查看: 2161|回复: 13
灯英语词汇
发表于 2007-7-9 16:21:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
acetylene lamp 乙炔灯
adverse weather lamp 防风灯, 防雾前灯
air cooled lamp (空)气冷(却电子)管, 空气冷却照明器
alarm lamp 信号灯, 告警灯
alcohol lamp 酒精灯
aldis lamp 轻便信号灯(飞机和船舶用); 手提闪光信号灯
alert lamp 报警信号灯
alley lamp 壁灯
all night lamp (客车)终夜灯
all-senders-busy lamp 记发器全忙信号灯
alternating current energized lamp 交流激励灯
amber lamp 淡黄色信号灯
amplifying lamp 放大管
analog lamp 模拟灯
anchor lamp 停泊灯, 抛锚灯
answer(ing) lamp 应答灯
answer next lamp 副应答灯
answering supervisory lamp 应答监视灯
approach indication lamp 接近表示灯
approach lock lamp 接近锁闭表示灯
approved lamp 安全灯
arc lamp 弧光灯
argon(-filled) lamp 氩光[气]灯
artificial sunlight lamp (人工)太阳灯
assignment lamp 呼叫灯, 联络灯
astral lamp 无影灯
atomic lamp 原子灯
attenuation step pilot lamp 衰减分级指 示灯
automatic signal lamp 自动信号灯
auxiliary lamp 辅助灯
auxiliary pilot lamp 辅助信号灯
back lamp 尾灯
bactericidal lamp 杀菌灯
ballast lamp 镇流灯
beacon lamp 标向灯
benzine blow lamp 汽油喷灯
berth lamp 卧铺灯
bimetal lamp 双金属灯
bipost lamp 双接点聚光灯
black-light lamp 不可见光灯, 黑光灯
blast lamp 喷灯
blow lamp 喷灯
blue print lamp 晒图灯
brazing lamp 铜焊喷灯
built-in head lamp 内装头灯, 插入头灯
busy lamp 占线指示灯, 忙线信号灯
button barrel lamp 按钮表示灯
cab lamp 司机室灯
cadmium lamp 镉灯
call lamp 呼号灯
called subscriber held lamp 用户信号灯, 被叫用户挂机信号灯
calling lamp 呼叫(信号)灯
calling supervisory lamp 呼叫监视灯
canary lamp 充气黄色灯泡
candle lamp 烛灯
cap lamp 【采矿】帽灯
carbon lamp 炭丝灯
carbon arc lamp 炭棒弧光灯
carbon-dioxide lamp 二氧化碳灯
carbon filament lamp 炭丝 灯泡
cartridge lamp 熔线灯
cathode-ray lamp 阴极射线管
ceiling lamp 吊灯
cell inspection lamp 电池检查灯
charge lamp 充电指示灯
chargeable (time) lamp 报时灯, 通话时长指示灯
check lamp 校 验灯
circular lamp 圆焰灯
clearing lamp 终话信号灯
codan lamp 接收指示灯
close-coupled lamp 紧密偶合灯
coiled lamp 卷丝灯
coiled-coil lamp 叠螺旋灯丝灯泡, 螺线式灯丝灯泡
cold cathode lamp 冷阴极电子管, 冷阴极灯
cold cathode fluorescence lamp 冷阴极荧光灯
cold light lamp 冷光灯
  cold-start lamp 冷起动灯
colour discrimination lamp 辨色灯
coloured lamp 彩色灯
comparison lamp 比较灯
compartment lamp 房间灯
control (indicating) lamp 控制表示灯
copying lamp 晒图灯, 复制灯泡
cord lamp 塞绳灯, 绳路信号灯
cord pendant lamp 吊灯
counter lamp 计数器信号灯
cowl lamp (发动机上的)边灯crater 点源录影灯(一种特殊的充氖 、氩或氦的辉光管); 凹孔放电管
cupola marker lamp 守车了望顶棚标志灯
current indicator lamp 示流灯
darkroom lamp 暗室灯
daylight lamp 日光灯
daylight fluorescent lamp 日光色荧光灯
"day-lite" display lamp 日光显示灯
deck lamp (机车的)煤水车灯
departure indication lamp 离去[发车]表示灯
detector lamp 检漏灯
deuterium lamp 氘灯
dial lamp 度盘灯
digital indicating lamp 数字指示灯
dim lamp 磨砂灯泡
discharge lamp 放电管
display lamp 显示灯, 表示灯
division lamp 区划灯
double-carbon arc lamp 双碳弧光灯
double coil lamp 双绕灯丝灯泡
dual-jacketed lamp 双夹套灯
dub lamp 复制灯
earth lamp 接地表示灯
electric arc lamp 电弧灯
electric(al) discharge lamp 放电管[灯]
electric incandescent lamp 白炽灯
参与人数 1威望 +2 收起 理由
kinzo + 2 全球验货员感谢你
 楼主| 发表于 2007-7-9 16:21:36 | 只看该作者
electric points lamp 电动道岔灯
                  electric safety lamp 电矿灯
                  electroluminescent lamp 场致发光灯
                  embarkation lamp 车外灯
                  emergency lamp 事故备用灯
                  enclosed arc lamp 封闭式弧光灯
                  engine hatch lamp 机车头灯
                  enlarger lamp (图象)放大灯
                  evening lamp 半夜灯, 黄昏灯
                  exciter lamp 激励灯
                  exciting lamp 激励灯; 激励管
                  exposing lamp 曝光灯
                  extra-high-pressure mercury vapor lamp 超高压水银灯
                  fairy lamp 彩色小灯
                  fairy light 彩色小灯
                  fancy lamp 装饰灯
                  fault indicating lamp 故障指示灯
                  fender lamp 保护板灯
                  filament lamp 白炽灯
                  finish lamp 操作结束检查[信号]灯
                  finsen lamp 水银灯
                  fishing lamp 集鱼灯
                  flame arc lamp 焰弧灯
                  flash(ing) lamp 闪光灯; 手电筒
                  flash-signal lamp 闪光信号灯
                  flexible lamp 活动电灯
                  flickering lamp 闪光灯
                  flood lamp 泛光灯
                  fluorescent lamp 荧光灯
                  focus lamp 焦点灯
                  framing indicator lamp 成帧指示灯
                  frosted lamp 毛玻璃[闷光]灯泡
                  frosted incandescent lamp 磨砂白炽灯
                  ga(u)ge lamp (仪表板上的)仪表灯
                  garage lamp (带金属护网的)安全灯
                  gas lamp 煤气灯
                  gas arc lamp 煤 气灯, 充气弧光灯
                  gas discharge lamp 气体放电灯
                  gaseous discharge lamp (荧光)气体放电管
                  gas-filled lamp 充气(电)灯泡
                  gas-filled incandescent lamp 充气白炽灯泡
                  gas-testing lamp 检查瓦斯灯
                  germicidal lamp 杀菌灯
                  gig lamps [俚]眼镜
                  glim lamp 暗光灯; 阴极放电管
                  glow-discharge lamp 辉光放电管
                  Grimm lamp 格林(放电)灯
                  ground lamp 接地表示灯
                  grounded signal lamp 接地指示灯
                  hand lamp 手(提)灯
                  hand regulated arc lamp 可调弧长的手提灯
                  head lamp (列车)头灯
                  heating lamp 喷灯; 加热灯; 焊接灯
                  helical lamp 螺旋形灯
                  helical flash lamp 螺旋型闪光灯
                  helium lamp 氦灯
                  high-frequency discharge lamp 高频放电管
                  high-pressure mercury vapo(u)r lamp 高压汞(气)灯, 高压水银灯
                  high-voltage lamp 高压电路试验灯; 高压管
                  hot cathode mercury discharge lamp 热阴极汞放电灯
                  hot start lamp 热起动灯
                  hurricane lamp 防风煤油灯; 马灯
                  hydrogen (discharge) lamp 氢灯
                  identification lamp 识别灯, 标志灯
                  incandescent lamp 白炽灯, 白热灯
                  incandescent arc lamp 白炽弧光灯
                  indicating lamp 指示灯
                  indication lamp 表示 灯, 指示灯
                  indicator lamp 表示 灯, 指示灯
                  infra-red lamp 红外线灯
                  infrared heat lamp 红外加热灯
                  infrared ray lamp 红外线电灯
                  inspection lamp 【采矿】井下检查灯
                  instant-start lamp 速燃灯(电极不预热的荧光灯)
                  instant -start hot cathode lamp 瞬时点燃热阴极灯
                  intensive arc lamp 强弧灯
                  inverted arc lamp 反向弧光灯
                  iridium lamp 铱灯
                  kerosene lamp 煤油灯
                  kino lamp 显象管
                  krypton (filled) lamp 氪气灯
                  lens lamp 透镜灯
                  locomotive frame lamp 机车车下照明灯
                  locomotive head lamp 机车头灯
                  low level lamp 房间夜间灯
                  luminous standard lamp 光度标准灯(泡)
                  magic lamp 幻灯
                  marker lamp 识别信号灯, 标(志)灯
                  master pilot lamp 总指示灯
                  meat-ageing lamp 肉品熟化灯(加速肉品成熟)
                  mercury lamp 汞灯
                  mercury arc lamp 水银灯, 水银弧光灯
                  mercury vapour lamp 水银灯; 水银荧光灯
                  metal halide lamp 金属卤化物灯
                  metal vapour lamp 金属蒸汽放电灯
                  metallic electrode arc lamp 金属电极弧光灯
                  metallic filament lamp 金属丝灯
                  middle-ultraviolet lamp 中紫外灯
                  midget lamp 小型电子管
                  mill-type lamp 耐[防]震灯泡
                  miner's lamp 矿灯, 采矿灯
                  miner's hand lamp 【采矿】手提自给矿工灯
                  miniature lamp 指示灯; 小型灯泡
                  multifilament lamp 多灯丝白炽灯
                  multiple arc lamp 并联弧光灯
                  negative-glow lamp 辉光放电管
                  neon arc lamp 氖(弧)灯, 氖光灯, 霓虹灯
                  neon glim lamp 氖光灯, 霓虹灯泡
                  neon glow lamp 氖辉光灯管
                  neon tube lamp 霓虹管灯, 氖管灯
                  noise lamp 噪声灯
                  nitrogen-filled lamp 充氮气灯泡
                  normal lamp 定位表示灯
                  normal indication lamp 定位表示灯
                  normally extinguished signal lamp 正常熄灭的信号灯
                  normally lighted signal lamp 正常点亮的信号灯
                  occupancy lamp 占用表示灯
                  OK lamp 绿灯(表示"准备完毕"的绿色信号灯)
                  oil-gas lamp 油气灯
                  oil switch lamp 道岔油灯
                  on-the-air lamp 表示"正在广播"的红灯
                  opal lamp 乳白灯
                  open arc lamp 敞式[无罩, 室外]弧光灯
                  optical sound lamp 光录音灯
                  osglim lamp 氖氦辉光灯, 霓虹灯
                  osram lamp 钨丝灯
                  outgoing code lamp 发出电码表示灯
                  overflow lamp 溢出指示灯
                  panel lamp 壁灯
                  pentane lamp 戊烷灯
                  permanent glow lamp 不挂机监视灯
                  permanent loop lamp 不挂机监视灯
                  permissible (safety) lamp 安全灯
                  phasing lamp 定相灯
                  photoflash lamp 闪光灯
                  photoflood lamp 照相用泛光灯
                  pilot lamp 指示灯, 信号灯; 表盘灯; 监视灯
                  pilot indicating lamp 航向指示灯
                  polarization lamp 旋光计灯; 偏振光计灯
                  portable lamp 手提灯
                  portable electric lamp 便携电灯
                  position lamp 指示灯, 位置灯; 席别灯
                  potentiometer lamp 电位器灯泡
                  prefocus lamp 聚光灯, 定焦灯
                  preheat fluorescent lamp 预热荧光灯
                  preheat hot cathode lamp 预热式热阴极灯
                  pressure vapour lamp 煤油蒸汽灯
                  pressurized lamp 高压灯
                  printing lamp 印刷用灯, 晒象用灯
                  projector lamp 投射灯, 幻灯, 放影灯
                  projector-type filament lamp 集光型白炽灯
                  protection lamp 保护灯
                  pulsed-flash gas-discharge lamp 脉冲闪光气体放电灯
                  pumping lamp 抽运灯, 泵浦灯
                  punctiform lamp 点形灯
                  push button lamp 按钮表式灯
                  pygmy lamp 小型灯; (手电用)小灯泡
                  quartz lamp 石英灯, 水晶灯
                  quartz-halogen lamp 石英卤素灯
                  quartz mercury lamp 石英水银灯
                  quartz mercury arc lamp 石英汞弧灯
                  quick start lamp 快速[瞬时]起动灯
                  radiant heat lamp 辐射热灯
                  rear-end stop lamp 后端停车灯
                  rear identification lamp 后标志灯
                  recording lamp (电影)录音灯
                  rectifier lamp 整流管
                  red incandescent electric lamp 红色炽光灯
                  reference standard lamp 参考标准灯
                  reflector lamp 反光灯
                  register lamp 记录(器)指示灯
                  register pilotlamp 记录器领示灯, 计数器信号灯
                  relighter flame safety lamp 【采矿】自点火焰安全灯
                  resistance lamp 电阻灯
                  resonance lamp 【原物】共振灯
                  reverse lamp 反位表示灯
                  reverse indication lamp 反位表示灯
                  ringing pilot lamp 振铃[呼唤]指示灯
                  room lamp 室内灯
                  rough service lamp 耐用灯, 防震灯
                  safe lamp 【摄】安全灯
                  safety (head) lamp 安全(头)灯
                  scale lamp 指示灯
                  screw base lamp 螺丝口灯泡
                  section lamp 分区[组]指示灯
                  semaphore lamp 臂板信号灯
                  series resistance lamp 串联电阻灯
                  series-wound arc lamp 串联连接的弧光灯
                  service lamp 轻便灯, 手提灯
                  shunt-wound arc lamp 并绕式弧光灯
                  side lamp 侧灯
                  sign lamp 信号灯
                  signal lamp 信号灯
                  signal indication lamp 信号表示灯
                  signal point indicator lamp 道岔表示器灯
                  silica lamp 石英水银灯
                  slimline type fluorescence lamp 细长管式荧光灯
                  slit lamp 缝灯, 狭缝灯
                  slot lamp 狭缝照明灯
                  sodium (discharge) lamp 钠汽灯
                  sodium-vapor lamp 钠蒸汽灯
                  soldering lamp 焊接用喷灯
                  spectrum lamp 光谱灯
                  standard lamp 标准灯
                  stand-by lamp 备用灯
                  star lamp 星灯
                  sterilizing lamp 杀菌灯, 灭菌灯
                  storm lamp 风雨灯, 防风(手)灯
                  straight sided lamp 茄子形灯泡
                  strip lamp 照明带; 管状灯, 灯管
 楼主| 发表于 2007-7-9 16:21:49 | 只看该作者
strip-light lamp 顶灯
stroboscopic lamp 闪光灯, 频闪灯
sun lamp 日光灯, 太阳灯
supervisory lamp 监视灯
switch lamp 道岔表示[标志]灯
switch correspondence lamp 道岔位置符合表示灯
switch indication lamp 道岔表示灯
switch lever lamp 道岔握[手]柄表示灯
switchboard lamp 交换台灯
synchronizing lamp 同步指示灯
table lamp 台灯
tail lamp (列车)尾灯
tantalum lamp 钽丝灯
target lamp 灯塔, 目标灯
television lamp 电视光源灯
telltale lamp 信号灯
temporary lamp 临时灯
tender lamp 煤水车灯
test lamp 试验灯
time check lamp 报时灯
time code lamp 时间码指示灯
timing lamp 调时标灯, 定时标灯
tiny lamp 小型电子管
toll line lamp 长途线号灯
torch lamp 喷灯
tornado lamp 防风灯
track indication lamp 轨[股]道表示灯
track occupancy lamp 轨[股]道占用表示灯
traffic indication lamp 运行方向表示灯
train departure indication lamp 发车[离去]表示灯
transistor fluorescent lamp 晶体管荧光灯
trap lamp 诱虫灯
trouble lamp 故障指示灯
trunk congestion lamp 中继线占用指示灯
tube lamp 管形灯泡
tubular lamp 管形灯泡
tungsten lamp 钨丝灯
tungsten-filament lamp 钨丝灯
tungsten-iodine lamp 碘钨灯
tuning lamp 调谐指示灯
twin-carbon arc lamp 双碳弧光灯
ultraviolet lamp 紫外线灯
ultraviolet germicidal lamp 紫外线杀菌灯
ultra-violet ray lamp 紫外线(电)灯
user lamp 用户指示灯
utility lamp 通用灯
uviol lamp 紫外灯
vacuum lamp 真空灯
vacuum fluorescent lamp 真空荧光灯
vestibule lamp 通过台灯
visual idle indication lamp 空线信号灯
vitalight lamp 紫外线灯(泡)
wall (bracket) lamp 墙灯, 壁灯
warning lamp 告警灯
water ga(u)ge lamp 水表灯
welding blow lamp 焊炬
white fluorescent lamp 白色荧光灯
、 whole night lamp 终夜灯
working standard lamp 标准工作电灯
xenon lamp 氙气灯; 氙气管
xenon arc lamp 氙弧灯
xenon flash lamp 氙气闪光灯
xenon-mercury lamp 汞氙灯
xenon vapor lamp 氙气灯(即人工小太阳)
发表于 2007-7-9 21:43:33 | 只看该作者
版主,太感谢你了
发表于 2007-7-9 22:47:40 | 只看该作者
zhi chi ~~~~~~~~~~~~~~~
发表于 2007-7-10 10:17:04 | 只看该作者
这是个好东东,多谢楼主
发表于 2009-5-8 16:04:41 | 只看该作者
加油!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2010-1-24 09:01:40 | 只看该作者
太好了,有這怎多資料
发表于 2010-1-25 10:34:09 | 只看该作者
绝对支持,非常感谢
发表于 2010-2-10 22:35:29 | 只看该作者
aaa
这么多灯的英文,都急啊
GMT+8, 2026-10-17 14:42 , Processed in 0.074359 second(s), 20 queries , Gzip On.
