查看: 771|回复: 3
货柜知识
发表于 2007-12-14 20:30:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助关于货柜的资料
   柜型, 外部尺寸, 内部尺寸, 载重, 谢谢
发表于 2007-12-16 16:54:35 | 只看该作者
Container dimension for size/weight etc.,FYI.
container                aka                dimensions         max        carrier usable        "tare wt.
MTs"
                Gtcs        other designations        (in feet)        CBM        CBM        (1,000 kgs)
20' dry goods van                20'        D2, D20, 20DV        8x8.5x20        33        27        18.5
20' reefer                20' Reef        "R2, 20reefer, 20R, Ref 20',
20' integral, 20' int."        "8x8.5x20
(7.6x7.5x18)"        "27.90
(28.50)"        27        27.5
24' reefer                --        24' Reef, 24reefer, 24R        8x8.5x24        31.15
28' dry goods van                28'        LTL tup ("piggyback")        8x9x28        57.45
40' dry goods van                40'        D4, D40, 40DV        8x8.5x40        67        55        37
40' dry goods van                40'        D41, 41DV, D40, 40DV        8x9x40
Dry 40' reefer                Dry 40' Reef        Dry Reefer        8x8.5x40        58.7        56        39.5
40' reefer                40' Reef        "R4, 40R, 40 reefer,
40' integral, 40' int."        8x8.5x40        58.7        56        39.5
40' high cube dry goods                40' HC        D5, 40HQ, 40HC        8x9.5x40        76        76        39.3
Dry 40' high cube reefer                Dry HC Reef        Dry Reefer        8x9.5x40        67        64.3        45.5
40' high cube reefer                HC Reef        "R5, HC reefer, 40HQ reefer,
40' HC integral, 40' HC int."        8x9.5x40        67        64.3        45.5
45' dry goods van                45'        D7, D45, 45DV        8x9.5x45        86        86        45.9
45' reefer                45' Reef        R7, 45reefer, 45R, Ref 45'        8x9.5x45        75.4        72.4        52
48' dry goods van                48'        D48, 48DV        8x9.5x48        97.69        97.69
48' reefer                --        48reefer, 48R, Ref 48'        8x9.5x48
53' dry goods van                53'        D53, 53DV        8x9.5x53        107.6
53' insulated van                --        53KFF, 53insul        8x9.5x53        101.94
53' reefer                --        53reefer, 53R, Ref 53'        8x9.5x53
57'                57'        D57, 57DV        8x9.5x57        133.09
发表于 2007-12-16 16:58:24 | 只看该作者
没办法,只有一个扩展名.gif可用,所以只能粘上来.
发表于 2007-12-16 20:39:44 | 只看该作者
很难看清楚啊
就不能编排一下?
GMT+8, 2026-6-15 00:38 , Processed in 0.067702 second(s), 18 queries , Gzip On.
