查看: 873|回复: 6
MTBF
发表于 2008-1-9 15:55:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有興趣的可以看看. 1
Description of Equipment
This Mean-Time-Between-Failure Prediction has been performed for the Telecommunications System. This
equipment consists of a System chassis with plug-in circuit board modules. Each sub-level unit includes it’s
associated circuit boards, enclosures, and cables. The following describes the equipment with it’s components.
Assembly Part Number
CE3
FE1
ENET 6U
T1 PKT
OC3 SMF
OC3 MMF
ATM DS3
DS3 PKT
ETH-3U
DC Power Supply
AC Power Supply
Assumptions and Conditions
This calculation relates to operational hours, as opposed to elapsed hours, so this should be reflected in the overall
reliability if required.
Models provided by the Telcordia (Bellcore) TR332, Issue 6, “Reliability Prediction Procedure for Electronic
Equipment” specification and manufacturer’s failure rate data, when available, was used.
Ambient temperature = 25 oC
Environment = Ground Benign, Controlled (GB)
Model = Serial. Redundant paths do not exist.
Bellcore TR-332, Issue 6, Calculation Method = Limited Stress, Method I, Case 3
Component Quality Level = II
Temperature rise of components - See Appendix B.
Electrical Stress - See Appendix B.
Omitted Items
Device Reason for omission
Assembly hardware Stationary mechanical devices are omitted
发表于 2008-1-21 01:29:47 | 只看该作者
好
好东东
学习先
咋没人顶呢
发表于 2008-1-24 09:38:36 | 只看该作者
:lol :lol
发表于 2008-1-24 13:00:27 | 只看该作者
学习学习,要是中文就好了
发表于 2008-2-16 11:03:07 | 只看该作者
原帖由 5982168 于 2008-1-24 13:00 发表
学习学习,要是中文就好了
LZ應該可以翻譯一下吧!
发表于 2008-2-16 11:34:58 | 只看该作者
学习一下了,最好是中文的就好了
发表于 2008-2-16 16:22:22 | 只看该作者
GMT+8, 2026-10-17 21:55 , Processed in 0.112777 second(s), 18 queries , Gzip On.
