查看: 1037|回复: 3
纺织品英文解释
发表于 2007-12-14 16:15:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Ottoman : A warp-faced cloth with a fairly flat, bold, smooth, weft-way rib. Originally made from a silk warp and worsted weft. The heavier weight cloths are suitable for tailoring and may have a small fancy design included in the general weft-way rib effect.
  • Oxford : A good quality shirting fabric made in a plain-weave with two ends weaving as one. It is generally made from cotton. Stripes of dyed yarn or decorative weaves are sometimes introduced.
  • Panama : A worsted fabric with a clear finish weighing about 200 g/m² and used for tropical suitings. The fabric is of a plain-weave and square construction. Fibres other than wool may be used. (NB A Panama embroidery canvas of a hopsack weave which is beetled must not be confused with the worsted Panama).
  • Piece : The unit length of fabric removed from the loom. The standard length depends on the type of fabric but may be such as best suits the purchaser. Piece lengths are generally between 75 and 120m. According to the state of the cloth expressions such as ‘loomstate piece’ and ‘dyed piece’ may be used.
  • Pile fabric : A fabric with tufts of fibre or loops of yarn projecting from the surface. The most important classes of pile fabric at present are (a) woven, in which case it has cut or uncut warp pile or cut weft pile, (b) knitted, in which case end of fibres may form the pile or the pile may consist of loops, or, (c) tufted, which results in brushed, cut or uncut pile.
  • Pilot : A heavily milled and raised woollen cloth generally used for seamen’s jackets and overcoats. It is available in a wide range of fibre qualities. A 2/2 twill is often used.
  • Piqué : Originally a woven cloth with rounded cords running in the weft direction, now often made in a lightweight Bedford cord weave with the cord running in the warp direction. Different widths of cord may be produced in one cloth to create interest and the fabric may be printed. A piqué effect may be produced by warp or weft knitting.
  • Plush : A cut warp-pile fabric similar to a velvet but having a longer end less dense pile laid in one direction.
 楼主| 发表于 2007-12-14 16:22:44 | 只看该作者
纺织品英语解释(续)
  • Printed cloth : A cloth on which a coloured pattern has been printed.
  • Pure new wool : A description of wool textiles carrying the IWS Woolmark. A maximum tolerance of 5% is allowed for non-wool fibres used for decorative effects and 0.3% for inadvertent impurities
  • Ratiné : Originally a thick woollen cloth with a curled nap. Ratiné, the past participle of the French verb ratiner (meaning to cover with a curled nap) has also been applied to a cloth made form a variety of fibres, with a rough surface produced in one of a number of different ways, either by using a fancy yarn in a cloth to which a special finishing technique may or may not be applied or by using ordinary yarns in a cloth to which the special finish is applied.
  • Regatta : A good quality 2/1 twill fabric of almost square construction and about 180 g/m² woven in even width stripes of dyed and white yarns. It is commonly made from cotton or other suitable staple fibre. Often used for nurse’s uniforms.
  • Regina : A fine quality 2/1 twill fabric with about twice as many ends as picks and weighing about 100 g/m²
  • Ribbon : An attractive woven fabric characterised in the higher qualities by fine warp yarns and high warp density and usually of lustrous appearance. Generally used for trimming and adornment.
  • Nap fabric : This refers to woollen overcoating of up to 1,000 g/m² which has been rubbed during finishing to produce a beady or pilled surface.
  • Narrow fabric : Sometimes known as ‘smallwares’. (1) Any textile fabric not exceeding 45 cm in width with 2 selvedges (2) Any trimming
  • Needlecord : A fine-ribbed corduroy used for dresses.
  • Ninon : This may be used to describe a voile fabric made form manufactured fibres. Originally it applied to fine, light open silk cloths with highly twisted yarns woven in groups of two or three in both warp and weft and known as double or triple Ninon.
发表于 2008-1-8 10:15:58 | 只看该作者
Thank you!
发表于 2008-1-12 18:53:38 | 只看该作者
看不懂啊
悲!
GMT+8, 2026-11-4 05:32 , Processed in 0.198390 second(s), 19 queries , Gzip On.
