查看: 727|回复: 2
IAPMO产品认证规范分类说明
发表于 2008-2-28 15:47:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IAPMO产品认证规范分类说明
1.止回阀 (Backflow Preventers)
IAPMO PS 38
2.水泥、焊料、结合点混合物 (Cements/Solder/Joint Compounds)
IAPMO PS 36; ASTM B 32
B 813, D 2235, D 2564, D 2672, D 2835, D 3122, D 3212, F 656
3.电气设备 (Electrical)
UL 651
4.房车及娱乐车用制造设备产品 (Manufactured Housing/RV Components)
ASSE 1049, 1050, 1051; IAPMO PS 42, PS 47, PS 54, PS 94, PS 95, TSC 2, IAPMO PS 55 , PS 69, PS 74, TSC 4, TSC 7, TSC 8, TSC 14, TSC 15, TSC 19, TSC 21, TSC 25, TSC 26, ANSI A112.21.2M, ASME A 112.21.1M
5.金属装置 (Metal Fixtures)
IAMPO PS 5, PS 54, PS 62, PS 9, PS 14, PS16, PS 41, ANSI A112.21.2M, ASME A112.19.1M, ASME A112.21.1M
6.金属管件及配件 (Metal Pipe/Fittings)
IAPMOPS 2, PS 7, PS 9, PS 14, PS 16, PS 23, PS 74, PS 4, PS 5, PS 44, ASTM F 1807
7.管道外涂层及覆盖物 (Pipe Wrap Tape/Coatings)
IAPMO PS 37
8.塑料设备 (Plastic Fixtures)
ANSI Z 124.5, IAPMO PS 94, PS 69, PS 74, PS 90, ANSI Z 124.1, ANSI Z124.2, ANSI Z 124.4, ANSI Z 124.8, ANSI A 112.21.2M, ASME A112.21.1M
9.塑料管件及配件 (Plastic Pipe/Fittings)
ASTM D 1527, D 1785, D 2104, D 2239, D 2241, D 2282, D 2447, D 2246, D 2467, D 2468, D 2661, D 2665, D 2680, D 2729, D 2737, D 2751, D 2846, D 3034, D 3036, D 3212, D 3311, F 405, F 409, F 437, F 438, F 439, F 441, F 442, F 628, F 667, F 789, F 794, F 810, F 876, F 877, F 891, F 949, F 1412, F 1673; IAPMO PS 4, PS 33, PS 38, PS 47, PS 51, PS 69, PS 74, PS 90, PS 94, SPS 3, SPS 4, ASME A112.21.1M, AWWA C 900, IAPMO PS 16, ANSI A 112.21.2M
10.阀门及龙头 (Valves/Faucets)
IAPMO PS 45, ASSE 1016, ASSE 1025, ASSE 1014, IAPMO PS 69, ASME A 112.18.1M
11.供水软管标准 (Flexible water connecters)
ASME A112.18.6
12.玻璃陶瓷洁具设备 (Vitreous China plumbing fixtures)
ASME A112.19.2m-1998
13.卫生洁具功能要求 (Hydraubic Performance Requirements for water closets and urinals)
ASMEA112.19.6-1995
14.水箱配件(Anti-siphen fill valves (Ballcocks) for Gravity water closet Flush Tanks)
ASSE Standard#1002
15.卫生间及卫生洁具排水阀 (Trim for water-closet bowls tanks, and urinals)
ASMEA112.19.5-1999
16.水龙头花洒 (Han-held Showers)
ASSE Standard No.1014
17.管箍及配件 (Shielded couplings joining hobbles cast iron, soil, pipe and fittings)
ASTM C
18.铸铁管/及管件 (CAST IRON, Soil pipe)
CISPI 601 ASEM A888
19.游泳池、健身浴池设备及配件 (Pool/Spa Components/Fittings)
ASME A 112.19.8, IAPMO PS 33, SPS 3, SPS 4
20.污水系统 (Septic Systems)
IAPMO PS 1
21.浴盆 (Shower Pan Liners)
ASTM D 4068, D 4511
22.真空破坏器 (Vacuum Breakers)
发表于 2008-2-29 00:00:15 | 只看该作者
顶顶顶
 楼主| 发表于 2008-3-3 18:08:25 | 只看该作者
回复 #1 braveshow 的帖子
有要其中部分标准的请留MAIL
GMT+8, 2026-10-17 23:20 , Processed in 0.095244 second(s), 18 queries , Gzip On.
