查看: 2169|回复: 16
验货用语资料
发表于 2008-3-6 14:37:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
成品检验Checking of finished products
检验,检查inspection, check
商检commodity inspection
领面松wrinkles at top collar
领面紧top collar appears tight
领面起泡crumples at top collar
领外口松collar edge appears loose
领外口紧collar edge appears tight
底领伸出collar band is longer than collar
底领缩进collar band is shorter than collar
底领里起皱wrinkles at collar band facing
底领外露collar band lean out of collar
倘领偏斜collar deviates from front center line
领窝不平creases below neckline
后领窝起涌bunches below back neckline
驳头起皱wrinkles at top lapel
驳头反翘top lapel appears tight
驳头外口松lapel edge appears loose
驳头外口紧lapel edge appears tight
驳口不直lapel roll line is uneven
串口不直gorge line is uneven
领卡脖tight neckline
领离脖collar stand away from neck
小肩起皱puckers at shoulders
塌肩wrinkles at shoulder
袖隆起皱creases at underarm
袖隆缝起皱puckers at underarm seam
塌胸lack of fullness at chest
省尖起泡crumples at dart point
拉链起皱wrinkles at zip fly
止口不直front edge is uneven
止口缩角front edge is out of square
止口反翘front edge is upturned
止口反吐facing leans out of front edge
止口豁split at front edge
止口下部搭叠过多crossing at front edge
底边起皱wrinkles at hem
后身起吊back of coat rides up
背衩豁开split at back vent
背衩搭叠过多crossing at back vent
绗棉起皱puckers at quilting
絮棉不均padded cotton is uneven
边缘缺棉empty hem
绱袖不圆顺diagonal wrinkles at sleeve cap
袖子偏前sleeve leans to front
袖子偏后sleeve leans to back
前袖缝外翻inseam leans to front
袖口起皱wrinkles at sleeve opening
袖里拧diagonal wrinkles at sleeve lining
袋盖反翘top flap appears tight
袋盖反吐flap lining leans out of edge
袋盖不直flap edge is uneven
袋口角起皱creases on two ends of pocket mouth
袋口裂split at pocket mouth
腰头探出end of waistband is uneven
腰缝起皱wrinkles at waistband facing
里襟里起皱creases at right fly
夹裆tight crotch
短裆short seat
后裆下垂slack seat
前浪不平wrinkles at front rise
裆缝断线bursting of crotch seam
裤脚前后two legs are uneven
脚口不齐leg opening is uneven
吊脚pulling at outseam or inseam
烫迹线外撇crease line leans to outside
烫迹线内撇crease line leans to inside
腰缝下口涌bunches below waistline seam
裙裥豁开 split at lower part of skirt
裙身吊split hem line rides up
裙浪不匀skirt flare is uneven
线路偏移stitch seam leans out line
双轨接线 stitch seam is uneven
跳针 skipping
尺码不符 off size
缝制不良stitching quality is not good
洗水不良washing quality is not good
熨烫不良pressing quality is not good
极光iron-shine
水渍water stain
锈迹rust
污渍spot
色差color shade, off shade, color deviation
褪色fading, fugitive color
线头thread residue
毛头raw edge leans out of seam
绣花不良embroidery design out line is uncovered
发表于 2008-3-7 22:35:53 | 只看该作者
服装的  谢谢LZ
发表于 2008-4-2 12:45:23 | 只看该作者
没有工具方面的英语吗?非常的期待的,
发表于 2008-4-2 15:12:40 | 只看该作者
兄弟有没有家具的啊。
 楼主| 发表于 2008-4-3 14:31:00 | 只看该作者
家具木材词汇
AAbele银白杨
Abnormal wood 异常(木)材
Acoustic acid board 吸音纤维板
Acoustical board 吸(隔)音板
Adjustable template 可调节的样板
Adult wood 成年材
African blackwood 非洲黑木黄檀
African ebony 非洲乌木
African mabogany 非洲桃花心木
African padauk 非洲紫檀
Aging 老化,陈化
Air drying 大气干燥
Air seasoning 天然干燥
Alaska fir 阿拉斯加冷杉木
Alaska yellow cedar
阿拉斯加柏木Alder 赤杨类
American ash 美国白蜡木
American beech 美国山毛榉
American eim 美国榆,白榆
American plane 美国悬铃木
American tulipwood美国鹅掌揪
Annual ring 年轮
Apron 望板
Armor-plywood 金属贴面板
Arris 棱
Artificial slabs人造板
Artificial timber 人造木材
Ash 白蜡木
Aspen 白杨类
BBabool 阿拉伯胶树
Back 背板Back board背板
Back veneer 衬板
Bald cypress 落羽杉
Bamboo 竹子
Basswood 椴木,美国椴木
Batten board 条板心细木工板
Beech 山毛榉木
Beech parquet 山毛榉拼花地板
Bent wood (弯)曲木
Birch 白桦,
Birdseye maple雀眼枫木板
Block 塞角
Block floor 拼花地板
Blockboard 细工木板
Board 板材
Bottom 底板
Bowing 顺弯
Branch wood 枝条材
Brazilian mahogany 巴西桃花心木
Bright sap 净面边材,无皮边材
Broad leaf wood 阔叶材,硬材
Brown ash 美国深色白蜡木
Burl 树疤,树瘤
CCaul 垫板,衬板
Cedar 雪松,杉木
Ceylon ebony乌木
Cherry 樱桃木
Chile pine 智利松
Chinese chi (中国)漆树
Chip 木屑# 1 common 普一级#2
common 普二级compreg 胶压木
compressed wood 压缩木
coniferous species 针叶树种
continuous layer board 多层板cork  软木
cottonwood 三角叶杨,杨木(毛白杨类)
crook 弯曲木
cross rail 拉档
crotch 丫权
cupping 翘弯
curly birch 皱纹桦木板
curved laminated wood  弯曲层积材
curved plywood曲型合板
cypress针叶树
DDado 护墙板,墙裙
Damp room panel  防潮镶板
Decay 初腐
Deciduous species 阔叶树种
Décor panel 镶板,装饰板
Delta wood 多层木
Densified wood 强化木材
Density of wood 木材密度
Dent啃头Depth of cut 切削量(深度)
Diffuse porous wood  散孔材
Dimension 规格
Dimension stock规格材
 Dimple djohar 波纹
Door frame  鸡翅木
Door lining 门框
Dovetail 门衬板
Dowel 燕尾榫
Drawer front 圆榫
Drawer side 屉旁板
Dressed timber净材
EEastern cottonwood  (美国)东部杨木
Eastern hemlock (加拿大)铁杉
Eastern larch 落叶松
Eastern white pine (美国)白松
Ebony 乌木
Edge cutting 封边
Elm 榆木
Elm burl 榆木树瘤薄木板
End cutting 截头
English plane 英国悬铃木
Eucalyptus 桉木,桉树(类)
Eucalyptus pom 柠檬铁皮桉木板
Europe cherry 欧洲樱桃木板
Eropean ash 欧洲白蜡木
European beech 欧洲桦木
European birch 欧洲桦木
European chestnut 欧洲栗木
European hop-hornbeam 欧洲穗子榆
European horse-chestnut 欧洲七叶树
European larch 欧洲落叶松
European lime 欧洲椴木
European spruce 欧洲云杉
European yew 欧洲紫杉
Excelsior-board 木丝板
Exotics 外来木
Exterior plywood 室外用胶合板
HFace veneer 表面单板FAS 一级和二级FAX 1F 单面一级
Fibre board纤维板
Fiddle back提琴背(板)
Fiddle butt 乐器用材
Figured 影木
Figured sycomore 梧桐影木
Fine wood board 纤维板
Flakeboard 碎料板Flakes 薄片刨花
Flame-retardant fibre building board 耐火纤维板
Flat-grain lumber 平切纹板材
Flooring 地板
Flush panel 平(光)镶板
Formed plywood 模压(成型)胶合板
Frame core flush panel 中空合板
From sustainable forests 来自可持续发展的森林
Furniture dimension stock 家具规格材
Furniture plywood家具胶合板
Furniture veneer制作家具用的薄片
GGap 离缝
Giant cedar (美国)侧柏
Gloss 光泽度
Grade 等级
Grade of lumber 成材等级
Graded分等级
Grain 纹理
HHackberry 朴树
Band selected 手工挑选
Hard board 硬质纤维板
Hard maple 硬枫木,械树
Hardy catapa (美国)梓树
Heat board 心板
Hickory 山核桃木
High-density plywood 压缩胶合板,高密度胶合板
High gloss 超光泽度
High moisture resistant(HMR) 高强度抗湿
Hipboard 细木工板
Hole drilling 打眼
Honey-comb core plywood 蜂窝心胶合板
Huanghauli wood 黄花梨木
IIdentification of timbers 木材识别
Imitation wood 仿制材
Imported timber 进口材
Impregnated wood (合成树脂)浸渍木
Indian camphor 印度樟木
Indian chestnut 印度栗木
Indian cinnamon印度肉桂
Indian ebony 印度乌木
Indian “laurel” 印度“月桂树”
Insect attack虫眼
Inserting panel 装板
Install wood strip flooring 安装地板条
JJapanese beech 日本山毛榉
Japanese larch 日本落叶松
Japanese(red)pine 日本赤松
Japanese thuja 罗汉柏
Japanese white pine 日本五须松
Joint flooring 企口地板
Jointless flooring 无缝地板
KKarelian birch克若利安桦木板
Kerf width 锯路宽度Khaya 非洲桃花心木
Kiln dried pine 窑干松木
Kiln drying 人工窑干燥
Kind of timber 材种
Kirl 紫花泡桐
Knob 节子
Knock-down carcass 可随时拆卸的框架
Knot 木节,节疤LLaminate 层压
Laminated wood 层积材,多层胶合木
Leg 腿,脚
Liquid cutting of wood 木材水力切割
Log 原木
Log grade 原木等级
 楼主| 发表于 2008-4-3 14:31:47 | 只看该作者
家具五金词汇
AAluminum 铝
BBall bearing slide脚轮滑道
Bolt pin 螺栓插销
Bolts and nuts for furniture 家具用螺钉,螺帽
Brass 铜
CCarcase 框架,架子
Castor 小脚轮
Ceiling 天花板
Central hinges 中央铰链
Chrome 铬
Complete range of drawer slide 各种类型的抽屉滑道
Component 零配件,元件
Concealed hinge 内藏铰链
Cupboard-lock 拒门锁
DDecorative trims for furniture 家具金边饰条
Door & window 门窗
Drawer-lock 抽屉锁
Drawer runner 抽屉滑槽
EEquipment for surface treatment 表面处理工具3/4
extension slide 部分开式滑道FFaucet 水龙头
Fixture 固定装置
Full extension slide 全开式滑道
Furniture fittings 家具五金
Furniture hardware家具五金
Furniture parts 家具零配件
Furniture structural parts 家具结构零件
GGas lift chassis 气压棒底盘
Glass door hinge 玻璃门铰链
HHeavy duty slide 承重式滑道
Hook lock 钩锁
KKeyboard slide 键盘板滑道
LLarge head type 大头型
Locating dowel 定位榫钉
Lock rail 安锁冒头
MMagnetic catch 磁性拉手
Magnetic-lock 磁锁
magnetic push latch磁性撞锁
Marquetry work镶嵌装饰品
Material 原材料
Metal fittings 金属配件
Matal handle 金属拉手
Mold模具
OOffice chair central tube accessories 办公椅中管配件
Office chair hardware accessories 办公椅五金配件
Out set 外盖型套轮
PPanel veneer 板料
Plastic 塑料
Plastic bolt and threaded axis 塑料螺帽及牙轴
Pocket door slide 柜门滑道
Prevent falling off due to turning 防止旋转脱落
SSecret-hinge 暗铰
Semifinished furniture product and accessories 家具半成品及配件
Semifinished product for interior fittings 装潢用半成品
Simple connecting fittings 简单五金配件
Single item 单项产品
Sliding door roller series 推拉门用轮系列
Straight-lock 企口锁
Surface gluing 板面上胶
VVeneer trimming 薄片整修
Vertical upright 直挂格
WWood-button 木纽Wood components 木制配件
Wooden bar 车件
Wooden cork 木塞
Wooden curtain rod and ring 木制窗帘杆及吊环
Woodscrew 木螺钉
Wreathed hand-rail 扭弯扶手
 楼主| 发表于 2008-4-3 14:32:44 | 只看该作者
家具机械词汇
Aaccessory equipment 附属设备
adhesion test instrument for the wood coating 木材涂层附着力测定仪adz(e) 手斧,刮刀
air brake 空气制动器,气闸
air compressor 空气压缩机
air conditioning unit 风向调节器
air nailer 风动钉钉机
air operated automatic control 气动自动控制
air tacker气(风)动钉钉机
air tool 风动工具
automatic band saw sharpener 带锯自动锉锯机
automatic circular saw sharpener 自动锉(圆)锯机
automatic controlled machine 自控机床
automatic copy shaper 自动仿型刨边机(单刀)
automatic copy shaper(double heads)(with splash guard) 自动仿型刨边机(双轴)(附安全门)
automatic feeder for veneer dryer 单板干燥机的自动填料机
automatic hydraulic backnife wooden lathe 全自动液压背刀式木工车床
automatic loader and unloader 自动装卸机
automatic rotary table shaper 自动转台式成型机
automatic sponge drum sander 自动鼓式海绵砂光机
automatic strake belt sander 自动带式砂光机
automatic stroke belt sander 自动(抚摸)砂光机
automatic tapping and screwing machine 自动攻牙锁螺丝机
automatic turning sander 全自动砂光机,自动圆棒砂光机
automatic wide-belt sander 宽带砂光机
BBack and arm impact test machine 椅背扶手冲击试验机
balance cut-off saw 平衡截断锯
Band and circular saw sharpener 带锯圆面积锯两用锉锯机
Band resaw 再分带锯机
Band saw 带锯
Band saw clamp 带锯夹
Band saw machine 带锯机
Band saw machine with auto-feed carriage 带锯机附自动填料传送车
Band saw machine with hand-feed carriage 带锯机附手扒送料车
Band saw sharpener 带锯磨锯机
Band saw shear 带锯剪(截)机
Band saw slasher 多带横切锯
Band saw stretcher 带锯滚压机
Band saw welding clamp接锯机
Band sawing 带锯制材
Band scroll saw 细木工带锯,曲线带锯
Barefaced tenon 裸面榫
Bark-peeler 剥皮机
Barking drum 鼓式剥皮机
Barking machine 剥皮机
Belt conveyor 带式传送器
Belt drier 带式干燥机
Belt drive 皮带传动
Belt grinder 带式磨床
Belt sander 带式砂光机
Bentwood forming machinery曲木成型机
Bevel saw 斜面锯
Bifurcated rivet 开叉钉
Bit 齿片,钻头
Blade 锯条
Block plane 短刨
Blower通风机,鼓风机
Blower kiln 鼓风式干燥窑
Bobbin sander 轴式砂光机
Body press (家具)装配压床
Boring machine 钻床
Bow saw 弓锯
Brash chopper 枝梢切断机
Breathing veneer drier 呼吸式单板干燥机
Buffing machine 抛光机
Business item 产品
Butting saw 截锯,齐头锯
CCabinet whole-plant equipment 橱柜整厂设备
Carbide tool grinder 炭素钢刀具研磨机
Carving machine 雕刻机
Centerless sander 圆棒砂光机
Centrifugal blower 离心通风机
Chain-belt conveyer veneer drier 网带式单项式板干燥机
Chain mortiser 插床
Chain saw 链锯
Chain saw machine 链锯机
Chair aim static load test machine 椅扶手静荷试验机
Chair back and arm impact test machine 椅背扶手冲击试验机
Chair back static load test machine 座椅靠背静荷试验机
Chair leg static load test machine椅腿静荷试验机
Chair stability test machine座椅靠背耐久性试验机
Chair whole-plant equipment 椅子整厂设备
Chip board press 碎木板压合机
Chip edger 双削齐边锯
Chromometer 比色机
Circular gang-saw 圆排锯
Circular saw bench 简单圆面积锯机
Circular saw bench for band feed ripping 手工送料纵切圆锯机
Circular-saw sharpener 圆锯锉锯机
Coating adhesion test instrument 漆膜附着力试验仪
Coating impact instrument 漆膜冲击仪
Coating surface impact instrument漆膜表面冲击仪
Concave plane 凹底刨
Concave saw 凹面(圆)锯
Conveyor输送机
Copier 复印机
Corner locking machine 锁角机
Cross cut band saw machine 横切带锯
Cup type wheel stone机碗形砂轮
Cup wheel杯形砂轮
Curtain flow coater 淋幕式平面涂装机
Custom 订做Customized solutions 订做胶水
Cut-to –size saw 裁板锯
Cutting block组合铣刀
Cutting head 刀座,刀头
Cutting jip 切削夹具
Cylinder saw 桶形锯,圆桶锯
Cylindircal saw 圆桶锯
DDado head 组合刀头
Debarder 剥皮机
Deck planer大型电刨
Decorative tip 装饰物
Disc and spindle sander 盘式轴式联合砂光设备
Disc planer 圆盘刨
Disc sander 圆盘砂光机
Door whole-plant equipment 门斗整厂设备
Double band saw双边带锯
Double belt sander 双边砂光机
Double bevel cutter 双斜刨刀
Double-edge cutting band saw 双边齿带锯
Double-side planer双面刨木机
double spindle shaper 双轴铣床
Double surface oscillating curve sander 双面震动曲型杪光机
Double surface planer双面刨
Double surfacer 双(面)压刨
Double-swage(set)saw 双压料锯
Double thicknesser 双(面)压刨
Dovetail machine 鸠尾榫机
Dowel making machine暗榫(加工)机
Drag saw sharpener狐尾机,锉锯机
Drawer durability test machine 抽屉耐久性试验机
Dresser 砂轮修整器,砂轮刀
Drop test machine 跌落试验机D
rum barker 滚筒剥皮机
Drum sander 滚筒砂光机
Drunken saw 摇摆(圆)锯
Dust cleaner conveyor 粉尘清除输送机
Dust collector 集尘器
 楼主| 发表于 2008-4-3 14:33:22 | 只看该作者
家具种类
AAdjustable bed 可调床
Air bed 气床
Anti-slip strip for stairs (儿童床)防滑楼梯打击扶手
Antique furniture 古式家具
Antique reproduction furniture 仿古家具
Armchair 扶手椅
BBaby crib 婴儿床
Backless wall-unit 不设背板的壁橱
Bamboo furniture 竹家具
Banqueting chair 宴会椅
Barstool 吧椅
Bathroom accessories 浴室配套装置
Bathroom combination 浴室组合柜
Bathroom consoles 浴室多用架
Bathroom furniture 浴室家具
Bathroom vanity 浴室盥洗台
Batten door 板条门
Bed base床架,床套
Bed base set 成套床架
Bedroom suite 卧室系列家具
Bedstead 床架
Bentwood furniture 曲木家具
Beside table 床头柜
Birch door 桦木门
Board-room and conference table 会议桌
Bookcase 书柜
Bookshelf 书架
Built-in kitchen 配套厨房家具
Bunk 双层床
Bunk bed 双层床
CCabin bed 儿童多功能床
Cabin furniture for ships 船用家具
Canopy bed 带天篷的床,四柱床
CD-video storage cabinet边 音响组合柜
Chair with castors 脚轮椅
Changing table 可调桌
Chest of drawers 多屉橱柜
Child cot 童床
Children’s bed 儿童床
Children’s bedroom suite 儿童卧房系列家具
Children’s chair 儿童椅
CKD(complete knock down) 整体拆装式家具
Clothes rail 挂衣杆
Cocktail cabinet 吧柜,酒柜
Cocktail table 鸡尾酒桌
Coffee table 茶几,咖啡桌
Combine-unit 组合柜
Composite furniture 复合家具
Console 小桌
Console table (装在墙上的)蜗形腿台桌
Contract furniture 订做家具,承建家具
Contract programmes 订做家具
Corner sofa suite 拐角扶杆
Cot 童床(婴儿床)
Couch 长沙发椅
Cupboard 橱柜
Cupboard wall unit for flat 套房衣柜
Curtain 窗帘,挂帘
Customized furniture 订做家具
DDecorative lighting 装饰灯具
Dining room furniture 餐厅家具
Dining room set 起居室配套家具
Dining table 餐桌
Divan 长沙发,沙发床
Dividing wall and fitted wall unit 隔墙板及系列
DIY furniture 自装式家具
Double-bed 双人床
Double function sofa-bed 双人沙发床
Double sided mirror 双面镜
Draughtsman chair 吧椅
Drawer 抽屉
Dressing table 梳妆台
EEasy chair 轻便椅
End table 茶几
Entrance hall furniture 门厅家具
Exterior door户外门
FFiling cabinet 文件柜
Fireplace壁炉
Fitment 固定家具
Fitting 家居用品
Flap 翻门
Flower stand 花架
Flush door 平面门,全板门
Folding chair 折叠椅
Folding furniture 折叠家具
Folk furniture 民间家具
Foot-stool 踏脚凳
Framed mirror 带框镜子
French-type furniture 模式家具
French cabinet 法式桌椅弯脚
French door 玻璃门
Function sofa多功能沙发椅
Furniture for bedrooms 卧室家具
Furniture for public premises 公共场所家具
GGame table 玩具桌
Gate-leg table折叠桌
Glass cabinet 玻璃陈设柜
Glass case玻璃陈设柜
Glass unit and container 玻璃容器制品
Glazed door 玻璃门
HHall furniture 厅房家具
Hat and coat stand 衣帽架
Headboard 床头
Heirloom quality furniture 祖传家具
High bed 儿童高脚床(不带屉柜)
High chair 高脚椅Highback executive chair
高背办公椅Home furniture 家庭家具,民用家具
Home office furniture 家庭办公家具
Hotel furniture 酒店家具
Household furniture 家庭家具
Hutch碗架
IInstitutional furniture 风俗家具,公用家具
JJunior desk chair 学生书桌椅
KKitchen block /kitchen rock 厨房地砖
Kitchen cabinet 餐具柜
Kitchen chair, stool and bench 厨房椅、圆凳及条椅
Kitchen fitment 厨房固定家具
Kitchen table 厨房餐桌
Kitchen unit 厨房成套家具
LLamp table 灯桌
Lath grid 板条格
Ledged door 直板门
Link chair 写字板椅
Living room furniture 起居室家具
Locker 衣帽柜
Lounge furniture 客厅家具
Louvered door 百叶窗柜门
Lowback executive chair 低背办公椅
Lowback guest chair 低背来宾椅
Lowback visitor chair 低背接待椅
MManagerial mediumback chair 中背经理椅
Margined flush door 镶边平板门
Mattress 床垫,席梦思
Mediumback executive chair 中背办公椅
Metal furniture金属家具
Mirror door 玻璃门
Mirror for chest of drawers 多屉柜梳妆镜
Multi-purpose sofa 多用沙发
Multi-purpose table 多用桌
NNest 茶几
OOccasional furniture 配套家具,休闲家具
Occasional table 休闲桌
Office furniture 办公家具
Office seating 办公座椅
Office table 办公桌
PPartition wall 隔断
Pembroke table 折面桌
Planters chair 园艺工用椅
Plastic furniture 塑料家具
Play furniture 娱乐家具
Presidential highback chair 高背办公椅
Pull-out table 伸缩餐具
RRattan furniture 藤家具
Recliner 躺椅
Refectory table长餐桌
Rocking chair 摇摆椅
Rotary chair 转椅
Rustic style furniture 乡村风格家具
SSchool table 课桌S
creen 屏风
Seat痤椅Seating element 痤垫S
ecretarial chair 秘书椅
3-section mirror 三面梳妆镜
semi-CKD 半拆装家具
serving table送餐桌
 楼主| 发表于 2008-4-3 14:34:21 | 只看该作者
家具风格词汇
Aa generation of chairs办公椅的改进型
a proven program 一个已经落实的新项目
a relaxed posture in every seating position
适应各种从姿,令人倍感舒适
aesthetic design 美学设计
allow an ambience to be harmoniously created 营造和谐温馨的气氛
appealing design 造型优美
artisan craftsmanship 手工工艺
BBaroco style 巴洛克风格
CColonial plantation furniture 殖民种植风格家具
Contemporary design 现代风格设计
Copy 复制,模仿,仿冒
DDesign studio 设计事务所
Design trend 设计趋势
Designer 设计师
Distinct grain pattern 清晰的木纹图案
EEconomical, versatile and efficient 经济实惠,用途多,效率高
Emphasize the magnificent features of the range 更烘托出豪华气氛
Energy and comfort 方便舒适
Essential, functional design 基本功能设计
Ethnic African style 非洲民族风格
FFocus on the essential 注重本质
Freelance 自由职业者
Functional, ergonomic, long-lasting 功能齐全,人体工艺,经久耐用
Functionality, quality and appealing design 功能全,质量优,造型佳G
Graphic design 图片(装帧)设计
HHigh quality 优质的
IIdeal combination between 两者完美的结合
Imitate 模仿
In a Italian walnut finish 意大利胡桃木效果
Innovative 创新的
Intelligent design 理智的设计
Interior decorator 室内美术师
Interior design室内设计
Interior designer室内装饰师
Italian style意大利风格
LLight color浅色,淡色
MMarbled effect 大理石效果
Meet the standards of all areas of the modern world of work可满足现代化办公要求
Ming Dynasty 明朝
NNatural feeling of warmth and texture 质感温暖自然
Neoclassic style 新古典式风格
PPerfect in shape and function 造型优美,功能完善
Product image development 产品形象推广
Product industrialization 产品工业化(设计)
QQing Dynasty 清朝
RRectangular 矩形
Rococo style洛可可风格
TTerra-cotta granulated paint finish 陶式沙砾漆效果
The strength of the company 公司工作重点
Traditional design传统风格设计
WWith a classic trend 带有古典风格
With the experience of specialist 由专家设计制作
Without compromise 面面俱到
 楼主| 发表于 2008-4-3 14:35:07 | 只看该作者
油漆涂料词汇
AAccelerate 促进剂
Accelerator硬化剂,接触剂
Acetic acid 醋酸Acetone 丙酮
Achromatic color 无彩色
Acid stain 丙烯酸树脂
Acrylic丙烯酸
Acrylics acid resin 丙烯酸(类)树脂
Acrylonitrile butadiene styrene resin ABS树脂,丙烯腈-丁二烯-苯乙烯树脂
Active agent 活性剂
Additive 添加剂
Additive mixture 加色混合
Adhesive 胶粘剂
Adhesive solvent 胶(料)溶剂
Adjacent color 类似色
Advancing color 进出色
Aerosol spraying 简易喷涂
After image 残象Air drying 常温干燥
Airless spraying 无气喷涂
Alcohol stain 酒精着色剂
Alert color警戒色
Alkyd resin 醇酸树脂
Alligatoring 漆膜龟裂
Amount of spread 涂胶量
Anticorrosive paint 防锈涂料
Antifouling paint 防污涂料
Antique finish 古式涂料
Automatic spraying 自动喷涂
BBaking finish 烤漆喷涂
Base boat 底漆
Blistering 小泡B
lushing 白化
Body varnish 磨光漆
Brilliant 鲜艳的
Brushing 刷涂
Brushing mark/streak 刷痕
Bubbling 气泡
Button lac 精致虫胶
CCafé 咖啡色
Carbamide resin adhesive 尿素树脂胶
Catalyst 催化剂,触媒,接触剂
Chalking 粉化
Cherry 樱桃色
Chipping 剥落
Chromatic color 有彩色
Chromaticity 色度
Chromaticity coordinates 色度坐标
Chromaticity diagram色度圆
Clssing 补漆
Clear coating 透明涂层
Clear lacquer 透明喷漆
Clear paint 透明涂料
Coarse particle 粗粒
Coating 涂料
Cobwebbing 裂痕
Cocos 可可色
Cold water paint 水性涂料
Color blindness 色盲
Color conditioning 色彩调节
Color harmony 色彩调和
Color in oil 片种特(调色用)
Color matching 调色
Color number 色号(色之编号或代号)
Color paint 有色涂料
Color reaction 显色反应
Color reproduction 色重现
Color tolerance 色容许差
Compatibility 相容性
Complimentary color 补色
Consistency 稠厚度
Contractive color 收缩色
Col color 寒色,冷色
Cooling agent 冷却剂
Covering power 覆盖力
Cracking 龟裂,裂纹
Cresol resin adhesive 甲酚树脂胶
Crimping 皱纹Cure 硬化
Curing agent 固化剂
Curing temperature 固化温度
DDark 暗Deep 深Degumming 脱胶
Dewaxed shellac 胶蜡虫胶
Diluent 稀释剂,冲淡剂
Dilution ratio 稀释比例
Dingy 浊色Dipping 浸渍涂层
Dipping treatment 变色
Discoloring 变色
Discord 不调和色
Drier 干燥剂
Dry rubbing 干磨
Drying time 干燥时间
Dulling 失光Dusting 粉化
EEgg-shell 埴孔亚光,显孔亚光
electrostatic spraying 静电涂装
emulsion adhesive 乳化胶
emulsion paint 乳化涂料
enamel 色漆,磁漆
end-coating 端面涂层
end-gluing 端面胶合
epoxy finish环氧效果
epoxy resin glue环氧树脂胶
ethyl cellulose lacquer乙基纤维素喷漆
FFading退色
Filler 腻子,埴料,填充剂
Finish code 涂料编号
Finshing 涂饰Flaking 剥落
Flat paint 消光涂料
Flatness 消光
Floor paint 地板涂料
Foam glue 泡沫胶
GGelatin 明胶,凝胶
Glare 眩目
Glue 胶粘剂,胶,胶料
Glue and filler bond 动物胶及填料胶结
Glue mixer 调胶机
Glue spreader 涂胶机
Gum 树胶,胶树
HHardener 硬化剂
Hide 皮胶
High solid lacquer 高固体分漆
Honey color 蜂蜜色
IIlluminant color 光源色
JJelly strength 胶质强度
Joint strength 胶接强度
LLac 虫胶
Lac varnish 光漆
Lacquer 漆
Latex 乳胶
Latex paint 合成树脂乳化型涂料
Leveling agent 均化剂
Light 光亮的
Liquid glue 液态胶
Long oil varnish 长性清漆
Love formaldehyde 低甲醛
MMake up paint 调和漆
Medium oil varnish 中油度清漆
Melamine resin adhesive 三聚氯胺树脂胶,蜜胺树脂胶
Melamine resin sheet 三聚氯胺树脂(片)
Methyl alcohol 甲醛
Multi-color 多彩漆
NNatural clear lacquer 清漆
N.C lacquer 硝化棉喷漆
N.C lacquer enamel 硝色棉色漆
N.C lacquer sealer硝化棉底涂料
N.C lacquer surfacer 梢化棉中涂整面涂料
Nitro-cellulose lacquer 硝化纤维漆,硝基榉
Nitro-lacquer 硝基漆
Nitrocellulose lacquer 硝化纤维(喷)漆
Non toxix finishes无毒喷漆
Novolac (线型)酚醛清漆
OOff- color 变色的,退色的,不标准的颜色
Oil paint 油性漆
Oil putty 油性腻子
Oil solvent 油溶剂
Oil stain 油性着色剂
Oil staining 油着色Oil stone 油石
Oil varnish 油性清漆,上清漆
Opacity 不透明度
Opaque paint 不透明涂料
PPaint 涂料,油漆
Paint film 涂膜
Paint nozzle 涂料喷头
Penetrant 渗透剂
Phenol aldehyde resin 酚醛树脂胶
Polishing varish 擦光(亮)清漆
Poly Urethane Resin 聚氨酯
(PU)Poly ester 聚酯
Polyester resin lacquer 聚酯树脂涂料
Polypropylene 聚丙烯
Polystyrene聚苯乙烯
Polyurethane 聚氨酯
Polyvinyl acetate adhesive 聚醋酸乙烯(树脂)胶
Polyvinyl adhesive 聚乙烯树脂胶
Polyvinyl chloride resin 聚乙烯树脂涂层
Pre-coating 预涂Procuring 预固化
Preservative 防腐剂
Primer 底漆(下涂涂料)
Putty 腻子
Pyroxylin lacquer 硝基漆
QQuick drying paint 速干漆
RReady mixed paint 调和漆
Refined shellac 精制虫胶
Resin adhesive 树脂胶
Reverse coater 反向涂料器
Roller brush 滚筒刷
SSample board 样板
Sand blast 喷砂
GMT+8, 2026-11-30 15:18 , Processed in 0.030155 second(s), 19 queries , Gzip On.
