查看: 608|回复: 0
PCB 行业常用英文
发表于 2008-1-23 11:51:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PCB艺工作者行业常用英文:
1、
印制电路:printed circuit
2
印制线路:printed wiring
3
印制板:printed board
4
印制板电路:printed circuit board (PCB)
5
印制线路板:printed wiring board(PWB)
6
印制元件:printed component
7
印制接点:printed contact
8
印制板装配:printed board assembly
9
板:board
10
单面印制板:single-sided printed board(SSB)
11
双面印制板:double-sided printed board(DSB)
12
多层印制板:mulitlayer printed board(MLB)
13
多层印制电路板:mulitlayer printed circuit board
14
多层印制线路板:mulitlayer prited wiring board
15
刚性印制板:rigid printed board
16
刚性单面印制板:rigid single-sided printed borad
17
刚性双面印制板:rigid double-sided printed borad
18
刚性多层印制板:rigid multilayer printed board
19
挠性多层印制板:flexible multilayer printed board
20
挠性印制板:flexible printed board
21
挠性单面印制板:flexible single-sided printed board
22
挠性双面印制板:flexible double-sided printed board
23
挠性印制电路:flexible printed circuit (FPC)
24
挠性印制线路:flexible printed wiring
25
刚性印制板:flex-rigid printed board, rigid-flex printed board
26
刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
27
刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
28
齐平印制板:flush printed board
29
金属芯印制板:metal core printed board
30
金属基印制板:metal base printed board
31
多重布线印制板:mulit-wiring printed board
32
陶瓷印制板:ceramic substrate printed board
33
导电胶印制板:electroconductive paste printed board
34
模塑电路板:molded circuit board
35
模压印制板:stamped printed wiring board
36
顺序层压多层印制板:sequentially-laminated mulitlayer
37
散线印制板:discrete wiring board
38
微线印制板:micro wire board
39
积层印制板:buile-up printed board
40
积层多层印制板:build-up mulitlayer printed board (BUM)
41
积层挠印制板:build-up flexible printed board
42
表面层合电路板:surface laminar circuit (SLC)
GMT+8, 2026-11-30 15:17 , Processed in 0.026763 second(s), 18 queries , Gzip On.
