查看: 970|回复: 2
什么样的灯泡才是冷光束的灯泡?
发表于 2007-12-14 08:33:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如何理解EN60598-1的3.2.11条款:
Symbol (see Figure 1), if applicable, for luminaires for lamps of similar shape to "cool
beam" lamps but where the use of a dichroic reflectorized "cool beam" lamp might impair
safety
什么样的灯泡才是冷光束的灯泡?
发表于 2008-1-23 15:25:56 | 只看该作者
e.g.
MR16 Halogen bulb with dichroic reflector.
Cool Beam - Two thirds of the heat produced from the bulb is evacuated through the back of the lamp.
Filament bulb generats HEAT and LIGHT.
Dichroic coating is good to reflect the light but not to the heat. So most of the heat dissiplated from the back but the light is reflected and directed to the front. So you do not feel heat as the ordinary Filament bulb.
Cool Beam lamps must be used in open or well ventilated fixtures, suitably designed to dissipate the heat which is radiated to the back of the lamp.
http://www.promolux.com/english/mr16.html
参与人数 1金币 +6 收起 理由
kinzo + 6 精品文章
发表于 2008-1-31 13:42:48 | 只看该作者
不明白啊,
有没有实际例子的
谢谢
GMT+8, 2026-10-22 00:57 , Processed in 0.149766 second(s), 19 queries , Gzip On.
