查看: 896|回复: 6
Standard tests for Inspection
发表于 2008-4-2 23:22:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. Introduction:
During a Quality Inspection, you will have to do aprecise number of tests defined in your Inspection Protocol to checkthe quality of the inspected product.
You will find below the list of the tests that you will have to do during most of the Inspections.
2. Definition of tests:
Every test that you should do will be written in your Inspection Protocol in the part ”.
Some of the test in the Inspection Protocol can beconsidered as standard test because they will be carried out in most ofthe Inspections. Here is a description completed with some pictures foreach one of these tests:
- Function test:
For this test you will have to check if the productworks under normal use and if none of the function of the product hasproblems.
Example: for a lamp, you should turn on and off the light. For a MP3, you should try to transfer and listen music, etc…
- Carton drop test:
This test is performed to check if the cartons protect enough the products.
To do so you need to throw on the floor a required number of cartons (number defined in the Inspection Protocol).
Please refer to the lesson "How to perform Carton Drop test" for more details.
- Abusive test:
This test determines if the product can withstand an abusive use.
Example: for a textile product like a bra, you have to pull on the straps. For a DVD, you have to distort it, etc…
- Fatigue test:
Example: for a product with a push-button, you have to push on it. For a textile product with a zipper, you have to open and close it. The number of times, you need to do so will be defined in the Inspection Protocol.
发表于 2008-4-3 08:28:13 | 只看该作者
发表于 2008-4-5 20:33:11 | 只看该作者
回复 #1 HQSASD 的帖子
Thank you very much!
发表于 2008-4-5 22:00:25 | 只看该作者
it's great goods
发表于 2008-4-8 10:04:48 | 只看该作者
要是再详细一些就更棒了!!!
发表于 2008-5-7 14:55:24 | 只看该作者
Thanks you for your inpection procedure.
发表于 2008-5-8 00:05:13 | 只看该作者
学习学习
GMT+8, 2026-10-18 01:09 , Processed in 0.030776 second(s), 19 queries , Gzip On.
