查看: 1667|回复: 11
Shoes QUICK TESTS FILE
发表于 2008-4-2 01:32:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
B
1 - Prove that colors are in keeping with order
NB
2 – The leather has not pipey grain : to fold several time the shoe
the material mustn’t mark the leather in permanent way
NB
3 – The lining doesn’t discolour : rub the slightly wet thumb on the lining
B
4 – the top piece is well cemented to the heel ==> try to turn it
B
5 – The marking must be like as it has been asked by the quality and looks like the same as the production
B
6 – The tongue is durably stitched ==> pull the tongue : it must be ok
NB
7 – the stitching is durable
==> a good tension of the thread
NB
8 – There’s no iron on the eyelets, hooks and rings ==> test it with a magnet : the accessories mustn’t be attracted
B
9 – the eyelets are well tight ==> don’t be able to cross the finger nail below
B
10 – the upper is well stuck at the sole ==> pull the sole
NB
11 – no big tracks of glue on the upper
B
12 – The insole must be well stuck, in exception of the removable insole
B
13 – No detail bthering inside the shoe : no remaining nail of the lasting ==> to touch the inside of the shoe with hand
B
14 – Verify the solidity of the cursor, for a zip ==> twist the cursor to verify its solidity
NB
15 – for a moccasin ==> verify that the hand stitching is well stopped : pull on the apron to make a tension
Do not forget to refer to you to your specification book to remember yourselves the procedures.
发表于 2008-4-9 15:32:45 | 只看该作者
good.thank you
发表于 2008-4-13 10:50:40 | 只看该作者
suppor t
发表于 2008-5-6 16:00:45 | 只看该作者
很实用的方法,谢谢lz
发表于 2008-5-6 16:23:08 | 只看该作者
THANKS!!!
发表于 2008-5-6 20:56:17 | 只看该作者
很实用的方法,谢谢
发表于 2008-5-7 23:52:25 | 只看该作者
THANK YOU FOR SHARING
发表于 2008-5-12 15:46:05 | 只看该作者
不错,
发表于 2008-6-10 14:49:28 | 只看该作者
thank you very much
发表于 2015-11-20 15:01:46 | 只看该作者
:victory::victory::victory:
GMT+8, 2026-11-4 08:25 , Processed in 0.034743 second(s), 17 queries , Gzip On.
