查看: 675|回复: 0
英语“口语”集锦1-劝告(Advice)
发表于 2008-1-29 15:23:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. Give it a try. 试试看。
2. Go for it. 去试试吧。
3. Have a go at it. 你来试一试。
4. It won’t hurt you to try it. 你不妨试试。
5. It’s going to be hard, but give it your best shot. 事情会很难,你尽力而为就是了。
6. Come on. You can do it! 来吧,你能行!
7. Go for the first prize! I know you are good enough. 争取拿头奖,我知道你行。
8. Let’s see some action! 赶快行动起来吧!
9. No pain, no gain. 只有付出,才有收获!(不劳则无获!)
advising someone to be patient advising someone to be patient
劝说某人要有耐心
1. Take it easy. 别着急。
2. Just try to be patient. 尽量耐心一点。
3. Please bear with me. 请耐心等一会儿。(意为:请等我把话说完或把手上的事情做完。)
4. Take things as they come. 车到山前必有路。(字面含义:等事情发生了,再想对策也不迟。)
5. Rome wasn’t built in a day. 罗马不是一天建成的。
6. One step at a time. 做事要一步一步来。
7. Don’t get ahead of yourself. 别做你力所不能及的事。
8. Don’t jump the gun. 别轻举妄动。(jump the gun:运动员在发令枪没响时就抢先起跑。常指在情况不明时过早地表态或行动,因而造成失误。)
9. Don’t cross that bridge till you come to it. 没到河边,先别操心怎么过桥。
10. All in good time. 别急,还有时间。
11. There’s a time for everything. 事情要一件一件地做。
12. Things will work out in the end. 事情最终都会解决的。
13. Everything will work itself out. 每件事情都会得到解决的。
14. Everything will fall into place. 事情该怎样,就会怎样。
15. Everything will come out right in the end---just you wait and see. 你就等着瞧吧,一切最终都会顺利解决。
英语“口语”集锦2-劝告
conforting someone who is unhappy
    安慰心情不好的人
    1. Pull yourself together. 振作起来。
    2. Keep your chin up. 别灰心。
    3. Don’t let it get you down. It will be over with soon. 别为此烦恼。事情很快就会过去的。
    4. Don’t be so miserable! 别这愁眉苦脸的。
    5. Cheep up! things will work out for the best. 高兴点儿。事情会有好结果的。
    6. Take heart- we’ll find a way out. 振作起来,我们会有办法的。
    7. Keep trying! Don’t give up the ship. 继续努力! 别轻易放弃!
    8. Loosen up! It’s not worth getting upset about. 放松点儿!不值得为这件事苦恼。
    9. Hang in there. Things will get better. 坚持住,情况会好起来。
    10. Keep smiling! things will calm down. 乐观一点,事情会平息下来的。
    11. It’s not as bad as all that. 事情没有那么糟。
    12. Things are never as bad as they seem. 事情往往不像看上去的那么糟。
    13. Win a few, lose a few. That’s life. 有得也有失,生活就是如此。
    14. Tet’s look on the bright side. 我们来看看它好的一面。
    15. Every cloud has a silver lining. 再黑暗的地方也有一线光明。
    16. When god closes a door, he opens a window. 山不转水转。
    17. Tomorrow is another day. 有明天就有希望。
    18. Stop carrying the weight of the world on your shoulders. 别太操心了,没有你地球照样转。(carry the weight of the world on one’s shoulders:自以为重任在肩。)
    telling someone to accept a bad situation or failure
    劝说某人接受失败或不好的境遇
    1. There’s nothing you can do about it. 你对此无能为力。
    2. That’s the way it goes. 现实就是这样。
    3. You can’t fight it. 你再争也没有用。
    4. c’est la vie. 生活就是如此。
    5. It was destined to happen.这是命中注定。
    6. It’s meant to be.命该如此。
    7. What ever will be, will be. 该怎样,就会怎样。
    8. It’s just one of those things. 这样的事情总是难免的。
    9. At least we are not the only ones facing these problems. 至少不光是我们面临这样的问题。
    10. It’s the best we can do under the circumstances. 情况就是这样,我们已经尽力而为了。
    11. You did the best you could. 你已经尽力而为了。
    12. You get an a for effort. 你尽了最大的努力。
    13. The important thing is that you tried. 重要的是你已经努力过了。
    14. Winning isn’t everything. 赢并不是一切。
    15. It’s not whether you win or lose, it’s how you play the game. 关键不在于输赢,而在于怎么玩。
参与人数 1金币 +4 威望 +8 收起 理由
hunghe + 4 + 8 你太有才了
GMT+8, 2026-11-30 13:40 , Processed in 0.091185 second(s), 19 queries , Gzip On.
