查看: 4083|回复: 30
一个第三方的DVD的检验报告
发表于 2008-2-10 18:44:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个第三方的DVD的检验报告,欢迎大家批评指正.
需要说明的是:如果你是贸易公司的朋友,大可不必这么麻烦,不需要这么多的图片,也不需要写这么多的测试.
Client Name
Supplier
Welltech Products Ltd
Factory
Skywood
Relation with factory
OEM
Inspection Location
Huizhou city, Guangdong province, China
Inspection date
Jan. 28,2008
Inspector
Alex / Jerry
Product Description
DVD Player
P.O No.
AM/PO 0415/07
P.O Quantity
7048
pieces
1762
cartons
Shipment Quantity
7048
pieces
1762
cartons
Model/Art/Style
DB-1700
QUANTITY AVAILABLE
Shipment Quantity
Quantity Available
Sampling Size From
Packed in Carton (%)
Packed in Polybag (%)
Finished but Not Packed (%)
Not Finished (%)
Packed Quantity
7048 pcs
4820pcs(68.4%)
0
0
31.6%
80 pcs
0
1762 ctns
1205 ctns(68.4%)
0
0
31.6%
50 ctns
0
INSPECTION CRITERIA & FINDINGS
Inspection Standard
ANSI/ASQC Z1.4
AQL
Accepted
Total Found
Sampling plan
Single, Normal
Critical
Not Allowed
0
0
Inspection Level
Level I
Major
1.5
3
21
Sample Size
80
pcs
Minor
4.0
7
0
INSPECTION RESULT
Quantity
[ x ] Conform
Not Conform, please refer to Special point
Workmanship
Conform
[ x ]Not conform, due to beyond AQL and refer to Special point 2,3 and 4.
Product Description /Style/Color
] Conform
[ x ] No sample given
On-site checking
[ x ] Conform
No requirement given
Form of Packaging
Conform
[ x ]
Shipping Mark
Conform
[ x ]
Not Conform, please refer to Special point 5.
OVERALL
CONCLUSION
] CONFORM TO APPLICANT’S REQUIREMENTS
[ x ] NOT CONFORM
] PENDING FOR APPLICANT’S DECISION
Due to[
] Special Point #:
Inspector’s signature: ALEX / JERRY
Factory signature and chop:
1) SPECIAL POINTS
1.
No approval sample was available for this shipment inspection.
2.
When arrival at factory at 10:30am, only 68.4% of products were finished and packed in export carton for inspection, and the balance was still in production line and excluded this inspection.
3.
Found 100% of nails on gift box were corrosive (rust mark), details refer to photo #78-81.
4.
Found actual brand of Optical reader and loader were “ARIMI”, Which not conformed to client’s PO required: “Hitachi”.
5.
The total numbers of export carton shown on shipping mark was 2180 instead of the required: 1762, details refer to photo #86.
6.
1 pc of defective sample (Rust mark on screw and nails on gift box was corrosive) was sealed by tape with inspector’s signature and keep at factory, refer to photo #82-85.
7.
Power cord length check on 1 pc , found length was 1.2 M;
8.
RCA cable length check on 1 pc , found length was 1.5 M;
9.
Found “Made in China” was shown on side mark of export carton, which conformed to client’s requirement.
10.
The finished quantity and packed in export carton were 5320 pieces while inspector leave at factory at 17:30 pm.
11.
Remote control distance measured on 1 pc was 10 M.
] Please turn to supplementary
2) WORKMANSHIP
Defects Description
Cr
Ma
Mi
1.
Rust mark on screw
18
2.
Missing remote controller inside gift box
1
3.
Loosen screw on back panel of DVD player.
1
4.
Forward key of remote controller no function
1
Total Found:
0
21
0
Allowed:
0
3
7
3)
PRODUCT DESCRIPTION, STYLE AND COLOUR
1.1
Check against PO
[ x ] The inspected samples were found similar to the description of PO
] Discrepancy was found. Please refer to Special point _______
] No PO was available for this shipment inspection.
1.2
Check against approval sample.
] The inspected samples were found similar to the submitted photo by
] Discrepancy was found on inspection sample. Please refer to Special point ________________
[ x ] No submitted sample was provided by applicant or Vendor for style & color comparison
4)
On-site checking
[ x ] Barcode readability check(S-1):
5
Samples ):
[ x ] Conform
] Not Conform, please refer to Special point ____
[ x ] Running test(4Hours)(S-1):
5
Samples ):
[ x ] Conform
[ x ] Product stability test at 10 degree slope(S-1):
5
Samples ):
[ x ] Conform
[ x ] Power cord tension test(15 lbs):
1
Sample ):
[ x ] Conform
[ x ] Hi-pot test(Level-I):
80
Samples ):
[ x ] Conform
[ x ] Playing function check(S-1):
5
Samples ):
[ x ] Conform
Use DVD, MP3, VCD, SVCD, WMA, 8 CM DVD,
CD, Region Disc and Kodak CD for test
[ x ] Normal function check(S-3): included
20
Samples ):
[ x ] Conform
connection terminals check, keys on remote
controller and product, power on/off, open/close,
play/resume/pause/stop, fast forward/backward
,volumn+/-, zoom, osd, and sound /picture quality,
LED display check, etc.
[ x ] Shock test(no loose material inside unit) (S-1):
5
Samples ):
[ x ] Conform
[ x ] Battery fitting check(S-1):
5
Samples ):
[ x ] Conform
[ x ] Battery voltage check(>1.5 V) (S-1):
5
Samples ):
[ x ] Conform
[ x ] Carton drop test:
1
Carton ):
[ x ] Conform
[ x ] Silk screen printing check(Tape test)(S-1):
5
Samples ):
[ x ] Conform
[ x ] General setting check according to Menu:
1
Sample ):
[ x ] Conform
5) PACKAGING:
-Each pc was packed in a gift box.
-4 pcs were packed in an export carton and sealed with tape.
6)
SHIPPING MARK:
Main mark ( 2 ) Side(s)
Side mark ( 2 ) Side(s)
Refer to photo
Refer to photo
NOTE
[ x ] Photos have been taken
] Manufacturer did not agree with us to draw one production sample to ???? office for reference.
] Manufacturer did not agree with us to draw defective sample to ???? office for reference.
SUPPLEMENTARY __Nil._
PSI_Shenzhen_Welltech.doc
1.32 MB, 下载次数: 131, 下载积分: 金币 -1
参与人数 1金币 +5 威望 +5 收起 理由
yyfbz + 5 + 5 你很热情
 楼主| 发表于 2008-2-10 18:47:12 | 只看该作者
INSPECTION PHOTO接上面DVD检验报告
INSPECTION PHOTO:接上面DVD检验报告
Inspection photo.doc
969.5 KB, 下载次数: 135, 下载积分: 金币 -1
发表于 2008-2-15 08:37:25 | 只看该作者
have a look ,thanks!
发表于 2008-2-15 13:47:52 | 只看该作者
很好,多谢分享!
发表于 2008-2-15 22:31:32 | 只看该作者
不错,多谢分享
 楼主| 发表于 2008-2-16 17:24:50 | 只看该作者
报告应该是很不错的,如果有朋友要去公证行,可以学习下.公证行的报告大都是差不多的.
发表于 2008-2-16 22:55:16 | 只看该作者
谢谢分享
发表于 2008-2-17 18:27:30 | 只看该作者
   thank you!
发表于 2008-2-18 14:09:19 | 只看该作者
楼主辛苦了
谢谢分享
发表于 2008-2-21 10:04:25 | 只看该作者
GMT+8, 2026-10-17 13:33 , Processed in 0.040556 second(s), 22 queries , Gzip On.
