查看: 897|回复: 5
纺织面料验货英语大全
发表于 2008-8-20 06:34:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
成品检验Checking of finished products
    检验,检查inspection, check
    商检commodity inspection
    领面松wrinkles at top collar
    领面紧top collar appears tight
    领面起泡crumples at top collar
    领外口松collar edge appears loose
    领外口紧collar edge appears tight
    底领伸出collar band is longer than collar
    底领缩进collar band is shorter than collar
    底领里起皱wrinkles at collar band facing
    底领外露collar band lean out of collar
    倘领偏斜collar deviates from front center line
    领窝不平creases below neckline
    后领窝起涌bunches below back neckline
    驳头起皱wrinkles at top lapel
    驳头反翘top lapel appears tight
    驳头外口松lapel edge appears loose
    驳头外口紧lapel edge appears tight
    驳口不直lapel roll line is uneven
    串口不直gorge line is uneven
    领卡脖tight neckline
    领离脖collar stand away from neck
    小肩起皱puckers at shoulders
    塌肩wrinkles at shoulder
    袖隆起皱creases at underarm
    袖隆缝起皱puckers at underarm seam
    塌胸lack of fullness at chest
    省尖起泡crumples at dart point
    拉链起皱wrinkles at zip fly
    止口不直front edge is uneven
    止口缩角front edge is out of square
    止口反翘front edge is upturned
    止口反吐facing leans out of front edge
    止口豁split at front edge
    止口下部搭叠过多crossing at front edge
    底边起皱wrinkles at hem
    后身起吊back of coat rides up
    背衩豁开split at back vent
    背衩搭叠过多crossing at back vent
    绗棉起皱puckers at quilting
    絮棉不均padded cotton is uneven
    边缘缺棉empty hem
    绱袖不圆顺diagonal wrinkles at sleeve cap
    袖子偏前sleeve leans to front
    袖子偏后sleeve leans to back
    前袖缝外翻inseam leans to front
    袖口起皱wrinkles at sleeve opening
    袖里拧diagonal wrinkles at sleeve lining
    袋盖反翘top flap appears tight
    袋盖反吐flap lining leans out of edge
    袋盖不直flap edge is uneven
    袋口角起皱creases on two ends of pocket mouth
    袋口裂split at pocket mouth
    腰头探出end of waistband is uneven
    腰缝起皱wrinkles at waistband facing
    里襟里起皱creases at right fly
    夹裆tight crotch
    短裆short seat
    后裆下垂slack seat
    前浪不平wrinkles at front rise
    裆缝断线bursting of crotch seam
    裤脚前后two legs are uneven
    脚口不齐leg opening is uneven
    吊脚pulling at outseam or inseam
    烫迹线外撇crease line leans to outside
    烫迹线内撇crease line leans to inside
    腰缝下口涌bunches below waistline seam
    裙裥豁开 split at lower part of skirt
    裙身吊split hem line rides up
    裙浪不匀skirt flare is uneven
    线路偏移stitch seam leans out line
    双轨接线 stitch seam is uneven
    跳针 skipping
    尺码不符 off size
    缝制不良stitching quality is not good
    洗水不良washing quality is not good
    熨烫不良pressing quality is not good
    极光iron-shine
    水渍water stain
    锈迹rust
    污渍spot
    色差color shade, off shade, color deviation
    褪色fading, fugitive color
    线头thread residue
    毛头raw edge leans out of seam
    绣花不良embroidery design out line is uncovered
发表于 2008-8-20 07:19:42 | 只看该作者
楼主真厚道,直接把这么有用的资料帖上来,谢谢你的热情
发表于 2008-8-26 21:27:55 | 只看该作者
有用!!!顶
发表于 2008-8-27 09:25:00 | 只看该作者
很好,喜欢,多多益好
发表于 2009-9-20 14:02:58 | 只看该作者
厚道的楼主,谢谢分享
发表于 2010-1-2 13:02:26 | 只看该作者
dddddddddddddddddddd
GMT+8, 2026-11-5 02:18 , Processed in 0.212752 second(s), 19 queries , Gzip On.
