查看: 884|回复: 5
Inspection of Baby Jogger
发表于 2008-5-28 15:41:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Inspection of Baby Jogger2.        INSPECTION CRITERIA
Packaging, marking, labeling, illustration and instruction.- d' S( F" b  Q) T4 y0 q
2.1.1        All the packaging material should be new, not damaged nor soaked.6 x5 |" P2 R$ N% d2 F: R( q9 s
2.1.2        The packaging material can protect the goods from damage during
Transportation. (ISTA test)
2.1.3        The shipping mark, label (such as price label), hangtag. etc should conform to client’s spec and/or approved samples.
The printing and colour must conform to client’s specification   [3 Z) p9 {& o+ k2 F% N* Y' e- U
and/ or approved sample and in good quality." B2 Y2 W: m* |% H
, n' t3 ~2 c$ Y9 q4 N0 X) r) |
The relevant legal marking and warning must be presented legibly and correctly on the individual packaging and/or product according to the regulation of the importer’s country such as country of origin …etc.* f, q) e: Z9 r5 V+ R. O
! N7 Z: e4 ?  o( \/ ?& E) U  u& j
2.1.5        Text of illustration, instruction and warning must be in user’s language. (in English for USA user)* g7 ]( p  w& v) H, x, ]- b8 t
2.1.6        The illustration and instruction on the packaging must conform to the product and its actual performance.
2.1.7        The barcode on the packaging and product must be correct and scannable.
2.1.8        Stickers should be applied straight and no air pockets under stickers.; x5 l0 e6 ?7 A  l# i; ?
2.2        Product& H* A& W2 v& w/ p$ T
2.2.1        Aesthetics / Workmanship check on Level ll( F  E0 R; w+ l( J2 |+ J; I+ n
•        Correct shape, size and colour9 r+ O: `) g1 c; X( o7 L/ L7 K( z* l" D! b
•        Decoration such as painting, tempo, silkscreen printing, and electro - plating must be in good quality, correct color and located correctly.' \3 r/ V. j1 p; f8 W. R' [& J, z
•        No sharp point and edge
•        No rust or corrosion) h; w8 K1 q) a7 G9 j6 h- O* h; v6 S
•        Moulding defect such as sink mark, flow line, white mark should be limited to minimum* s; A" P$ U2 n
•        The screw, nail must be secured firmly. No loosen/ missing screws or nails.
•        The parts must be assembled together firmly and correctly.; M! D! \$ x; v- g
•        No dirt, stains or contamination
•        Push handles should not be deformed, broken, cracked or flash, and can not move or rotate.& T/ p7 Z# V+ s7 u9 B
•        Canopy and seat should be tightly fit with frame, operated easily and smoothly. Color and printing on fabric of canopy and seat should match with each other and conform to reference sample. Canopy and seat should be free of poor sewing, loose stitch, untrimmed long thread end, broken, open seam, and jump stitch.5 \! t- F' p* K  F0 R# y
•        No broken needles or metal slivers are in fabric.
•        Seat must be held firmly in position.
•        Strap should be correct width and length. And strip twists are unacceptable.0 @! [$ A$ r6 ?
•        Buckle should be at correct position, and not reversed, cracked or broken.
•        Color and size of all metal tubes should conform to reference sample.1 G2 N  p4 T0 W2 v4 r  V5 D
•        All hard components should be free of scratches, dent marks, cracks, flash, sharp point, hard burr. Metal parts should be free of sharp edge.
•        All wheels should not be slant assembled.& Q) X. O; x) E6 h4 N+ O* i0 O
0 G! S# E$ e( S; N/ M: i' D1 i: I) ^
2.2.2        Functional check
•        Straight line moving test (Roll Test) conducted on1 out of every 15 units: the distance of 10 feet movement shall not be greater than 2 inch, or a distance of 20 feet shall not deviate over 4 inches.0 v: q# i- l+ V) o0 {7 {2 Q" p
•        100 lb. Load test conducted on 1 out of every 15 units.
•        Check function of rotation locks of the wheel on all sample size., g( q& x1 l" i6 A
•        Check the wheels assembly, too tight or loose is unacceptable.
•        Buckle functional check for 3 times, too tight, loose is unacceptable, white mark is not allowed after the test.
•        All tubes should be protected firmly with cap at ends. 7 T' D! l" V; \' f' l9 Y
•        Pull Test of safety strap and attachments to ASTM standards
 楼主| 发表于 2008-5-28 15:59:23 | 只看该作者
3.        DEFECT CLASSIFICATION LIST
Note: Not limit to but only for your reference and according to above definition for standard reference
3.1        Master carton, product packaging (such as gift box, blister card.,polybag.etc)%
- Broken /torn        Major
- Wet        Major
- Creased / wrinkle                                                Major/Minor
- Scratch/ abrasion                                                 Major/Minor
- With odor                                                        Major
- Poor sealing/ gluing                                                Major
- Substandard packaging material, can’t protect the          Major
- Over size or under size                                        Major
- Incorrect colour / printing                                        Major/Minor
- Poor printing (color shade, white spot, off register. Etc)        Major
- Incorrect quantity or assortment of product                           Critical
- Polybag dimensions/thickness/ warning statement/Air   Major
      hole not conform to standard
3.2        Marking, Labeling, illustration and instruction.
-Incorrect / missed shipping mark                                Major
-Incorrect / missed price label/ hang tag...etc                Major
-Misleading/ incorrect product description, illustration         Critical
(including photo on the packing) instruction.:
-Missed / incorrect legal statement/ warning such                 Critical
as CE mark, country of origin. etc., according to the
relevant safety standard and other regulation
- Instruction sheet missed                                         Major
- Illegible marking                                                Major
- Marking/ label incorrect located                                 Major4
- Missed/ incorrect/ unscannable / damaged barcode          Major
3.3        Aesthetics, workmanship, function, safety and reliability
- Size / shape/ colour/ material not conform to                 Major
specification
- Sharp point, sharp edge                                        Critical
- Rust /corrosion                                                Major
- Intermittent function                                                Critical
- No function                                                        Critical
- Function not as per illustration or instruction                Major
- Missed / loosen screws                                        Critical
- Printing off register                                                Major
- Untrimmed flash / burr                                Critical
- Painting over-spray/ under-spray                                Major/Minor
- Label peel off                                                Major/Minor
- Parts loosen or detached (not small part)                        Major
- Missing parts                                                        Major
- Crack, chip                                                        Major
- Broken                                                        Major
- Dirt /stain                                                        Major/Minor
- Molding defect: sink mark, white mark, flow line.etc      Major/Minor
- Any stitching defect                                                             Major / Minor
- Loose push handle – can be moved or rotated                   Major
-- Canopy / seat loose                                                             Critical
- Canopy / seat can not or difficultly be assembled to frame Major
- Mis-match color of fabric                                                      Major
- Broken needle or similar metal parts in fabric                      Critical
- Strip twist        Major
- Loose wheel        Critical
- Wheel can not touch ground (gap over 1.5mm)                   Major
- No function or malfunction of rotation lock                           Critical
- No function or malfunction of buckle                                    Critical
- Buckle broken, crack                                                            Critical
发表于 2008-5-29 09:39:27 | 只看该作者
全英文的看的好辛苦,有中英文对照就好了
发表于 2008-5-29 09:43:56 | 只看该作者
thanks for posting
发表于 2008-5-29 10:07:36 | 只看该作者
have a look!
发表于 2008-7-10 14:03:30 | 只看该作者
饮水思源,感谢大哥
GMT+8, 2026-9-17 02:14 , Processed in 0.047964 second(s), 18 queries , Gzip On.
