查看: 3676|回复: 14
如何验厂 HOW TO AUDIT FTY FOR SA8000
发表于 2008-4-1 22:04:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1Introduction:
During a SocialAudit, you will have to assess different criteria such as Safety, Hygiene,Child labor, etc… tt in thefactory. The aim of this lesson is to define clearly how to give a proper resultconcerning all these domains.
2. How to rate aSocial Audit:
Please find below themost important points that you should consider for every criteria so that youcould rate them properly:
2.1 Safety:
- Fireequipment:
When you check the fire detection system of a factory, pleasecheck what kind of equipment it is. Indeed you have three kinds of detectors:smoke, heat, and some which detect both. The last ones are the best, so youshould consider this in your score.
The fire detectionsystem should be often checked to be sure that it could be effective in case ofemergency so ask the factory how often they check it. If it less than once a year, the score should not bemore than 3.
Evacuationexits are useless without evacuation instructions or evacuation signage because in case ofemergency they will not know where to go so it means that the score for “Evacuation exit” can not be more than 2without evacuation instructions or evacuation lightning.
Please don't forgetto check the shape and content of evacuation instructions. If they are clearly not readable (for example, if the paper isused-up), the score for this criteria should not be higher than 1. If there is noevacuation plan, the score should not be higher than 2.
The factory shouldhave 2 evacuation exits per floor. Ifthe factory has only one, the scoreshould be of 2 and if they don’t have any at all, it should be 0.
When you check extinguishers, you should absolutely check the limit date because if it is expired, the equipments are useless sothe score for this point should not be higher than 1.
The previous remarkis also available for fire hoses. Don’tforget to check that there is no missing component on it (for example, thehose…). If you find any component missing,the score should not be higher than 1.
The workers training should be notified in anotebook and the company should be able to show it. In this paper, you shouldfind the signature of every worker included in this training. If the factorysays that their workers are trained about fire emergency but can not show the proof on a paper with signatures,the score should not be higher than 1. Inthis case, please talk about this during the worker’s interviews. You shouldalso check what kind of training have been performed by the employees and howmany people did it. If less than 25% of the totalnumber of employees, had one training, the score should not behigher than 2. If the employees did nothave a practical training but only a theoretical one,the score should not be higher than 1.
- Toxicproducts:
It is very importantthat you check this point by yourself and not only ask to the factory ifthey have some toxic product and if they say no, assess it with the maximalscore. Indeed, most of the time, the factory will say that they don’t use anytoxic whereas they do, so you will have to lookand search around you everywhere.
To know if a productis toxic, you can refer to the pictures and sentences written on the productlabel. Please, read it carefully, if you have any doubts.
You will have toassess every kind of toxic product separately. To do so, you should considernot only how and where the products are storedbut also their handling conditions.
For example, ifpeople use a corrosive product without gloves,the score should be 0.
发表于 2008-4-1 22:54:35 | 只看该作者
多谢LZ!  提供全点啊
发表于 2008-4-2 11:51:53 | 只看该作者
SA8000 是什么东西?
发表于 2008-4-2 15:11:30 | 只看该作者
有没有全套的啊,好象只有一部分
 楼主| 发表于 2008-4-2 23:12:20 | 只看该作者
HOW TO AUDIT FTY FOR SA8000 CONTINUE
:vict
Machinery and heavy equipment:
You should reference every heavy equipment in the factory and mention their model and number. It is very important so that if the client wants to find out some information about one of this equipment, he could do it easily.
If you find security instructions but that they are clearly never read by the workers (for example, if they are stored in a closet instead of the working site) or that you can see that they are obviously not applied (for example, if it written to wear gloves and that nobody does it), the score should not be higher than 1.
Every heavy machine where the operator should use his hands to set it in motion with a hazard of compressing or wounding should have a double switched operating system. If you do not find it for at least one machine that required it, the score should not be higher than 1.
When you count the number of employees per operating machine, you should not refer to what the factory said but count it by yourself.
As for the fire emergency training, if the factory can not show a written proof with signature of trained workers and the date, even if they say that they trained their workers, the score should not be higher than 1. Please also, talk about this during the interviews.
According to your previous experiences and knowledge, you should know what kind of protective equipment should be used by workers. If, you find that less than 50% of workers use protective equipment whereas they should, the score should not be higher than 2. If you find that less than 25% of workers use protective equipment whereas they should, the score should be 0.
Don’t forget that you should only assess protective equipment that should be used by the workers. It means that, for example, if they don’t have to wear helmets, you should delete this from the report and modify the general score according to this. You should NOT assess it to a score of 5.
- Electrical installation:
When you check the date of installation and date of review, you should not only ask to the factory but always look what is written on the installation’s label and only believe it.
If the electrical installation is reviewed less than once a year, the score should not higher than 1.
When you check the isolation of electric parts, you should check that there is no damage and that no one could have access to hazardous parts. You should also take a look at their general shape. Indeed, if you find a lot of rust or dust, it means that nobody is taking care of it so the score should not be higher than 2.
You should have at least one circuit-breaker per floor. If not, the score should be 0.
2.2 Health and Hygiene:
- Medical care:
If medical equipments are not checked at least every year, the score should not be higher than 1.
If you find less than one first aid kit for 200 employees, the score should not be higher than 2. Don’t forget to check the content of first aid kits, if you find any empty bottles or some products with an outdated limit date, it means that they are useless and so the score should not be higher than 1.
If there is no sick bay or medical service in the factory, it means that every emergency in case of injury can not be resolved on the working site, so the score should be 0.
- Commodities:
When you check drinkable water spots, don’t forget to check the water supplying. If there is less than another reload of water, the score should not be higher than 1. Don’t forget to also check if workers can have hot or cold water.
When you check worker’s bedrooms, you should notify how many people are slipping in the same bedroom and the approximate number of square meters. If you find less than 5 square meters per worker, the score should be 0.
You also need to check their bathrooms and toilets. Please consider the general shape. For example, if you find that it is not clean and that people can not flush, the score should not be higher than 1. Please also check if people can access to hot water in the bathrooms. If they can not, the score should not be higher than 2.
If they do not have any kitchen or canteen, the score should be 0.
2.3 Child labor and forced labor:
For every part, where you need to check labor, please read and refer carefully to the corresponding SA 8000 extract that you can find in your protocol.
- General questions:
For all questions about child and forced labor, you should notify the opinion according to the management but most of all according to the workers.
For example, If the management says that there is no one working under the legal age but you find someone doing it, the score should be of course 0.
When you can, if you find different opinion between management and workers, try to find some written proofs.
For example, if the management says that the workers should not deposit their ID but the workers deny it, you should check the employee register or ID of employees to try to find some proofs.
In every case, if there is an opinion’s difference between management and workers, you should always consider the staff’s opinion as true, except if you find a proof that contradict it.
发表于 2008-4-3 14:52:38 | 只看该作者
谢谢
发表于 2008-4-3 20:22:46 | 只看该作者
楼主,好象还是不全哦
Franklai 该用户已被删除
发表于 2008-4-21 17:21:40 | 只看该作者
多谢楼主的用心了,分享学习了。
sujun9504 该用户已被删除
发表于 2008-4-22 12:35:03 | 只看该作者
学习了解中,知识共享,谢谢楼主
发表于 2008-4-27 17:14:15 | 只看该作者
最好有中文的啊
GMT+8, 2026-11-17 17:43 , Processed in 0.028481 second(s), 19 queries , Gzip On.
