查看: 1081|回复: 3
拉链知识英语
发表于 2007-7-17 22:02:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1, 闭口拉链: closed –end zipper
2, 开口拉链: open –end zipper
3, 双拉头拉链: zipper with double sliders
4,树脂拉链: resin teeth zipper
5, 尼龙拉链: nylon teeth zipper
6, 隐形拉链: invisible zipper
7, 黄铜拉链: brass teeth zipper
8, 镍齿拉链: nickel teeth zipper
9, 青铜拉链: bronze teeth zipper
10, 古铜拉链: antique brass teeth zipper
11, 铝齿拉链: aluminum teeth zipper
12,树脂银齿拉链:resin silver teeth zipper.
TYPES OF ZIPPER
The type and name of zipper is given on the basis of the material used in zipper teeth.
拉链类型主要由拉链牙的材质决定
Teeth size is expressed by #3-#10 and onwards. #3 representing smaller size teeth and #10 the larger.
牙的尺寸通常是3号-10号,数字越小,尺寸越小。
♂ PZlastic zipper 塑料拉链
♂ CZolyester zipper, coil zipper (previously known as Nylon zipper) 聚酯拉链,尼龙拉链
♂ MZ:Metal zipper 金属拉链
G.K. : Antique Brass Zipper 古铜
G.B. : Golden Brass Zipper 金色 铜
AL : Aluminium Zipper 铝
NI : Nickel Zipper 镍牙
2. FUNCTION :功能
O (O/E) : OPEN-END 开尾拉链
C (C/E) : CLOSED-END 闭尾拉链
M (2WAY) : 2WAY OPEN END 双向拉链
Example :
♂ PZC#5 : Plastic zipper no. 5, closed-end
♂ PZM#8 : Plastic zipper no. 8, 2way open-end
♂ GKO#5 : Metal, Antique Brass no. 5, open-end
Open-end zippers are generally used in the front of garments Closed-ends in pockets, hoods, legs of garments
开尾拉链通常用在衣服的前面,而闭尾的则用在口袋、帽子或是裤子的腿部
POSITION OF SLIDER :拉链头的位置
L/S : Left slider (same as R/H-Right hand). Means-When a jacket is opened the slider remains at the left side of the user.
左拉头(留在穿着者衣服的左侧)
R/S : Right slider (same as L/H-Left hand) 右拉头(同理)
Use : L/S -- in Europe and Asia both by male and female
(在欧洲和亚洲,男女都适用)
-- in USA. generally female 美国,女性
R/S -- in USA, Canada, South American countries ets. generaly male
美国、加拿大通常是男性服饰适
发表于 2007-8-6 17:29:14 | 只看该作者
大哥,我还能回贴不?
发表于 2008-8-31 21:27:46 | 只看该作者
不错~~~~~~~~~~~~~~~~~~
发表于 2008-8-31 22:37:42 | 只看该作者
辛苦了,谢谢分享,,
GMT+8, 2026-11-4 10:15 , Processed in 0.095026 second(s), 18 queries , Gzip On.
