楼主: kangqinjun
出门验货被工厂打了怎么办呀。
31#
发表于 2008-8-18 01:43:14 | 只看该作者
我曾经一挑4
我去厂里,他们都怕我
被打了以后,最好的办法就是
花钱找人,把打你的人的鸡鸡砍掉
你们老大收了钱,当然不会帮你说话
最好的办法就是,投奔我
32#
发表于 2008-8-18 08:09:57 | 只看该作者
有这样的老板,坚决打击.
33#
发表于 2008-8-18 08:36:03 | 只看该作者
这样的工厂是太过分了,应该从严处理!
34#
发表于 2008-8-18 08:55:28 | 只看该作者
这种事直接搞到你们老板那里去啊,不用怕他了。想办法把工厂搞关门好了。把工厂的名字和地址放到网上让各位抵制他们。
35#
发表于 2008-8-18 12:02:12 | 只看该作者
靠,工厂不好,你老大也成了拥凶!可恶!
这样的工厂还能有订单?这样的老大还能做上司?
搞不懂!
36#
发表于 2008-8-18 12:10:08 | 只看该作者
这样的工厂还要跟她做?我是第一当时报警,第二等公司的老大过来看,三在工厂不走。
工厂还能把你杀了你不成。反正款还在自己公司手上,搞也要搞死他
37#
 楼主| 发表于 2008-8-18 17:49:30 | 只看该作者
回复 31# neverust 的帖子
兄弟哪里的,不介意我就来投奔你,只怕你不敢收我
38#
 楼主| 发表于 2008-8-18 17:56:42 | 只看该作者
我们的单子是下给镇海香海日用品厂的,可是这个工厂没办法做,他们又拿到另一个工厂去做的,那天香海的人把我送过去就走了,就我一个人在那里验货,打我都是在验好了之后发生的,是因为拍了两张照片,真是晕呀,对了,下次你们去镇海瑞旺日用品厂可一定不要一个人去,太危险了,我们公司现在每次去都两人过去,我看其他公司也从来没有一个人去他那里验货的,都是两个以上,听说这家工厂老板有一次把一个验货的腰都打断了,太可怕了
39#
发表于 2008-8-18 18:45:55 | 只看该作者
回复 1# kangqinjun 的帖子
Felt sorry at the case, but such case would never happen on me.
How do you look at the factory and the goods you inspected? Whatever you are, trading company QC or ISP QC, you should have the knowledge that your salary basically came from the goods you inspected. Accordingly, you should have given highest respect  and best care to the goods you inspected. How came that when the rain was coming imminently but you still had the goods exposed outside??!! And, it was at least part of your attendence that those cartons were damaged by the rain, how came that you just took photos to shrug off possible problems without the least consultation with the factory to seek for any possible remedy - to replace the damaged cartons, or even suggest short shipment to the factory??!!How long have you worked in this line? your tutor did not reminded you this?
You should have called your superior to advise the situation and ask for instructions, anyway, your inspection was over.
Forgive my strong words. I used to work in factory, and then as QC. This is a good lesson to you. Maybe you can call the guy who beat you and apologize. That is difficult to you, but helpful for your improvement.
40#
发表于 2008-8-18 19:42:55 | 只看该作者
lz回答上面的
GMT+8, 2026-11-7 00:21 , Processed in 0.027501 second(s), 15 queries , Gzip On.
