查看: 1034|回复: 0
内衣厂常用英语
发表于 2008-4-7 16:39:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
中文 英文
1/2腰圍(放鬆度) 1/2 Waist length (relaxed)
  Waist on half
  1/2 Elasticatied waist
1/2腰圍平度 Waist flat on half
1/2腰圍(拉度) 1/2 Waist elastic strength
  1/2 Front waist elastic strength
  Waist stretch
  Waist extended
  Waist min stretch
1/2腳圍(下腳闊) 1/2 Bottom width
坐圍 Hip circle at top of leg
  Hip across top of leg
坐圍彎度 1/2 Hip (folded meas.)
1/2脾圍不計側繩 1/2 Thigh length excl. side elastic (side string)
1/2脾圍 1/2 Thigh (edge to edge)
  Leg on half
  Leg opening 1/2
1/2脾圍放鬆度 Leg flat - relaxed on 1/2
1/2脾圍放鬆度 1/2 Leg circumference
1/2脾圍拉度 Leg extended on 1/2
1/2脾圍拉度 Leg stretch
1/2脾圍(直度) Leg drop (straight line)
1/2脾圍穿起計右邊,放鬆度 1/2 Thigh length band - right side worn,relaxed
脾圍 Leg circle
脾圍放鬆度 Leghole relaxed
脾圍不連側繩 Thigh length (excl. waistband)
前幅褲脾長 Front leg length
前花邊長 Front EMB leg
前幅褲腳長連浪 Front leg flat incl. gusset
前褲腳長至骨位穿起計左邊 Back thigh length to seam - left side worn
後褲腳長至骨位穿起計左邊 Front thigh length to seam - left side worn
前中長彎度至花邊牙底 Front height - fold along edge / low scallop
前中長彎度(包褲頭丈巾) Front height - fold along edge (incl. Waistband)
  Frontlength incl. WB
前中長(彎度,連綑條)(連浪) Front height (curved,incl. binding)(incl. Crotch)
前中連底浪 Front length + Gusset length
前中長至前浪 C/F rise to front gusset
前中彎度 Centre front length (curve measured)
  Front rise cf to back gusset seam
  Front rise (folded meas.)
前中長包褲頭巾 CF to gusset (incl. W/B)
後中長變度 Back height - fold along edge
  Back rise including waist band
  Back rise (folded meas.)
後中長包褲頭巾 CB to gusset (incl. W/B)
後中長(彎度,連綑條) Back height (cureved,incl. binding)
後中長至前浪 Back rise to front gusset
後中長平度 Back centre length (plane)
後中丈巾長 Back string length cut at
後繩長(不連吊飾) Back length (excl. motif)
前浪闊 Front gusset width
前浪闊-沿骨度(連丈巾) Front crotch width - along seam (incl. Elastic)
前浪骨闊(連丈巾) Front crotch seam width (incl. Elastic)
前浪闊(後浪骨上10cm處) Front crotch width (10cm up from back crotch seam)
前浪闊(浪骨上11.5cm處) Front seat width (11.5cm up from crotch seam)
  Measure 11.5cm up from gusset
前浪闊褲頭落15cm處 Gusset width front 15cm fr to
前幅褲頭落11cm處 Across front 11cm fr to
後浪闊 Back gusset width
後浪闊-沿骨度(連丈巾) Back crotch width - along seam (incl. Elastic)
浪闊(度最窄位) Gusset width - narrowest
後幅闊浪上12cm處度 Back width 12cm abv gusset
後帶距(後幅最窄位) String width back
褲頭至後帶距長 Length to string
底浪長彎度 Crotch length - fold along edge
浪長 Gusset length
側骨 Side height / side depth
  Side height depth
  Sideseam fr. Upper edge
側骨包褲頭巾&綑條 Side length (incl. W/B & trim)
前幅褲頭長 Front panel width
前幅褲頭長(不連側繩) Front waist width (excl. side rope)
後幅褲頭長 Back panel width
褲頭繩長(打結後) Waist string length (after knots)
側繩長 Side waistband length / side string length
’’ Side rope length
兩側位丈巾長 Length of side rouleaus cut at
側丈巾帶長 Tanga sides finished
側繩長7cm回帶後 Side elastic length w/7cm loop
前側繩長(綁帶) Front side string length
後側繩長(綁帶) Back side string length
褲側綁帶長 Side strap length
前帶長(穿起計左邊) Front belt length (left side as worn)
前帶長(穿起計右邊) Front belt length (right side as worn)
前腰帶長 Front belt length
前三角闊 Front triangle width
前三角高 Front triangle height
綑邊丈巾闊 Foldover binding width
中文英文
下腳全長至第一勾圈Base length total band incl 1st hook
''Underbust up to 1st hook
''Underband 1st hook to 1st eye
''Chest underbust length(from hook to first eye)
''Total length to 1st hook & eye
''Finished base (to C.B. raw edge)
下腳長不計扣Bottom band excl. fasteners
下腳長至第一勾圈放鬆度Bottom rlx. F. hook to first eye
''Underband relaxed (hook to 1st set eyes)
下腳長從頭到尾Chest relaxed edge to edge
下腳全長(不連勾圈)Total base(inside edges of hook & eyes)
''Under chest length
下腳全長至第一勾圈拉度Base length strung incl 1st hook
''Underband extended (hook to 1st set of eyes)
下腳脾位長Back base length band
''Half back
''Bottom wing from side
''Bottom of wing
下腳脾位長不連勾圈Base of backs(inside edge of hook&eyes)
下脾長拉度Bottom wing stretch
雞心闊連鋼支Width between cups incl. wires
上雞心闊Top gore width
''Centre front width
''Top of CF
''Gradle width (at top)
''Topline of centre front
''Centre front at top
上雞心闊連鋼支Between wires at top including casing
雞心頂闊(不包鋼支)(上)Top yoke width (upper)
上雞心至杯邊距(雞心放落位置)Drop at centre front
下雞心闊Bottom gore width
''Bottom centre width
''Bottom of CF
''Base of centre front
雞心底闊(不包鋼支)(下)Bottom yoke width (lower)
雞心(CF)高Gore height
雞心高(不包丈巾度)Centre front height (excl. band)
''Centre front depth
''Length at front
''Gap heigth
''Gradle high
杯邊長連/不連綑碗Neckline length-incl./excl. wire
杯邊長連鋼支Neckline edge including wire
''Cup topline(incl channelling)
杯邊長不連鋼支Finished topline(excl. C.F. wire casing)
''Top cup edge (excl wire casing)
上碗邊長Upper cup length
''Top cup edge width
''Cup side length
''Upper cup edge
''Apex to centre front
杯闊(不連鋼支)Cup width (excl. wire)
''Horizontal cup (excl, wire)
上杯高Upper cup height
''Upper vertical cup
''Top cup depth / height
下杯高Lower cup height
''Lower vertical cup
''Bottom cup depth / height
''Undercup height
杯高(夾碗骨長)連/不連綑碗Front cup depth-incl./excl. wire
杯高Cup (seam) height
杯高Overcup
杯高不邊綑碗Vertical cup excl. wire
杯骨長Cup seam length
''Cup width at seam
''Over bust seam
''Seam cup width
''Across cup on seam
杯骨長不連鋼支Over cup seam width (excl. wire casing)
杯骨長連鋼支Cup depth on seam including wire
杯扎長Dart length
三角杯高Cup triangle high
拉上脾長連/不連綑碗Armhole length-incl./excl. wire
拉上脾全長不連勾圈Total underarm & back topline
 (from cup apex to inside edge on hook & eye)
''Finished u/arm + back (excl. hook & eye)
拉上脾長不計丈巾Top wing not incl. Strap
拉上脾長連捆條Top of wing (incl. Binding)
上脾長連綑碗Under arm wire to centre back
上脾長(鋼支至搭帶位)Wire seam to back strap
夾位長Underarm cup side length
''Arm edge length
''Apex to wire
夾位長連綑碗Underarm to wire
側脾高Side height
''Length at sideseam
''Side depth
''Side height under arm
''Wing height
側脾高(靠鋼支位度)
駁脾高(沿鋼支位度),不計丈巾牙)Around wire to wing join (not incl. Elastic scallope)
前肩帶長Front shoulder strap length
前肩帶長(成品)(布部分)Front strap length (finished) (fabric part)
後肩帶長7cm回帶後Back shoulder strap elastic length w/7cm loop
後肩帶長(成品)Back strap length (finished)
花邊肩帶長(成品)Shoulder strap (lace)
肩帶全長(拉盡扣成品)Shoulder strap (full length)
肩帶成品長Elastic strap max. length
肩帶長不計5cm回帶Strap length with 5cm adjustment
肩帶長包5cm回帶Elastic strap (finish between ring & slider 5cm)
後肩帶落帶距Distance between strap & hook
''Back strap to centre back
前肩帶落帶距Distance between strap & wire
後帶距(不連肩帶及勾圈)Back strap position (excl. hook & eye)
搭帶成品長(不包勾圈)Apex to back strap
半月紗長連鋼支Half moon lining length incl. wire
下雞心至脾位距(沿鋼支度)Around exposed wire from bottom of CF to wing join
勾圈闊Hook band heigth
''Hook & eye tape
肩帶闊Elastic strap width
鋼圈套長"外度"邊至邊Channel length at outer edge
鋼圈套長Around wire
鋼圈套長打棗至打棗Around wire bar tack to bar tack
鋼圈套長(每邊0.5CM虛位)Length around wire casiing(wire play 0.5CM each side)
鋼支虛位Wire play
鋼支型號Wire reference
鋼支長Wire length
鋼支闊Cups width
膠片闊Rubber widths
圈扣闊S/Strap rubber width
捌扣上圈闊Top wing rubber
捌扣下圈闊Bottom wing rubber
GMT+8, 2026-11-4 11:30 , Processed in 0.027708 second(s), 19 queries , Gzip On.
