查看: 634|回复: 1
雅思学习
发表于 2008-5-14 22:54:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
语法复习必备:20分钟搞定定语从句
一、在英文中,名词或名词短语主要充当四种成分,主语、宾语、表语和同位语。
  如果我们把句子当作名词来使用,分别在另一个句子中作主语、宾语、表语和同位语(见下表第二列),于是就构成了四种从句:主语从句、宾语从句、表语从句和同位语从句。因为以为这四种从句在本质上相当于名词的作用,所以我们把他们统称为名词从句。请看例句:
  二、三种句子来充当四种成分。(3,4)
  上面说到名词从句就是用一个完整句子充当另一个句子的某种句子成分便构成了具体某一名词从句。那么可以用什么样的句子来充当四种成分呢?答案是:
  三、陈述句可分别充当四种句子成分(名词从句的重点内容),要在陈述句首加上他that。
  对于陈述句,我们要在句首加上that,然后把“that+陈述句”分别放在另一个句子的四种位置即构成四种名词从句。
  1.主语从句。“that+陈述句”在主语位置即成主语从句:
  Stuart is ugly.
  That Stuart is ugly is a fact..
  That Malaysians don’t speak good English is obvious.
  更常见的是用it式主语置于句首,而将主语从句放在句末。例如:
  It is a fact that Stuart is ugly.
  It is obvious that Malaysians don’t speak good English。
  因此下面都是常见的主语从句句型:(¥)
  ①It is +过去分词 +that 从句(found, believed, reported, thought, noted…)
  ②It is +形容词 +that 从句(clear, possible, likely, natural, certain, fortunate, necessary, strange…)
  ③It is +名词(短语) +that 从句(a pity, a shame, an honor, a good idea, a miracle…)
  2. 宾语从句。“that+陈述句”在宾语位置即成宾语从句:
  I think (that) you turned off the light.
  We know (that) women love shopping.
  She believed (that) her child was premature.
  只有宾语从句中的that才可以省去,其他名从that不省。
  3.表语从句。“that+陈述句”在表语位置即成表语从句:
  My idea is that the students should be more open to each other.
  The reason is that he was careless and irresponsible.(考点)
  4.同位语从句。“that+陈述句”在同位语位置即成同位语从句:
  所谓同位语,就是用来补充说明名词的成分。
  The rumor that Tom washed his socks once a month turned out to be untrue.
  Our fathers brought forth upon this continent a new nation, conceived in liberty and dedicated to the proposition that all men are created equal.
  A saying goes that tomorrow is another day.
  四、一般疑问句可分别充当四种句子成分。1、一般疑问句语序变成陈述语序。2、用来whether或if引导。
  1.主语从句: does she love dog-walking?
  Whether she loves dog-walking or not is unknown.
  2.宾语从句:
  I don’t know if/whether whether she loves dog-walking
  3.表语从句:
  My concern is whether you are a student or not.
  4.同位语从句:
  They are faced with the problems whether they should continue to play.
  补充:if whether区别
  1)if一般用于引导宾语从句,而whether可引导所有名词从句
  If he comes or not makes no difference.
  The question is if he will arrive.
  2)if 不和or not直接连用,一般不说 if or not。但可以说 if … or not 。而whether没有此限制。
  I don’t know if or not he arrives.
  I don’t know whether or not he arrives.
  五、特殊疑问句可分别充当四种句子成分。特殊疑问句变成陈述句语序。
  There arose the question where we could get the loan.
  I have no idea what gender he is.
  Why he refused to cooperate with us is still a mystery.
  I don’t know how many letters I have written to her.
  NBA is what I am crazy about.
  How China should develop next is a serious problem.
  Excuse me, can you tell me where the post office is?
  My question is where we are going to have our holidays.
  The point is whose book is the most horrible.
  Whoever comes will be welcomed.
  Whatever is left over is yours
  Do whatever you please.
  Read whichever books you please.
  I'll give it to whichever of you wants it.
  P.S. 最后说明:同位语从句多用that引导,少用whether, if以及代词或副词引导,因为我们多是用陈述句补充名词的内容,而少用一般疑问句或特殊疑问句来补充名词的内容。
  温故知新:名词从句就是用三种句子来分别充当另外一个句子的四种句子成分。
  三种句子:
  四种成分:
  这三种句子不是直接放在另个句子中作成分,而是要做以下调整:
  1)用陈述句作成分时,要在句首加
  2)用一般问句作成分时,先将疑问句换成语序,然后在句首加
  3)用特殊问句作成分时,只需将疑问句换成 语序。
  下面是95年1月份的阅读真题,来感受下几个难句吧,若搞定名词从句,那它们也就是小儿科。
  It is a curious paradox that we think of the physical sciences as “hard”, the social sciences as “soft,” and the biological sciences as somewhere in between. This is interpreted to mean that our knowledge of physical system is more certain than our knowledge of biological systems, and these in turn are more certain than our knowledge of social systems. In terms of our capacity of sample the relevant universes, however, and the probability that our images of these universes are at least approximately correct, one suspects that a reverse order is more reasonable
 楼主| 发表于 2008-5-14 22:56:17 | 只看该作者
雅思听力Sentence completion六大攻略
从近几年的雅思命题趋势来看,主观类题目,如 sentence completion/ multiple choice with more than one answer/ labeling 等正成为主导题型,其中最常见就是sentence completion,今天就和大家聊一聊该类题型的六点注意事项。
  攻略一:预测敌情
  很多烤鸭其实不是听不懂,只是出题的地方没有听到,而没有出题的地方反而听的很清楚,这种情况最为令人depressed,我称这种烤鸭是“死的冤枉”!因为大家会发现听第二遍的时候好像一切都变的再清晰不过了,但是一切都太晚了!
  所以第一步就是要预先判断需要听懂什么,判断需要填入的单词是什么词性、什么范围。例如: There are many kinds of bicycles available:
  racing
  touring
  (11)___________________
  ordinary
  看到这个题目,大家应该马上就应该判断,这通常应该填入一个单词,而且是一种类型的bicycle。
  攻略二:严阵以待
  其实烤鸭们会发现,即使是判断对了方向,有时候也是做不对题目,就是一眨眼的瞬间答案就过去了,我们的烤鸭们好像还没有准备好!通常我会建议烤鸭们一步步进入战备状态,并战略性的舍弃某些阵地。例如:
  Well, last week we talked about buying camping equipment and today I.d like to talk to you about buying a bicycle. A simple enough exercise, you might imagine, but there are lots of things to look out for to make sure you get the best deal for your money. Well, the range of bicycles is enormous . there are racing bikes, touring bikes, mountain bikes or just plain ordinary bikes for riding round town.
  听到第二个well之前,各位只需要处于警界状态,可以适当休息;当听到well 这个单词时,请进入一级战备状态,细心听下面的内容;听到 racing bikes 进入二级战备状态,随时准备书写;听到了mountain bikes,进入作战状态,将mountain 这个单词记在脑海中,立即书写,此时建议可以放弃后面的8-10词左右的内容,即,可以放弃一个分句,当然有时候可以放弃更多的内容。这样做的原因很简单:因为第二道题目不可能马上就会出现。完成这题后,等待第二道题目的出现,“警界—— 一级准备—— 二级准备——作战 —— 警界”如此循环往复,一切都那么轻松自然!
  攻略三:围而不歼
  众多烤鸭之所以最终被烤焦,往往时因为没有大局观,过分“贪功”,恨不得一次将敌人吃掉。这样做的后果往往是会贻误战机,最终难以实现全胜!
  假设现在第一道题目我们已经知道答案是“mountain”,我们面临两个选择:一是写完每一个字母;而是只写开头结尾,做好标记,“围而不歼”,等待时机!现在立刻赶向下一道题目。
  例如:mountain 可以简写成 “mou….n”、“mout…”、“m…n”等形式,前提条件是自己能够认出来,过一会回来还可以“歼灭”这道题目。
  攻略四:避重就轻
  在雅思考试中,有时候为了打乱烤鸭们答题的节奏,我们发现命题者会把在两道题目中间留下较短的调整空间。如果你不幸遇到了这种题目,在此劝告烤鸭可以战略性地放弃其中一道题目,因为事实上这种题目绝大部分的烤鸭都是做不出来的。这时候烤鸭应该告诉自己,如果可以做对其中一道题目,已经算是不错了。
  So I would tend to recommend the ten speed bike as the price is similar. Q17 However, you'll be getting better quality components. Q18
  Ten speed bike are better because they are (17) ______________________ in price but (18) ______________________.
  上面这道题目,我们发现第17题和第18题之间的距离非常近,所以在实战中我们发现很多的烤鸭事实上是没有时间对第18题做出反应的。不少烤鸭因此自乱阵脚,后面的第19题和20题也因此收到影响,本来可以得到的分数也白白丢掉了。
  攻略五:紧扣重点
  假设现在已经听不太懂了,只是零星听懂一些,我们应该怎么办呢?
  Wilson 建议烤鸭将听到的重读的和重复的答案都在一边稍微记录一点,然后看哪一个词可以填到题目中;如果不确定应该把记录好的单词填进哪一道题目中,请将所有没有填好的题目都写上这个词,最低可以保证有一道题目是对的。
  例如:Contrary to what you might imagine, the size of the cycle is not determined by the size of the wheels (except in children's cycles), but by the size of the frame. So Q20 you'll need to measure the length of your legs and arms to get a frame that is the right size for you.
  The size of the bicycle is determined by the size of the (20) ______________,
  在上面一题中,我们可能没有听懂整个这几句话的意思,但是大部分考生其实是听到了frame这个单词两次的。如果烤鸭们当时把这个单词记录下来了,我们会发现把frame 填写进去还是非常合适的,而答案恰恰就是frame!
  攻略六:最后一击
  现在录音已经放完了,但是你仍然有两个空不知道该怎么填?现在是否要放弃呢?还是要死马当作活马医,做出最后一击呢?
  Wilson 建议使用常识做最后的努力,例如:
  They vary in price and (12) ______________________.
  诸位烤鸭,大家是否可以猜出来这题的答案呢?自行车有很多种类,他们在价钱和……上有所不同,请问答案是什么?Wilson 相信很多的烤鸭都会很自然地想到“质量”这个常识,碰巧答案就是“quality”!
  Wilson 在这里提醒大家雅思考试考的就是国外生活、工作和求学的基本常识,所以大家一定要相信自己的判断,有很多时候我们会惊讶地发现其实答案是非常明显的。
  有了以上这六招处理sentence completion 的技巧,相信大家不会再害怕这种题型了。Wilson 建议大家做题的时候一定要很清楚的知道题目可能出现的方式,知道自己应该如何应对,所谓知己知彼,百战百胜也就是这个道理!
GMT+8, 2026-11-30 15:48 , Processed in 0.028827 second(s), 19 queries , Gzip On.
