冷煤泵;
regenerative pump 旋涡泵;
resonance diaphragm pump 谐振隔膜泵;
return sludge pump 回流污泥泵;
reversible pump 可逆泵;
reversible screw pump 可逆式螺杆泵;
rocker arm pump 变行程往复泵;
rocking arm pump 杆式泵;
rocking pintle piston pump 扭转活塞泵;
roller pump 滚轮泵;
roller vane pump 转子滑片泵;
rolling piston radial pump 径向旋转活塞泵;
rolling vane pump 回转滑片泵;
Root‘s vacuum pump 罗茨真空泵;
rotaru piston pump with slide gate !pump 滑阀式回转活塞泵;
rotary meterring pump 回转式计量泵;
rotary piston libe type pump 罗茨泵;凸轮泵;
rotary piston pump 回转式活塞泵;
rotary plunger pump 回转式柱塞泵;
rotary pump 回转泵;
rotary vaccum pump 回转式真空泵;
rotary vaccum pump with liquid piston 液体活塞式转子真空泵;
rotary vane pump 回转式滑片泵;
rotary vane vaccum pump 回转式叶片真空泵;
rotary-block radial pump 缸体旋转式径向活塞泵;
rotary-displacement pump 回转式容积泵;
rotating vane pump 回转式滑片泵;
rotative reciprocating pump 曲柄泵;
rotodynamic pump 叶片泵;
rotoplunger pump 梭心转子泵;
rotor diaphragm pump 转子隔膜泵;
rotor pump 转子泵;
rubber lined pump 衬胶泵;
rubber lined vaccum 衬胶真空泵;
salvage pump 救助泵;
sand pump 沙泵;
sanitary pump 卫生泵;
scoop pump 斗式泵;
screw pump 螺杆泵;
screw pump with square thread 方形螺杆泵;
screw vane pump 螺旋形滑片泵;
sea water pump 海水泵;
sealed screw pump 密闭式螺杆泵;
sediment pump 沉积物泵;
seed(ing)sludge pump 腐泥引进泵;接种污泥泵;
segmental type pump 分段式多级泵;
self-filling pump 自灌泵;
self-priming pump 自吸泵;
self-priming pump with inner recirculation 内混合型自吸泵;
self-priming pump with outer recirculation 外混合型自吸泵;
self-priming pump with recirculation 混合型自吸泵;
semi-axial flow pump 混流泵;
semi-axial flow pump with adjustable or variable pitch blades 可调式混流泵;
semi-rotary(wing) pump 摆动泵;
separate valve box type piston pump 分置阀室式活塞泵;
service pump 值勤泵;
sewage broad irrigation pump 污水泛灌泵;
sewage irrigation spray pump 污水喷灌泵;
sewage pump 污水泵;
shaft pump 矿井泵;
shallow well pump 浅井泵;
ships pump 船用泵;
shuttle-block pump 梭心转子泵;
side channel pump 侧流道泵;
side pot type piston pump 分置阀式活塞泵;
side suction pump 侧吸 泵;
simplex power pump 单杠曲柄泵;
simplex steam pump 单杠蒸汽直动泵;
single (power)pump 单杠曲柄泵(美);
single (steam)pump 单杠蒸汽直动泵(美);
single action piston pump 单作用活塞泵;
single action vane pump 单作用滑片泵;
single cell vane pump 单作用滑片泵;
single channel impeller pump 单流道叶轮泵;
single cylinder (reciprocating) pump 单杠往复泵;
single entry pump 单吸泵;
single lobe pump 单凸轮泵;
single plunger pump 单柱塞泵;
single power pump 单杠曲柄泵(美);
single stage pump 单吸泵;
single steam pump 单杠蒸汽直动泵(美);
single suction pump 单吸泵;
 楼主| 发表于 2008-8-20 11:10:48 | 只看该作者
机电行业——水泵相关词汇2
sinking pump 吊泵;
skid mounted pump 撬式泵;滑移泵;
skirt mounted pump 灯笼架支承泵;
sliding vane pump 滑片泵;
sliding vane vacuum pump 滑片真空泵;
slipper pump 滑履式泵;
sludge liquor pump 浆液泵;污泥液泵;
sludge pump 污泥泵;
slurry pump 浆液泵;
smalll load pump (主机)低负荷泵;
soft rubber lined pump 衬软胶泵;
solid (handling)pump 固体输送泵;
sorption pump 吸收泵;
spare pump 库存泵;备用泵;
spary pond pump 喷淋池泵;
spary pump 喷洒泵;喷淋泵;
sprinkler system supply pump 消防喷淋系统供水泵;
spur gear pump 正齿轮泵;
square thread screw pump 矩形螺杆泵;
stage casing pump 分段式多级泵;
stainless steel pump 不锈钢泵;
standard pump 标准泵;
stand-by circulating pump 备用循环泵;
stand-by pump 备用泵;
starting up pump 起动用泵;
starting up stand-by pump 起动备用泵;
stationary pump 固定式泵;
steam jet pump 蒸汽喷射泵;
steam jet vaccum 蒸汽喷射真空泵;
steam pump 蒸汽泵;
stock drain water pump 纸浆废水泵;
stock water pump 纸浆稀释水泵;
storage pump 蓄能泵;
storm water pump 暴雨排水泵;
straight through type piston pump 直通活塞泵;
straight way type piston pump 直通活塞泵(美);
straw pulp pump 草浆泵;
stripping pump 扫仓泵;清仓泵;
sublimation pump 升华泵;提纯泵;
submerged pump 潜水泵;
submerged screw pump 潜液式螺杆泵;
suction booster pump 吸入增压泵;
suction box water pump 吸水箱水泵;
sudspump 冷却乳剂泵;肥皂液泵;
sugar liquor pump 糖汁泵;
sump pump 凹坑排水泵;
sundyne pump 切线增压泵;部分流泵;
super cavitation pump 超汽蚀泵;
supernatant liquor pump 清泥液泵;
super-pressure pump 超高压泵;
supersonic pump 超声速泵;
surface wash pump 表洗泵;
suspended pump 悬挂式泵;
suspension pump 悬浮液泵;
Sven-Pedersen pump 吸水箱水泵;
swash plate operated(reciprocating) pump 斜盘式(往复)泵 ;
swing gate piston pump 摆阀式活塞泵;
swinging vane pump 摆动滑片泵;
syrup(extraction) pump 糖浆泵;
tailings pump 尾矿泵;
tank drainage pump 罐柜抽泄泵;
tank residue pump 油罐残油泵;
tanker pump 油罐车泵;
tannery fleshings pump 鞣革液泵;
telemotor pump 伺服系统油泵;
ther‘moelectromagnetic pump 热电磁泵;
thick sludge pump 沉积物泵;
three cell vane pump 三作用滑片泵;
three channel impeller pump 三流道叶片泵;
three cylinder reciprocating pump 三缸往复泵;
three lobe pump 三叶凸轮泵;
three screw pump 三螺杆泵;
three throw crank pump 三缸曲柄泵;
three throw reciprocating pump 三缸往复泵;
tilting cylinder block type axial plunger 斜缸型轴向柱塞泵;
titanium alloy pump 钛合金泵;
top inlet pump 顶端吸入泵;
top return pump 回流泵;
top suction pump 顶端吸入泵;
torque flow pump 旋流泵;土拉泵;
tractor pump 拖拉机泵;
transportable pump 可移式泵;
trapezoid screw pump 梯形螺杆泵;
treble ram pump 三柱塞泵;
trench pump 基坑排水泵;
trimming pump 纵倾平衡泵;
triple plunger pump 三柱塞泵;
triplex pump 三缸曲柄泵;
trochoid rotor pump 次摆线转子泵;
trochoid screw pump 次摆线螺杆泵;
tubewell pump 管式深井泵;
tubular type axial flow pump 管流泵;直管轴流泵;
turbine driven pump 汽轮机驱动泵;
turbine feed pump 汽轮机直联给水泵;
turbine pump 泵-水轮机;
turbine pump with reversible blades 叶片可逆转的泵-水轮机;
turbo pump 叶片泵;
turf pump 泥煤泵;
Turo pump 土拉泵;旋流泵;
turret type piston pump 阀箱式活塞泵(美);
twin cylinder reciprocating pump 双缸往复泵;
twin lobe pump 双凸轮旋转活塞泵;
twin vane pump 双滑片泵;
two cell vane pump 双作用滑片泵;
two cylinder reciprocating pump 双缸往复泵;
two diaphragm pump 双隔膜泵;
two rotor radial piston pump 双转子径向活塞泵;
two screw pump 双螺杆泵;
two stage pump 两级泵;
ultrahigh vacuum pump 超高真空泵;
unchokeable pump 不堵塞泵;
unit construction pump 直联泵;
universal pump 通用泵;
vacuum displacement pump 容积式真空泵;
vacuum pump 真空泵;
valve box type piston pump 阀室式活塞泵;
valve deck plate type piston pump 阀板式活塞泵;
valve plate axial piston pump 配流盘式轴向活塞泵;
valve plate type piston pump 阀板式活塞泵(美);
valve spindle radial piston pump 轴配流径向活塞泵;
valve type piston pump 阀形活塞泵;
valveless diaphragm pump 无阀隔膜泵;
valveless pump 无阀活塞泵;
valveless vibration pump 无阀振动泵;
vane pump 叶片泵;
variable area ratio jet pump 变量喷射泵;
variable capacity pump 变量泵;
variable capacity screw 变量螺杆泵;
variable output pump 变量泵;
variable reluctance motor pump 可变磁阻电动机泵;
variable speed pump 变速泵;
variable stroke reciprocating pump 变形程往复泵;
vertical barrel pump 立式筒袋泵;
vertical mounted pump 立式框架固定泵;
vertical process pump 立式流程泵;
vertical pump 立式泵;
vertical turbine pump 深井泵;
viscose spinning pump 纺丝泵;
volute pump 涡壳泵;
vortex pump 旋涡泵;
vortex pump with open impeller 开式旋涡泵;
vortex pump with shrouded impeller pump 闭式旋涡泵;
v-type piston pump V型活塞泵;
vuel oil transferpump 燃油转送泵;
walking beam pump 杆式泵;
wall mounted pump 壁式泵;
warm water pump 温水泵;
washery pump 清洗泵;
washing pump 清洗泵;
waste paper pulp pump 废纸浆泵;
waster water 污水泵;
water conveying pump 供水泵;
water jet propulsion axial flow pump 喷水推进轴流泵;
water jet pump 水喷射泵;
water pump 水泵;
water ring pump 水环泵;
water ring vaccum pump 水环真空泵;
water service pump 自来水泵;
water supply pump 供水泵;
wear resisting pump 耐磨泵;
Westco pump 旋涡泵(美);
wet motor pump 湿式电动机泵;
wet pit pump 湿坑泵(美);
wet sump pump 湿坑泵;
wet vacuum pump 湿式真空泵;
wheel and bucket pump 斗轮水车;戽斗水车;
windmill (driven) pump 风车驱动泵;
wobble plate axial piston pump 斜盘式轴向活塞泵;
wood pulp pump 木浆泵;
wood stock pump 木浆泵
发表于 2008-8-20 19:03:14 | 只看该作者
thank you very much !
GMT+8, 2026-12-1 00:22 , Processed in 0.029378 second(s), 18 queries , Gzip On.
